    [plugin] Divide By Material
    17 Posts 9 Posters 18.2k Views 9 Watching
    • sdmitchS Offline
      sdmitch
      srx, Glad that the plugin works for you. The plugin posted to this forum doesn't require you to pre-select the faces. If there are no selected faces, it looks at all faces in the model and sub-divides the ones with the given material.
      As far as groups and components go, you can sub-divide their faces if you enter edit mode before running the plugin. This selects the faces and makes them accessable.
      http://sdmitch.blogspot.com/
      • Didier BurD Offline
        Didier Bur
        Works on my PC at home (Win 7 SU8 Pro) but doesn't work at my office (WinXP SU8 Pro).
        Would it be possible to have the localized material names instead of english names ?
        DB
        • srxS Offline
          srx
          This means that I have to enter every group - component in model manual?
          Is it a problem to make it work for all nested geometry in model? This would be even more useful ๐Ÿ˜„
          www.saurus.rs
          • sdmitchS Offline
            sdmitch
            srx, Your wish is granted. DivideByMaterial.rb now handels faces in groups and components.
            Updated to handle groups and components
            • EarthMoverE Offline
              EarthMover
              Nice work Sam. ๐Ÿ‘ Thanks for the update. Perhaps update the first post as well.
              Content Creator at Skapeup
              • srxS Offline
                srx
                ๐Ÿ˜„
                ๐Ÿ˜ณ
                Thank you Sam. Very kind of you.
                I agree you should update the first post.
                www.saurus.rs
                • Z Offline
                  ZFRPS
                  nice!
                  Thank you Sam ![img][url][/url][/img]
                  sketchup is bim
                    Daryan
                    "undefined method `file_loaded?' for main:Object"
                      Very probably it's an install error but since we don't know anything whatsoever about your SketchUp version, operating system, nor how you went about installing the plugin, there's not much help to be given. Please complete your profile and help us help you.
                        Daryan
                        Sorry, your right. Because im very bad in english i usualy say the less possible.
                        Windows 8.1
                        Sketchup 8 pro
                        install the plugin : just copy past the file "DivideByMaterial.rb" in C:\Program Files (x86)\Google\Google SketchUp 8\Plugins
                          The file is missing a line at its start:
                          require("sketchup.rb")
                          This is not needed IF an earlier loaded script has already required/loaded sketchup.rb...
                          But I suspect you do not have that happening...
                          Rather than edit the main file... Add this new file to your Plugins folder...!.rb
                          On a restart of SketchUp any scripts missing the ' require("sketchup.rb")' should be OK because the !.rb files loads very early and will have done that for them...
                            Daryan
                            Thanks a lot TIG !
