    [plugin] Divide By Material
    17 Posts 9 Posters 18.4k Views 9 Watching
      Thanks again, Sam!
      • srxS Offline
        srx
        Thank you Sam. I am glad for being part of this modest contribution to SC forum to which I own so much.
        www.saurus.rs
        • Didier BurD Offline
          Didier Bur
          The script doesn't do anything here, no subdivision, no material paint 😲
          DB
          • srxS Offline
            srx
            First select geometry (not groups) with different materials applied.
            Run plugin and chose the material which you want to subdivide and the maximum size of subdivision...and
            It works for me...
            but only for geometry not in groups or components .
            Guess the next step is to make it work for all nested geometry 😄
            www.saurus.rs
            • sdmitchS Offline
              sdmitch
              srx, Glad that the plugin works for you. The plugin posted to this forum doesn't require you to pre-select the faces. If there are no selected faces, it looks at all faces in the model and sub-divides the ones with the given material.
              As far as groups and components go, you can sub-divide their faces if you enter edit mode before running the plugin. This selects the faces and makes them accessable.
              http://sdmitch.blogspot.com/
                Didier Bur
                Works on my PC at home (Win 7 SU8 Pro) but doesn't work at my office (WinXP SU8 Pro).
                Would it be possible to have the localized material names instead of english names ?
                DB
                • srxS Offline
                  srx
                  This means that I have to enter every group - component in model manual?
                  Is it a problem to make it work for all nested geometry in model? This would be even more useful 😄
                  www.saurus.rs
                  • sdmitchS Offline
                    sdmitch
                    srx, Your wish is granted. DivideByMaterial.rb now handels faces in groups and components.
                    Updated to handle groups and components
                    • EarthMoverE Offline
                      EarthMover
                      Nice work Sam. 👍 Thanks for the update. Perhaps update the first post as well.
                      Content Creator at Skapeup
                      • srxS Offline
                        srx
                        Thank you Sam. Very kind of you.
                        I agree you should update the first post.
                        www.saurus.rs
                        • Z Offline
                          ZFRPS
                          nice!
                          Thank you Sam ![img][url][/url][/img]
                          sketchup is bim
                            Daryan
                            "undefined method `file_loaded?' for main:Object"
                              Very probably it's an install error but since we don't know anything whatsoever about your SketchUp version, operating system, nor how you went about installing the plugin, there's not much help to be given. Please complete your profile and help us help you.
                                Daryan
                                Sorry, your right. Because im very bad in english i usualy say the less possible.
                                Windows 8.1
                                Sketchup 8 pro
                                install the plugin : just copy past the file "DivideByMaterial.rb" in C:\Program Files (x86)\Google\Google SketchUp 8\Plugins
                                  The file is missing a line at its start:
                                  require("sketchup.rb")
                                  This is not needed IF an earlier loaded script has already required/loaded sketchup.rb...
                                  But I suspect you do not have that happening...
                                  Rather than edit the main file... Add this new file to your Plugins folder...!.rb
                                  On a restart of SketchUp any scripts missing the ' require("sketchup.rb")' should be OK because the !.rb files loads very early and will have done that for them...
                                    Daryan
                                    Thanks a lot TIG !
