    Is this a video card issue?
    17 Posts 4 Posters 977 Views 4 Watching
      mrossk
      and that's not good?
      https://www.mkaplanfinefurniture.com/
        I don't think the transparent toolbars has anything to do with it.
        Is it the red line going off in the wrong direction? What happens if you orbit a little bit?
          mrossk
          hey Dave!- Yes, the red line goes off 180 degrees from where I'm trying to go. In the above example, I was trying to draw from the leg on the left to that on the right. You can see the red inferencing line going off to the left. If I orbit, or try again, it will usually try to do the right thing, but if I get close to another object, line, face, whatever, it will sometimes "jump away" again. I can usually get it to work after some coaxing, but it often takes more work than I would like, and it can make precise work frustrating. Haven't heard anyone else mention it, so my first thought was lousy video card, but honestly, I know next to nothing about hardware.
            I haven't seen that sort of thing. Would you e-mail the model to me with the same view where you get it? I'll try it and see what happens.
              mrossk
              I will, but unfortunately I'm late to leave my house- I'll do it tonight,Thanks!
                OK. Later.
                • BoxB
                  It could be something as simple as having the precision set too large and snap to on, so the endpoint sort of jumps away.
                  • KrisidiousK
                    Krisidious
                    is it an inference line or an axis line? has to be inference with that blue line being where it is. I'm with Box. check your units. make sure they are a nice scale to be working in. like 1/8" or 1/4" for furniture. Dave's our resident furniture builder though, he'd know better what units to use.
                    By: Kristoff Rand
                      mrossk
                      I usually work with the precision to 1/64", after all, this is fine woodworking:). I tried changing it to 1/32 or 1/16, and I don't work with "snap" on. Didn't seem to make a difference either way. Something I didn't think to mention earlier, though perhaps it's related- occasionally when surfing the web, if I change web pages, part of the previous web page will briefly linger on the new web page until I scroll or move on that page. For example, if I'm doing a Google search, when I click on a link, part of the Google Search page (a few lines or a portion of the screen) will linger on the new page. Perhaps it's related?
                      Any help is appreciated...
                      • KrisidiousK
                        Krisidious
                        When we said to check the units it was because it might have been set to something quite large. like 1 foot. those lower units won't make any difference. I'm not familiar with the GT 520. I use two GTX 470's I would suggest a larger video card if that one isn't 1 gig. But have never seen this issue. SO not sure it's a graphic issue.
                        By: Kristoff Rand
                          mrossk
                          Krisidious- Thanks. I'll really show my ignorance here. Which specification is the "1 gig" you refer to? Below are the specifications for this card. Thanks for the help.
                          GPU Engine Specs
                          CUDA Cores
                          48
                          Graphics Clock (MHz)
                          810
                          Processor Clock (MHz)
                          1620
                          Texture Fill Rate (billion/sec)
                          6.5
                          Memory Specs
                          Memory Clock
                          900 MHz (DDR3)
                          Standard Memory Config
                          1024 MB (DDR3)
                          Memory Interface
                          DDR3
                          Memory Interface Width
                          64-bit
                          Memory Bandwidth (GB/sec)
                          14.4
                          Feature Support
                          OpenGL
                          4.2
                          Bus Support
                          PCI-E 2.0 x16
                          Supported Technologies
                          DirectX 11, CUDA, PhysX
                          Display Support
                          Multi Monitor
                          Yes
                          Maximum Digital Resolution
                          2560x1600
                          Maximum VGA Resolution
                          2048x1536
                          Standard Display Connectors
                          Dual Link DVI-I
                          HDMI
                          VGA (optional)
                          HDMI1
                          Yes
                          Standard Graphics Card Dimensions
                          Length 5.7 inches
                          Height 2.7 inches
                          Width Single slot
                          Thermal and Power Specs
                          Maximum GPU Temperature (in C) 102
                          Maximum Graphics Card Power (W) 29 W
                          Minimum System Power Requirement (W) 300 W
                            I think we sorted the problem with the inferencing last night. It appears to be a case of an unresolvable inference. The line's direction is locked in the red direction and the cursor is placed on a face that would never intersect with the line no matter how long the line, not how big the face. This isn't a video card issue but as I told Michael last night, more like a divide-by-zero sort of thing.
                              mrossk
                              I agree Dave, and thanks again. I only asked about the card specs to educate myself, and thought it might help with the other issue I was having; knowing right next to nothing is often problematic when dealing with computers!
                                No worries, Michael. I just thought we should answer the original question. Ignorance can be bliss but you're right when it comes to computers. πŸ˜‰
                                • KrisidiousK
                                  Krisidious
                                  Glad you got it figured out. Looks like you do have a 1 gig card.
                                  here's our two cards compared. remember that I have two of them and that mine are like 4-5 years old and pretty outdated. if you have an extra $300 bucks laying around, a GTX 770 would be smokin fast.
                                  Your Card
                                  GPU Engine Specs
                                  CUDA Cores - 48
                                  Graphics Clock (MHz) - 810
                                  Processor Clock (MHz) - 1620
                                  Texture Fill Rate (billion/sec) - 6.5
                                  Memory Specs
                                  Memory Clock - 900 MHz (DDR3)
                                  Standard Memory Config - 1024 MB (DDR3)
                                  Memory Interface - DDR3
                                  Memory Interface Width - 64-bit
                                  Memory Bandwidth (GB/sec) - 14.4
                                  Feature Support
                                  OpenGL - 4.2
                                  Bus Support - PCI-E 2.0 x16
                                  Display Support
                                  Multi Monitor - Yes
                                  Maximum Digital Resolution - 2560x1600
                                  Maximum VGA Resolution - 2048x1536
                                  Dual Link DVI-I
                                  HDMI
                                  VGA (optional)
                                  HDMI1 - Yes
                                  My Card
                                  GPU Engine Specs
                                  CUDA Cores - 448
                                  Graphics Clock (MHz) - 607 MHz
                                  Processor Clock (MHz) - 1215 MHz
                                  Texture Fill Rate (billion/sec) - 34.0
                                  Memory Specs
                                  Memory Clock - 1674 MHz (3348 data rate)
                                  Standard Memory Config - 1280 MB
                                  Memory Interface - GDDR5
                                  320-bit
                                  Memory Bandwidth (GB/sec) - 133.9 GB/sec
                                  Feature Support
                                  OpenGL - 4.2
                                  3D Vision Surround, SLI, DirectX 11, CUDA, 3D Vision, PhysX
                                  SLI Options1
                                  2-way
                                  3-way
                                  Display Support
                                  Multi Monitor - Yes
                                  Two Dual Link DVI
                                  Mini HDMI
                                  HDMI
                                  Yes
                                  By: Kristoff Rand
