    Is this a video card issue?
    17 Posts 4 Posters 371 Views 4 Watching
      mrossk
      Hey y'all- I have an issue where occasionally, if I'm zoomed in close, using the line tool, trying to inference to an existing face the inferencing line will shoot out in the completely opposite direction- it sometimes makes it impossible to inference. The last time this happened was on the model of a small stool, trying to draw a stretcher from one leg to another. I've attached a screen shot, I think you can see what I mean.
      My computer has a relatively low grade NVIDIA GeoForce GT 520 card, but otherwise it's a decent machine for the work I do. Windows 7, 3.30GHz, 6.0 GB RAM. Would the video card be responsible for this? If so, how does a relatively computer illiterate guy like myself choose a wise upgrade for say $150.00 or so? Thanks for any help,
      https://www.mkaplanfinefurniture.com/
      • KrisidiousK Offline
        Krisidious
        looks like you have windows transparent toolbars on...
        By: Kristoff Rand
          mrossk
          and that's not good?
            I don't think the transparent toolbars has anything to do with it.
            Is it the red line going off in the wrong direction? What happens if you orbit a little bit?
              mrossk
              hey Dave!- Yes, the red line goes off 180 degrees from where I'm trying to go. In the above example, I was trying to draw from the leg on the left to that on the right. You can see the red inferencing line going off to the left. If I orbit, or try again, it will usually try to do the right thing, but if I get close to another object, line, face, whatever, it will sometimes "jump away" again. I can usually get it to work after some coaxing, but it often takes more work than I would like, and it can make precise work frustrating. Haven't heard anyone else mention it, so my first thought was lousy video card, but honestly, I know next to nothing about hardware.
                I haven't seen that sort of thing. Would you e-mail the model to me with the same view where you get it? I'll try it and see what happens.
                  mrossk
                  I will, but unfortunately I'm late to leave my house- I'll do it tonight,Thanks!
                    OK. Later.
                    • BoxB Online
                      It could be something as simple as having the precision set too large and snap to on, so the endpoint sort of jumps away.
                        Krisidious
                        is it an inference line or an axis line? has to be inference with that blue line being where it is. I'm with Box. check your units. make sure they are a nice scale to be working in. like 1/8" or 1/4" for furniture. Dave's our resident furniture builder though, he'd know better what units to use.
                        By: Kristoff Rand
                          mrossk
                          I usually work with the precision to 1/64", after all, this is fine woodworking:). I tried changing it to 1/32 or 1/16, and I don't work with "snap" on. Didn't seem to make a difference either way. Something I didn't think to mention earlier, though perhaps it's related- occasionally when surfing the web, if I change web pages, part of the previous web page will briefly linger on the new web page until I scroll or move on that page. For example, if I'm doing a Google search, when I click on a link, part of the Google Search page (a few lines or a portion of the screen) will linger on the new page. Perhaps it's related?
                          Any help is appreciated...
                            Krisidious
                            When we said to check the units it was because it might have been set to something quite large. like 1 foot. those lower units won't make any difference. I'm not familiar with the GT 520. I use two GTX 470's I would suggest a larger video card if that one isn't 1 gig. But have never seen this issue. SO not sure it's a graphic issue.
                            By: Kristoff Rand
                              mrossk
                              Krisidious- Thanks. I'll really show my ignorance here. Which specification is the "1 gig" you refer to? Below are the specifications for this card. Thanks for the help.
                              GPU Engine Specs
                              CUDA Cores
                              48
                              Graphics Clock (MHz)
                              810
                              Processor Clock (MHz)
                              1620
                              Texture Fill Rate (billion/sec)
                              6.5
                              Memory Specs
                              Memory Clock
                              900 MHz (DDR3)
                              Standard Memory Config
                              1024 MB (DDR3)
                              Memory Interface
                              DDR3
                              Memory Interface Width
                              64-bit
                              Memory Bandwidth (GB/sec)
                              14.4
                              Feature Support
                              OpenGL
                              4.2
                              Bus Support
                              PCI-E 2.0 x16
                              Supported Technologies
                              DirectX 11, CUDA, PhysX
                              Display Support
                              Multi Monitor
                              Yes
                              Maximum Digital Resolution
                              2560x1600
                              Maximum VGA Resolution
                              2048x1536
                              Standard Display Connectors
                              Dual Link DVI-I
                              HDMI
                              VGA (optional)
                              HDMI1
                              Yes
                              Standard Graphics Card Dimensions
                              Length 5.7 inches
                              Height 2.7 inches
                              Width Single slot
                              Thermal and Power Specs
                              Maximum GPU Temperature (in C) 102
                              Maximum Graphics Card Power (W) 29 W
                              Minimum System Power Requirement (W) 300 W
                                I think we sorted the problem with the inferencing last night. It appears to be a case of an unresolvable inference. The line's direction is locked in the red direction and the cursor is placed on a face that would never intersect with the line no matter how long the line, not how big the face. This isn't a video card issue but as I told Michael last night, more like a divide-by-zero sort of thing.
                                  mrossk
                                  I agree Dave, and thanks again. I only asked about the card specs to educate myself, and thought it might help with the other issue I was having; knowing right next to nothing is often problematic when dealing with computers!
                                    No worries, Michael. I just thought we should answer the original question. Ignorance can be bliss but you're right when it comes to computers. 😉
                                      Krisidious
                                      Glad you got it figured out. Looks like you do have a 1 gig card.
                                      here's our two cards compared. remember that I have two of them and that mine are like 4-5 years old and pretty outdated. if you have an extra $300 bucks laying around, a GTX 770 would be smokin fast.
                                      Your Card
                                      GPU Engine Specs
                                      CUDA Cores - 48
                                      Graphics Clock (MHz) - 810
                                      Processor Clock (MHz) - 1620
                                      Texture Fill Rate (billion/sec) - 6.5
                                      Memory Specs
                                      Memory Clock - 900 MHz (DDR3)
                                      Standard Memory Config - 1024 MB (DDR3)
                                      Memory Interface - DDR3
                                      Memory Interface Width - 64-bit
                                      Memory Bandwidth (GB/sec) - 14.4
                                      Feature Support
                                      OpenGL - 4.2
                                      Bus Support - PCI-E 2.0 x16
                                      Display Support
                                      Multi Monitor - Yes
                                      Maximum Digital Resolution - 2560x1600
                                      Maximum VGA Resolution - 2048x1536
                                      Dual Link DVI-I
                                      HDMI
                                      VGA (optional)
                                      HDMI1 - Yes
                                      My Card
                                      GPU Engine Specs
                                      CUDA Cores - 448
                                      Graphics Clock (MHz) - 607 MHz
                                      Processor Clock (MHz) - 1215 MHz
                                      Texture Fill Rate (billion/sec) - 34.0
                                      Memory Specs
                                      Memory Clock - 1674 MHz (3348 data rate)
                                      Standard Memory Config - 1280 MB
                                      Memory Interface - GDDR5
                                      320-bit
                                      Memory Bandwidth (GB/sec) - 133.9 GB/sec
                                      Feature Support
                                      OpenGL - 4.2
                                      3D Vision Surround, SLI, DirectX 11, CUDA, 3D Vision, PhysX
                                      SLI Options1
                                      2-way
                                      3-way
                                      Display Support
                                      Multi Monitor - Yes
                                      Two Dual Link DVI
                                      Mini HDMI
                                      HDMI
                                      Yes
                                      By: Kristoff Rand
