    Is this a video card issue?
    17 Posts 4 Posters 1.0k Views 4 Watching
    • KrisidiousK
      Krisidious
      looks like you have windows transparent toolbars on...
      By: Kristoff Rand
        mrossk
        and that's not good?
        https://www.mkaplanfinefurniture.com/
          I don't think the transparent toolbars has anything to do with it.
          Is it the red line going off in the wrong direction? What happens if you orbit a little bit?
            mrossk
            hey Dave!- Yes, the red line goes off 180 degrees from where I'm trying to go. In the above example, I was trying to draw from the leg on the left to that on the right. You can see the red inferencing line going off to the left. If I orbit, or try again, it will usually try to do the right thing, but if I get close to another object, line, face, whatever, it will sometimes "jump away" again. I can usually get it to work after some coaxing, but it often takes more work than I would like, and it can make precise work frustrating. Haven't heard anyone else mention it, so my first thought was lousy video card, but honestly, I know next to nothing about hardware.
              I haven't seen that sort of thing. Would you e-mail the model to me with the same view where you get it? I'll try it and see what happens.
                mrossk
                I will, but unfortunately I'm late to leave my house- I'll do it tonight,Thanks!
                  OK. Later.
                  • BoxB
                    It could be something as simple as having the precision set too large and snap to on, so the endpoint sort of jumps away.
                    • KrisidiousK
                      Krisidious
                      is it an inference line or an axis line? has to be inference with that blue line being where it is. I'm with Box. check your units. make sure they are a nice scale to be working in. like 1/8" or 1/4" for furniture. Dave's our resident furniture builder though, he'd know better what units to use.
                      By: Kristoff Rand
                        mrossk
                        I usually work with the precision to 1/64", after all, this is fine woodworking:). I tried changing it to 1/32 or 1/16, and I don't work with "snap" on. Didn't seem to make a difference either way. Something I didn't think to mention earlier, though perhaps it's related- occasionally when surfing the web, if I change web pages, part of the previous web page will briefly linger on the new web page until I scroll or move on that page. For example, if I'm doing a Google search, when I click on a link, part of the Google Search page (a few lines or a portion of the screen) will linger on the new page. Perhaps it's related?
                        Any help is appreciated...
                        • KrisidiousK
                          Krisidious
                          When we said to check the units it was because it might have been set to something quite large. like 1 foot. those lower units won't make any difference. I'm not familiar with the GT 520. I use two GTX 470's I would suggest a larger video card if that one isn't 1 gig. But have never seen this issue. SO not sure it's a graphic issue.
                          By: Kristoff Rand
                            mrossk
                            Krisidious- Thanks. I'll really show my ignorance here. Which specification is the "1 gig" you refer to? Below are the specifications for this card. Thanks for the help.
                            GPU Engine Specs
                            CUDA Cores
                            48
                            Graphics Clock (MHz)
                            810
                            Processor Clock (MHz)
                            1620
                            Texture Fill Rate (billion/sec)
                            6.5
                            Memory Specs
                            Memory Clock
                            900 MHz (DDR3)
                            Standard Memory Config
                            1024 MB (DDR3)
                            Memory Interface
                            DDR3
                            Memory Interface Width
                            64-bit
                            Memory Bandwidth (GB/sec)
                            14.4
                            Feature Support
                            OpenGL
                            4.2
                            Bus Support
                            PCI-E 2.0 x16
                            Supported Technologies
                            DirectX 11, CUDA, PhysX
                            Display Support
                            Multi Monitor
                            Yes
                            Maximum Digital Resolution
                            2560x1600
                            Maximum VGA Resolution
                            2048x1536
                            Standard Display Connectors
                            Dual Link DVI-I
                            HDMI
                            VGA (optional)
                            HDMI1
                            Yes
                            Standard Graphics Card Dimensions
                            Length 5.7 inches
                            Height 2.7 inches
                            Width Single slot
                            Thermal and Power Specs
                            Maximum GPU Temperature (in C) 102
                            Maximum Graphics Card Power (W) 29 W
                            Minimum System Power Requirement (W) 300 W
                              I think we sorted the problem with the inferencing last night. It appears to be a case of an unresolvable inference. The line's direction is locked in the red direction and the cursor is placed on a face that would never intersect with the line no matter how long the line, not how big the face. This isn't a video card issue but as I told Michael last night, more like a divide-by-zero sort of thing.
                                mrossk
                                I agree Dave, and thanks again. I only asked about the card specs to educate myself, and thought it might help with the other issue I was having; knowing right next to nothing is often problematic when dealing with computers!
                                  No worries, Michael. I just thought we should answer the original question. Ignorance can be bliss but you're right when it comes to computers. πŸ˜‰
                                  • KrisidiousK
                                    Krisidious
                                    Glad you got it figured out. Looks like you do have a 1 gig card.
                                    here's our two cards compared. remember that I have two of them and that mine are like 4-5 years old and pretty outdated. if you have an extra $300 bucks laying around, a GTX 770 would be smokin fast.
                                    Your Card
                                    GPU Engine Specs
                                    CUDA Cores - 48
                                    Graphics Clock (MHz) - 810
                                    Processor Clock (MHz) - 1620
                                    Texture Fill Rate (billion/sec) - 6.5
                                    Memory Specs
                                    Memory Clock - 900 MHz (DDR3)
                                    Standard Memory Config - 1024 MB (DDR3)
                                    Memory Interface - DDR3
                                    Memory Interface Width - 64-bit
                                    Memory Bandwidth (GB/sec) - 14.4
                                    Feature Support
                                    OpenGL - 4.2
                                    Bus Support - PCI-E 2.0 x16
                                    Display Support
                                    Multi Monitor - Yes
                                    Maximum Digital Resolution - 2560x1600
                                    Maximum VGA Resolution - 2048x1536
                                    Dual Link DVI-I
                                    HDMI
                                    VGA (optional)
                                    HDMI1 - Yes
                                    My Card
                                    GPU Engine Specs
                                    CUDA Cores - 448
                                    Graphics Clock (MHz) - 607 MHz
                                    Processor Clock (MHz) - 1215 MHz
                                    Texture Fill Rate (billion/sec) - 34.0
                                    Memory Specs
                                    Memory Clock - 1674 MHz (3348 data rate)
                                    Standard Memory Config - 1280 MB
                                    Memory Interface - GDDR5
                                    320-bit
                                    Memory Bandwidth (GB/sec) - 133.9 GB/sec
                                    Feature Support
                                    OpenGL - 4.2
                                    3D Vision Surround, SLI, DirectX 11, CUDA, 3D Vision, PhysX
                                    SLI Options1
                                    2-way
                                    3-way
                                    Display Support
                                    Multi Monitor - Yes
                                    Two Dual Link DVI
                                    Mini HDMI
                                    HDMI
                                    Yes
                                    By: Kristoff Rand
