    [Plugin] FullScreen v5.1.3 (25 April 2024)
    285 Posts 79 Posters 402.5k Views 80 Watching
      A futur hit! β˜€
        Anton_S
        Update 3.0.2: A bunch of minor fixes and improvements
        • F Offline
          feodos
          • in the new dialog window there is no toolbar Containers
          • the button of the menu isn't active
            Pherim
            Can this simply be updated via the Plugin store? It says in the description that the old version needs to be removed. And what about AMS Library, will this be installed by the Plugin Store, too? I Can't find it in there.
              Anton_S
              I tested coping and pasting the new version over the original version and found that replacing the new plugin over the original one will not affect the plugin, but there will be unused content inside the plugin's folder. Deleting the original version is not required, but you may if you want to be organized. I changed the description back to normal.
              Added it to the plugin store.
              Thanks for suggestions.
                Anton_S
                @feodos said:
                In the new dialog window there is no toolbar Containers
                What do you mean there is not toolbar containers, there is! I removed an option where you could show/hide current toolbar container because not much users use these options anyways. They just show/hide them all at once.
                The menubar can be shown/hidden only when SketchUp is fullscreen! Set SU fullscreen, and then you'll be able to show/hide menubar. Hover the cursor over the menu item, and the description will be displayed in the status bar. It clearly states that the option works with main window set fullscreen only!
                  Anton_S
                  New update 3.0.3
                  • Minor dialog and menu optimizations.
                  • Added the set/remove menubar option back. Press the ALT key to set/remove menu bar.
                  • Requires AMS Library 1.0.2 or later
                    Nice one Anton.
                    • CadFatherC Offline
                      CadFather
                      Thank you for the update Anton - this plugin is fantastic.
                      but...could the ALT be optional (or assignable)? on my machine it conflicts with some native keyboard shortcuts (move, or follow me tool + alt) - of course also other custom ones.
                        Anton_S
                        I will add customizing shortcuts soon.
                        Sorry about the ALT thing πŸ˜†
                          Anton_S
                          Perhaps for now, you can change the shortcut yourself:
                          1. Open ams_WindowsSettings/main.rb
                          2. Scroll down to line 434
                          3. Change 'menu' to 'f12' or whatever key you prefer.
                          4. Save, and restart SU.
                            CadFather
                            Thank You, Master Anton! πŸ˜„ β˜€
                              Anton_S
                              3.5.0 Dec 15, 2013
                              • Added customizable shortcuts, thanks to CadFather.
                              • Added drag, clip, snap dialog.
                              • Added dialog clear borders option.
                              • Changed default set/remove menu shortcut key from ALT to F12.
                                laudhi
                                sketchup always freeze when i make a rectangle and select the face,right click and press R
                                I tried without any other plugin.......
                                (sketchup make,windows 7 x64)
                                btw,thanxz for the plugin..... πŸ˜„
                                  Anton_S
                                  Thank you for the report laudhi.
                                  I found and fixed it. Download the latest version of AMS Library.
                                    laudhi
                                    thanks Anton_S,now everything is running smoothly without any problems with other plugins 😍
                                    i love the floating window....
                                      Anton_S
                                      3.6.0 Jan 29, 2014
                                      • Figured out a way to keep all shortcuts working while the menu bar is removed. The fancy shortcuts sections and the show/hide menu bar option were removed. They are no longer required! πŸ˜„
                                      • Fixed the get screen resolution function in AMS library. Now, it will return the size of all monitors combined. This fixes an issue where the dialog could not be moved to another screen.
                                      • Simplified and improved stuff.
                                        CadFather
                                        Master Anton strikes again - thanks!
                                        • U Offline
                                          unearthed
                                          Thanks for this plugin Anton, it's arguably the number 1 plugin for me as it enables me to quickly clear my screen for online client presentations. The only thing is could the floating black dialog be made smaller?
                                          Growplan - People ∩ Plants ∩ Place
                                          windows 7 64b, 4GB RAM, SU 8.0.16846
                                          Gimp, QGIS, Vectorworks 12, Bricscad 11
                                            Anton_S
                                            Thank you, CadFather!
                                            I'm glad you like it. πŸ˜„ I've been thinking about making another collapsible on top, that would collapse/uncollapse all other collapsibles. Perhaps this feature could be available in the next release. Thanks for suggestion!
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 10 / 15
