    One File Won't Export
    11 Posts 4 Posters 482 Views 4 Watching
    • JBJDesignsJ Offline
      JBJDesigns
      Hi!
      I have a house model built in SketchUp Make (free version) which will not export when I use the extension "OBJexporter." I've been using this extension successfully on many house and furniture objects without incident. At first I suspected long texture/material file names; so I shortened the file names; seems not to be the problem. I also checked texture/material file size, but this too was not the issue. So, I'm stumped!
      A copy of the file can be found here at 3D Warehouse:
      http://sketchup.google.com/3dwarehouse/details?mid=f855a6491f86a806be024c17f1e95abc
      I hope that someone might be able to determine the problem.
      Thanks in advance for your help.
      Jo Ann
      ...you send them to school, you give them books, and they eat the pages...
      • ely862meE Offline
        ely862me
        I used the built in exporter and it worked .
        house.rar
        Elisei (sketchupper)
        Come and See EliseiDesign
          mac1
          the 3 d ware house shows the model as sU8, is that correct?
          I used tigs objectexporter, installed in my su8 but got bug splat 3 different times when I tried to export. I have not used this much at all. will try with make and see what happens
            JBJDesigns
            That's great! But I have the FREE version which does not have a built-in exporter.
              JBJDesigns
              I think that SketchUp Make is also SketchUp 8. I'm having the same problem with "bug splat" when I try to export. The really strange part is that I don't have this problem on any of my other models. Just this one.
                I confirm that the OBJexporter fails [splats] when trying to export this file.
                There's nothing wrong with the file/instance/group/material/texture names so I can't see what's up.
                It gets half way to the end of the OBJ and fails.
                It uses much the same code as my Octane exporter. That works fine !
                πŸ˜•
                  JBJDesigns
                  πŸ˜•
                  Hi TIG! Is your "Octane" exporter available in the plug-in store? Thanks for testing the model.
                  Jo Ann
                    The similar Octane tool is only available to download if you bought a [cheap] beta-license for Octane...
                    However, it is 'almost identical' to the version here... so I am at a loss to see the difference that causes a spat πŸ˜’
                      mac1
                      I deleted all materials in the orginal OP model and it will export then. Maybe that is too trival a case?? Did get the obj and mtl folders
                        JBJDesigns
                        Hi TIG,
                        I don't mind paying for the license. If you had success with your version then perhaps it's an OBJexporter extension issue; the extension has not been updated (could that be an issue?).
                        Appreciate your help!
                        Jo Ann
                          JBJDesigns
                          I was able to export the model, but in pieces. What confounds me about this particular model it uses almost all the same materials I use in other models which I have had no problem exporting with the extension OBJexporter.
                          I do appreciate all the help and suggestions. This is a wonderful community! Thank you.
                          Jo Ann πŸ˜„
