    [Plugin] Import OBJ with Materials v2.1 20131118
    279 Posts 87 Posters 438.8k Views 87 Watching
    • Z Offline
      Zylescozar19
      Hi TIG, this is a AWESOME PLUG-IN!
      But when i try to import this simple cube (see image)
      there is no object that have been imported.
      Thanks.
      • Z Offline
        Zylescozar19
        Hi TIG. this is a AWESOME PLUG-IN!
          What units are you using?
          If the imported object is very tiny geometry can't be created.
          So a number like 0.1 might be very tiny in mm but x1000 using m !
          The radiused edges look very faceted ?
          Try using meters ?
          The imported object might then be enormous, but can be scaled.
          Can you attach the OBJ/MTL to a post or a PM ?
          • Z Offline
            Zylescozar19
            I did try all of the units.
            Ok ill send you the copy of obj. file.
            BTW im using WINDOWS 7 ULTIMATE - 32 BIT
            Thanks TIG! 😛
              OK
              I now have your ZIP file by PM for this OBJ.
              I note that there are no materials specified in the OBJ, by referencing an associated MTL file ?
              Also the 'object' seems to have some tiny facets.
              I think it was exported in 'mm' - but there's no units info in the header !
              It does now import OK in 'mm'.
              There are 68,000 lines of code in the OBJ file - which seems a lot for such a simple thing !
              BUT... you have discovered a typo in my script's code.
              This typo causes a failure - with a message in Ruby Console - but only when a particular rare combination of definitions in the OBJ file occur - that is when there are negative [-ve] values for 'f' face vertices specification: most OBJ's make +ve values to count the vertices when referring to v/vt/vn down the list etc... but -ve ones are allowed to count up the list... and my code did try to trap for that possibility... however, with certain combos of v/vt/vn it does fail because of this typo with the 'vn' counter...
              However, your OBJ file's format is odder still in that it makes 26 subgroups [one for each external cube] and it restarts the vertex negative count back up the file for each subgroup it defines, rather than counting through the the whole file - making it awkward to 'reverse-engineer' it to the more normal [logical] downward count which always runs from the top and is always ignoring any subgroups - so '1' is always the very first vertex defined and any grouping is ignored - but it is trappable...
              Also I note that many faces are 'reversed' in this OBJ's code.
              These need fixing manually...
              Frankly you could more easily make and assemble these cubes in SketchUp - there are only 3 variants for corners, centrally and mid-side, with 3d rotation etc and suitable face coloring [which is entirely missing from this OBJ anyway]...
              However, you reported issue has made me make the script work better for these -ve values 😉
              I have fixed the script and an update will be published shortly... 🤓
                There is an update available: http://sketchucation.com/forums/viewtopic.php?p=172790#p172790
                or http://sketchucation.com/resources/pluginstore?pln=obj_importer
                Previously unpublished:
                v2.0 20130321 'Blender-quads' now import as two tri-facets. The OBJ file must contain header-text "# Blender" or similar.
                Recently fixed:
                v2.1 20131118 Import of OBJ files using a -ve counter for 'f' vertices within sub-groups fixed. View now refreshes with each group completion.
                  Mill29
                  Thanks for your job, really apreciate.
                  there is something i missunderstood.
                  1/ I open a .vray.mat in 3DS
                  2/ I export in obj format, wih mat as you can see on the picture.
                  http://img600.imageshack.us/img600/38/jmqm.jpg
                  3/ i put in the export folder, the map furnished with the .vray.max.
                  4/ i import in SU using your plugin, i choose cm
                  The problem is i don't have any mat with the model.
                  Could you help me?
                    When you make a .OBJ file it should also make a similarly named .MTL file which defines the materials.
                    These materials are referenced in the header of the OBJ and can be plain colors with optional transparency or with mapped textures.
                    The textures are defined with a reference to an imgae file.
                    Most OBJ exporters put these in a folder - named something like Textures or OBJName_Textures...
                    The normal rule is that the OBJ and MTL files go in a common folder - the OBJ's code typically looks for the MTL file 'by name only' [with no 'path'] and therefore expects it to be in the same folder as the OBJ... The 'Texture' folder goes in the same folder as the OBJ and MTL because the MTL's code looks for "Textures/ImageName.png" etc.
                    If the OBJ can find the MTL then no materials are made/used.
                    If the MTL can't find an image file then the a plain-color is used instead.
                    You can read an OBj or MTL file with a plain-text-editor...
                    So see what the OBJ and MTL files are expecting and ensure that you keep all of the exported parts together: that is - the matching OBJ + MTL + ImageFilesInsideTextureFolder
                      chandlerplusbass
                      For some reason the file will not show the textures. I checked the .mtl and everything seems fine, and the textures are where they need to be. But when I import the file, all the textures are replaced with a matte grey. Is there anyway I can get this to show the textures? It's working fine in blender but not SketchUp.
                        Without seeing the files who can say ? 😒
                        Are the faces made 'inside out' ?
                        So you are seeing their backsides ?
                        Are you importing 'with textures' - there are different options...
                        Can you ZIP and attach or PM+attach the files 😕
                        • X Offline
                          XAIR134
                          Some textures are not loading, the model had 26,000 lines though. Is that usual?
                            Who knows? 😒
                            What's the object?
                            What are the Textures? 😮
                            Are ALL Texture files listed in the MTL sub-file also in the Textures sub-folder ? 😲
                            If it's a manageable size when made into a ZIP can you attach it to a post or PM it ?... ☀
                            It might be an issue with the files themselves rather than the plugin ???
                              Janice
                              I am using Sketchup 2013 and installed obj_importer_v2.2.rbz. I am trying to import a .obj file in to Sketchup.
                              I installed by going to Window > Preferences and then clicking Extensions. The Extensions panel is displayed and then I clicked the Install Extension button.
                              Then I restarted sketchup.
                              Then I select import and the file format for obj still doesn't appear.
                              I was hoping you might now what I am doing wrong. Should I be importing a different way?
                              Thanks in advance.
                                This tool is NOT an importer that is listed under the File menu...
                                That would need a special kind of coding...
                                This tool makes its entries in the Plugins menu...
                                  komeyl
                                  @chris fullmer said:
                                  And thanks!
                                  how to import materials obj?
                                    And thanks!
                                    Help us to help you... 😕 You question is useless 😞
                                    Let's assume you have the plugin's RB file correctly installed in the Plugins folder and you have restarted SketchUp...
                                    And also that you have an OBJ file, and it related MTL file defining materials - this must be kept with the OBJ file.
                                    If there are textures specified they come as image-files inside a subfolder that is kept with the MTL file [its exact name varies - open the MTL in notepad to see the expected folder-name/relative-path...]
                                    Run the Import OBJ tool from its Plugins menu item [I assume you'll want 'with Textures'].
                                    Answer the dialog prompts [if you don't know the original units accept the default 'inches'], then wait as it is processed.
                                    Answer the prompt at the end - you will probably want to flip the imported geometry upright.
                                    You should now have the imported object using the specified materials and textures.
                                    To see progress watch the status bar.
                                    If you have the Ruby Console open rare error-message might appear...
                                    If the geometry is exceptionally tiny and arrives with 'holes', then try reimporting it as 'meters' [scaling down to the real size later] - that way you'll avoid the known tolerance issues, where very tiny edges are not created by SketchUp when it considers their ends 'coincident' [~/1000"], then the related face is lost because it has a gap in its edge-loop - tiny geometry can 'exist' [say after scaling down] but it can't be 'created'.
                                    Should you need further help, please come back and ask concisely and clearly, ...
                                    • bagateloB Offline
                                      bagatelo
                                      The inverse option, for export obj files from SU is possible?
                                      Thanks anyway....
                                        sketchorro
                                        Let me start by saying thanks for this plugin, it's great.
                                        I've started using it to import models from Structure Sensor.
                                        I decided to do a little hacking to make my life easier; basically setting the units to default to metres and taking a look at how to bulk import mesh models (todo). I also discovered that when the models were loading in the background/covered by another window, they loaded much faster (I'm on OSX/'14 Make).
                                        The reason for this is because the UI is getting hammered with several tens/hundreds of thousands of repaints (1 per obj file line) to updated the status bar from this:
                                        	 Sketchup.set_status_text("Processing line #{line_cnt} of #{lines.length}")
                                        I took a crack at fixing this by making the status line update on a change in percentage. I obviously screwed it up not being a ruby coder, but in the process discovered my 40K+ line (991kb) models loaded in about 2 seconds.
                                        It still slows down when you get really big models; I have a 13.2MB file that starts to grind after about 90%, but I suspect this is a memory/swap bottleneck.
                                        Anyway, I fixed my update code and it looks like this:
                                        Initialize the percentage variables before the looping starts
                                         old_percentage=-1
                                         new_percentage=0
                                         ### trap in case of a missing 'g'
                                         lines=["g OBJ\n"]+lines
                                        Update the status and force sketchup to repaint once per percentage point.
                                         # Sketchup.set_status_text("Processing line #{line_cnt} of #{lines.length}")
                                         new_percentage = ((line_cnt * 100.0)/lines.length).round;
                                         if old_percentage != new_percentage
                                           Sketchup.set_status_text("Importing Model - #{new_percentage}% (#{line_cnt} of #{lines.length})")
                                         end#if
                                         old_percentage = new_percentage
                                        Probably something that would help others enjoy this plugin a little more.
                                        -G
                                        • E Offline
                                          enuminous
                                          I've just installed Import OBJ with Materials 2.1 and am running into the same problem, with materials being replaced with white/grey. I'm exporting from Poser, and the .obj and .mtl files are in a folder, with a Textures subfolder containing the generated PNG files. I've also tried it with the PNG materials in the same folder at the .obj and .mtl files. Neither works. I'm running Sketchup2015 64 in Yosemite on a 5K Retina iMac if that helps. Any suggestions?
                                            storm2000
                                            Same for me here, on SketchUp 2014 on Windows, OBJ + MTL textures. All textures are gray. Any solution to make it working welcome 😃
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 11 / 14
