    [Plugin] Import OBJ with Materials v2.1 20131118
    279 Posts 87 Posters 413.8k Views 87 Watching
      My FixTreeD.rb is in this post: http://sketchucation.com/forums/viewtopic.php?p=306529#p306529
        jackwatson
        Hi there,
        I'm having trouble getting the materials to import with the model. The mtl file is in the same folder as the obj file, but it seems to replace the materials with random colours. I did tests with free models, but they're from designconnected which seems like a reputable site so I'm not sure what's stopping the import correctly. This is the chest which is supposed to be wood/iron.
        Any ideas what might be causing this?
        Regards
        Jack
          Without seeing the relevant OBJ and MTL how could I say ๐Ÿ˜’
          Can you ZIP them and attach them to a post or PM them ?
          It's likely something wrong with the MTL etc - both files are human-readable so you should be able to see issues ?
          ๐Ÿ˜•
          • Z Offline
            Zylescozar19
            Hi TIG, this is a AWESOME PLUG-IN!
            But when i try to import this simple cube (see image)
            there is no object that have been imported.
            Thanks.
            • Z Offline
              Zylescozar19
              Hi TIG. this is a AWESOME PLUG-IN!
                What units are you using?
                If the imported object is very tiny geometry can't be created.
                So a number like 0.1 might be very tiny in mm but x1000 using m !
                The radiused edges look very faceted ?
                Try using meters ?
                The imported object might then be enormous, but can be scaled.
                Can you attach the OBJ/MTL to a post or a PM ?
                • Z Offline
                  Zylescozar19
                  I did try all of the units.
                  Ok ill send you the copy of obj. file.
                  BTW im using WINDOWS 7 ULTIMATE - 32 BIT
                  Thanks TIG! ๐Ÿ˜›
                    OK
                    I now have your ZIP file by PM for this OBJ.
                    I note that there are no materials specified in the OBJ, by referencing an associated MTL file ?
                    Also the 'object' seems to have some tiny facets.
                    I think it was exported in 'mm' - but there's no units info in the header !
                    It does now import OK in 'mm'.
                    There are 68,000 lines of code in the OBJ file - which seems a lot for such a simple thing !
                    BUT... you have discovered a typo in my script's code.
                    This typo causes a failure - with a message in Ruby Console - but only when a particular rare combination of definitions in the OBJ file occur - that is when there are negative [-ve] values for 'f' face vertices specification: most OBJ's make +ve values to count the vertices when referring to v/vt/vn down the list etc... but -ve ones are allowed to count up the list... and my code did try to trap for that possibility... however, with certain combos of v/vt/vn it does fail because of this typo with the 'vn' counter...
                    However, your OBJ file's format is odder still in that it makes 26 subgroups [one for each external cube] and it restarts the vertex negative count back up the file for each subgroup it defines, rather than counting through the the whole file - making it awkward to 'reverse-engineer' it to the more normal [logical] downward count which always runs from the top and is always ignoring any subgroups - so '1' is always the very first vertex defined and any grouping is ignored - but it is trappable...
                    Also I note that many faces are 'reversed' in this OBJ's code.
                    These need fixing manually...
                    Frankly you could more easily make and assemble these cubes in SketchUp - there are only 3 variants for corners, centrally and mid-side, with 3d rotation etc and suitable face coloring [which is entirely missing from this OBJ anyway]...
                    However, you reported issue has made me make the script work better for these -ve values ๐Ÿ˜‰
                    I have fixed the script and an update will be published shortly... ๐Ÿค“
                      There is an update available: http://sketchucation.com/forums/viewtopic.php?p=172790#p172790
                      or http://sketchucation.com/resources/pluginstore?pln=obj_importer
                      Previously unpublished:
                      v2.0 20130321 'Blender-quads' now import as two tri-facets. The OBJ file must contain header-text "# Blender" or similar.
                      Recently fixed:
                      v2.1 20131118 Import of OBJ files using a -ve counter for 'f' vertices within sub-groups fixed. View now refreshes with each group completion.
                        Mill29
                        Thanks for your job, really apreciate.
                        there is something i missunderstood.
                        1/ I open a .vray.mat in 3DS
                        2/ I export in obj format, wih mat as you can see on the picture.
                        http://img600.imageshack.us/img600/38/jmqm.jpg
                        3/ i put in the export folder, the map furnished with the .vray.max.
                        4/ i import in SU using your plugin, i choose cm
                        The problem is i don't have any mat with the model.
                        Could you help me?
                          When you make a .OBJ file it should also make a similarly named .MTL file which defines the materials.
                          These materials are referenced in the header of the OBJ and can be plain colors with optional transparency or with mapped textures.
                          The textures are defined with a reference to an imgae file.
                          Most OBJ exporters put these in a folder - named something like Textures or OBJName_Textures...
                          The normal rule is that the OBJ and MTL files go in a common folder - the OBJ's code typically looks for the MTL file 'by name only' [with no 'path'] and therefore expects it to be in the same folder as the OBJ... The 'Texture' folder goes in the same folder as the OBJ and MTL because the MTL's code looks for "Textures/ImageName.png" etc.
                          If the OBJ can find the MTL then no materials are made/used.
                          If the MTL can't find an image file then the a plain-color is used instead.
                          You can read an OBj or MTL file with a plain-text-editor...
                          So see what the OBJ and MTL files are expecting and ensure that you keep all of the exported parts together: that is - the matching OBJ + MTL + ImageFilesInsideTextureFolder
                            chandlerplusbass
                            For some reason the file will not show the textures. I checked the .mtl and everything seems fine, and the textures are where they need to be. But when I import the file, all the textures are replaced with a matte grey. Is there anyway I can get this to show the textures? It's working fine in blender but not SketchUp.
                              Without seeing the files who can say ? ๐Ÿ˜’
                              Are the faces made 'inside out' ?
                              So you are seeing their backsides ?
                              Are you importing 'with textures' - there are different options...
                              Can you ZIP and attach or PM+attach the files ๐Ÿ˜•
                              • X Offline
                                XAIR134
                                Some textures are not loading, the model had 26,000 lines though. Is that usual?
                                  Who knows? ๐Ÿ˜’
                                  What's the object?
                                  What are the Textures? ๐Ÿ˜ฎ
                                  Are ALL Texture files listed in the MTL sub-file also in the Textures sub-folder ? ๐Ÿ˜ฒ
                                  If it's a manageable size when made into a ZIP can you attach it to a post or PM it ?... โ˜€
                                  It might be an issue with the files themselves rather than the plugin ???
                                    Janice
                                    I am using Sketchup 2013 and installed obj_importer_v2.2.rbz. I am trying to import a .obj file in to Sketchup.
                                    I installed by going to Window > Preferences and then clicking Extensions. The Extensions panel is displayed and then I clicked the Install Extension button.
                                    Then I restarted sketchup.
                                    Then I select import and the file format for obj still doesn't appear.
                                    I was hoping you might now what I am doing wrong. Should I be importing a different way?
                                    Thanks in advance.
                                      This tool is NOT an importer that is listed under the File menu...
                                      That would need a special kind of coding...
                                      This tool makes its entries in the Plugins menu...
                                        komeyl
                                        @chris fullmer said:
                                        And thanks!
                                        how to import materials obj?
                                          And thanks!
                                          Help us to help you... ๐Ÿ˜• You question is useless ๐Ÿ˜ž
                                          Let's assume you have the plugin's RB file correctly installed in the Plugins folder and you have restarted SketchUp...
                                          And also that you have an OBJ file, and it related MTL file defining materials - this must be kept with the OBJ file.
                                          If there are textures specified they come as image-files inside a subfolder that is kept with the MTL file [its exact name varies - open the MTL in notepad to see the expected folder-name/relative-path...]
                                          Run the Import OBJ tool from its Plugins menu item [I assume you'll want 'with Textures'].
                                          Answer the dialog prompts [if you don't know the original units accept the default 'inches'], then wait as it is processed.
                                          Answer the prompt at the end - you will probably want to flip the imported geometry upright.
                                          You should now have the imported object using the specified materials and textures.
                                          To see progress watch the status bar.
                                          If you have the Ruby Console open rare error-message might appear...
                                          If the geometry is exceptionally tiny and arrives with 'holes', then try reimporting it as 'meters' [scaling down to the real size later] - that way you'll avoid the known tolerance issues, where very tiny edges are not created by SketchUp when it considers their ends 'coincident' [~/1000"], then the related face is lost because it has a gap in its edge-loop - tiny geometry can 'exist' [say after scaling down] but it can't be 'created'.
                                          Should you need further help, please come back and ask concisely and clearly, ...
                                          • bagateloB Offline
                                            bagatelo
                                            The inverse option, for export obj files from SU is possible?
                                            Thanks anyway....
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 11 / 14
