    [Plugin] 2D Tools
    791 Posts 178 Posters 807.4k Views 177 Watching
    • G
      ghostanywhere
      Hello, I can't find the zip version for download, pls help
      • cottyC
        cotty
        In the first post you will find a link to the plugin store where you can download the rbz-file. If you need a zip-file, you can rename it to zip-ending, but it is recommended to use the extension installation button or even better the sketchucation tools for installation.
        my SketchUp gallery
        • P
          pohlovec
          about 2D Fillet Tool
          I would like to change the default count of segment from 18 to 6.
          Can I somehow modify the file 2DfilletTool.rb?
          I tried it, but without result.
          Is there any option???
          Thx
            You change the setting when activating the tool - by typing 6s [+<enter>] - as well as then say 100 [+<enter>] for the radius... then both of those settings are remembered with the model on a save, and reused across sessions.
            IF you want to change the script's coding...
            Use a plain-text editor - say Notepad/Notepad++ or TextWrangler[for MAC] - never a wordprocessor!
            Edit the file: ../Plugins/2DTools/2DfilletTool.rb
            Then find the following two lines: #70
            @segs=**18** if not @segs
            which becomes: @segs=**6** if not @segs
            and then #89
            @segs=Sketchup.active_model.get_attribute("2Dtools","fillet_segments",**18**)
            which becomes: @segs=Sketchup.active_model.get_attribute("2Dtools","fillet_segments",**6**)
            [TIP: If your text-editor has no line-numbering then you can search/find for the two occurrences of " @segs="...]
            Now when opening a brand new model the default 2DfilletTool's segmentation is always 6s - although of course you can reset it to say 18s or whatever you desire on a per model basis. by typing the new value into the VCB, such settings are remembered with each model on save - here as the attribute 2Dtools : fillet_segments...
            πŸ€“
            • robertWanR
              robertWan
              How to avoid this error? After the fillet lines are not parallel.
              2D Fillet
              Robert
              2DFillet.skp
                @RobertWan
                I think this is down to tiny geometry again.
                SketchUp tolerance is ~1/1000"
                3mm is approaching that for the tiny facet sizes and their end points being considered equivalent...
                When the fillet tool rounds a corner like that there should be no residual lines anyway!
                The faceted arc has a first/last section at such a shallow angle to the side that the point is confused.
                If you delete the two edges and redraw them, being sure to snap to the ends of the fillet-arc, then they will be 3mm long and dimension correctly.
                See the zoomed view attached...
                  jzar_kobi
                  Having trouble with the textures....just don't fill. I've picked the texture from the scene and used the bucket tool....worked that way but not from the 2d hatching tool. The 2d line tool....love it. It did jump it's xyz position when it when over a 3D object. Moved in the positive z direction to float above the cube. I'll post some of my experiments if you'd like them.
                  • T
                    trackbuilder
                    I am new to installing Plugins for SU, so I downloaded the Plugin from SketchUcation and it installed correctly. I downloaded the 2D Tools plugin from TIG and it appeared to load properly. However, once it was installed, this message came up...
                    Permission denied - C:/Program Files/SketchUp/SketchUp 2013/Plugins/2Dtools/2Dtidied.txt
                    Error Loading File 2D#.rb
                    Is this a setting conflict with my PC or what? Please help...
                    I've installed SU Pro v 2013, on OS Windows 7
                      Actually, you didn't quite get it installed correctly. Before installing it you need to go in to the Security setting for the Plugins folder and set permissions for your log in to All so there's full access. Do that and reinstall it. Best would be to install the SCF Plugin Store and automatically install other plugins from there.
                      • jim smithJ
                        jim smith
                        I was receiving the same message as trackbuilder on just some of the plugins and only on su 2013. My SU8 never had the problem. I redid the security setting as suggested and can now load more plugins. 2D is a favorite, now I can start to migrate with confidence, but hanging on to 8 for a while..... Thanks for the clue Dave!
                        "Out of clutter find simplicity,
                        from discord find harmony,
                        In the middle of difficulty lies opportunity"
                        Albert Einstein
                          Hi Jim,
                          I'm glad that helped. Some plugins need to be able to write to a file for changes you might make in the VCB or a window that opens. The files generally end up in the Plugins folder so having privileges will be important.
                            That temp file is a throwback.
                            I'll remove it and update.
                            It's there to record if ye olde format of the 2dTools installation has already been tidied up...
                            However, you do need to ensure FULL permissions to your Plugins folder as several tools do still write temporary files there...
                            • T
                              trackbuilder
                              TIG, Dave and Jim,
                              Thank you for all of your help!!!!! I adjusted the security settings, and found the 2D Tools plug-in in the Draw menu.
                              • Clayton49C
                                Clayton49
                                Help to anyone,
                                This tool will be a life saver, however for some reason it won't let me install it. I get an the error message below:-
                                Permission denied - C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/2Dtools/2Dtidied.txt
                                Not had anything like this before on any extensions, what gives with this extension...
                                I wish this extension was available through SketchUP's own Extension Warehouse, I might get it loaded that way.
                                Not too sure if this is related to the SKETCHUCATION PLUGIN STORE V2.0 as having some problems with that as well...
                                When I click on the blue icon (SKETCHUCATION PLUGINS MANAGER) I get error message saying "no security permission to manage any plugins folder in the $LOAD_PATH. FULL Read/write Permissions are needed to manage Plugins within this Plugins Folders.."
                                Just not my day I guess.. 😞
                                Any help will be most appreciated.
                                Over & out,
                                Clayton.
                                Over & out,
                                Clayton.
                                %(#008000)[Trotman & Taylor
                                Architectural Consultants]
                                  This has been covered a number of times here. In fact, just five posts above. You need to set the permissions for the Plugins folder so you have full administrative rights under your log in. Go to the Plugins folder, right click on it and choose Properties. Then click on the Security tab and the Edit button. Select your log in and tick all of the boxes for "Allow." Then OK and close out of that. Reinstall the plugin and it should work fine.
                                    Somehow the issue that was meant to be resolved with v5.6 messed up in the recent upload.
                                    The latest v5.7 [hopefully] avoids this 'temp-file-in-plugins-folder' issue all together...
                                    http://sketchucation.com/resources/pluginstore?pln=2Dtools
                                    BUTthis does not sidestep the issue that you MUST have FULL security permissions to your Plugins folder both to AutoInstall Plugins from the PluginStore... AND subsequently 'manage' them... πŸ˜’
                                      Here's a future-proofed update.
                                      http://sketchucation.com/forums/viewtopic.php?p=185760#p185760
                                      • OxerO
                                        Oxer
                                        Thanks TIG for the update, the v5.9 works fine on Mac OSX 10.9 & SU2013 but a minor problem, the icons of the tools cursor don't show.
                                          I confirm that I too get no custom-cursors with the MAC version [PC is still fine!] - there are no error messages...
                                          I'm investigating... πŸ˜•
                                          Any advice from others who've seen this kind of thing would be appreciated... πŸ˜’
                                            I just installed 2D Tools on my Mac again from the Plugin Store. the tools show just fine on the toolbar for me.
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 39
                                            • 40
                                            • 30 / 40
