    Sketchup Make 2013/ Mac Lion Constantly Crashing!
    20 Posts 5 Posters 5.1k Views 5 Watching
      Try disabling Podium and see if you have different results.
        mwm5053
        So what kind of Mac are you using Mac Pro, laptop?
        2011 iMac
        SU 2015 Pro, 2017 Make
        V2 Twilight
        macOS Sierra 10.12.5
          Anja
          I'm having the same problem with Sketchup 8 and OS X Mavericks. Sketchup is constantly crashing. Impossible working like that. I'm saving the drawings every minute. Just not possible. 😠 Does anyone have the same problem. Is there a solution to this problem?
          Many thanks
            Anja, maybe you ought to update to SU2013.
              mwm5053
              These problems are not SU 2013 or SU 8 on Lion or Mavericks as I have had no problems with crashes on either one. It could be the model itself (try doing a basic model and see what happens) I really believe they are machine problems i.e graphics card or check "Verify disk permission in Disk utility.If your not sure how to do that post a response.
              2011 iMac
              V2 Twilight
                Anja
                Dave. A didn't update to 2013 het because I do not like the graphics of the buttons 😄. But if I have to I will do it. mwm5053. I don't think so but I'll try it. I'll keep you posted. Thanks Anja
                • E
                  eppyart
                  Dave R - I was thinking of disabling Podium to see if that would help but I am unsure how to do this >< However I dunno if it will help. I have already reinstalled it along with sketch up and it was installed when sketch up was working fine just a month or so ago :S
                  mwm5053 - Using a Mac Desktop computer, not sure if it's an iMac it's just a regular Mac I think... 😕 I kinda have no idea about Mac models or the order of its OS I'm afraid :S Just have to use one as it's what we use where I am. I've asked my manager and he says that the Mac is using the graphics card it has come with so I'm unsure if this could be causing the problem or not. Initially I was fine for making simple or complex models but it's crashing so much that even creating a new file, about less than a few minutes in to making any models, it will usually crash 😞
                  Anja - Sounds like what I'm having but I am using SU Make 2013…it's impossible to work with 😞
                  Thanks for everyones replies so far, hope I can get to the bottom of this and if I do, that it will help anyone else having a similar problem
                  • E
                    eppyart
                    I am still however a little confused about the Mac's OS. I'm aware that this is apparently a Mountain Lion OS but when I click on the name of the Mac (top left corner) in the round circle it is DEFINITELY a picture of a regular lion roaring…is this right?
                    I've also had a look to see what the LATEST version of Mac is and it's called Mavericks. Bit confused as the app store on here says there are no updates yet this came out a few months ago? Is there a possibility downloading this version will fix the problem?
                      Rachel, I expect the thing you are seeing is that there are no updates available for your current OSX, not that there aren't newer operating systems. This will happen with SketchUp, too, when SU2014 comes out. If you check for updates of SU2013 you'll find there are none listed. That's a common thing.
                      To disable the Podium plugin, you can go to the Plugins folder and rename the .rb file. Right click on the file name and choose Get Info. There you can rename it to .rb! Add the exclamation mark and SketchUp won't load it.
                      I would suggest you install the SCF Plugin Store tool because you could disable the plugin from there but if you can't keep SU2013 open long enough to do anything, you might not be able to do that either.
                        slbaumgartner
                        What you write confuses me a bit...you see the name of the Mac at the top left corner? Presumably you mean in the main menu bar? What I see there is an Apple logo. I don't know how to change that to the computer's name, but it sounds like someone clever may have been fiddling with this machine, and that may be related to your problems - who knows what else they did?
                        If you click this logo, the menu should have an item "About this Mac". When you click that, you should get a dialog with summary info about the system, including the OS X version, the processor, memory, and startup disk. There is a button labeled "More info...". If you click this, you will get a window with more details including the specific model of your Mac, the graphics card, and more. There are tabs for other system details, but it seems likely they are not relevant to your SU crashes. If you post an image of this window it might help us to understand what you have got.
                        Does the Processor show an Intel, or something else? If the Mac is old, it may be the pre-Intel CPU, and that could tie in with why you are seeing these errors but those of us with newer machines are not.
                        If you are seeing a roaring African lion instead of a somewhat sly-looking mountain lion, but these dialogs show OS X 10.8.x, something is messed up in your operating system installation! Lion was 10.7.x! I don't know whether that is causing your SU crashes, but the Mac is confused! Again, maybe someone clever was using it before you and fiddled with things?
                        It would be worth doing a reinstall of the OS or upgrading to 10.9 to see if that helps. To do an upgrade, you have to log onto the Apple store and download the new OS from there (it is free). "Software updates" are only for minor version numbers of the same release - e.g. for 10.8.4 to 10.8.5. If you see nothing on software update, it just means you are on the latest minor version within your major version.
                          mwm5053
                          Click on the apple logo to get about this Mac and more info to tell you what kind of Mac you have.
                          2011 iMac
                          V2 Twilight
                          • E
                            eppyart
                            Well, this is a bit embarrassing as I meant to say right hand not top left corner >< However it does still sound like there is something wrong. Here are the details I get from the apple icon:
                            imac 2009
                            Processor 3.06 GHz Intel Core 2 Duo
                            Memory 4 GB 1067 MHz DDR3
                            Graphics NVIDIA GeForce GT 130 512 MB
                            Serial Number VM9319V8250
                            Software OS X 10.8.5 (12F45)
                            I am wondering if it is the graphics card, as when I've been working on other sketch up files that have a lower quality texture image mapped to them, it does run better and crashes a lot less often. Could this be the culprit?
                            I haven't updated it to the Mavericks OS yet as I am unsure if it will run on here or make things better/worse :S
                            I have also encountered another problem since reinstalling Sketchup Make 2013 and the SU Podium plugin, although the settings have and always have been on default for me, it is now rendering the files REALLY bright/over exposed. Yet if I drag the model into a new file and render it, with the same settings, it comes out how it should!
                            Gotta love technology 😄 Start getting to the bottom of something, then find another problem D:!
                              slbaumgartner
                              Aha! Yes, it is reasonably easy to cause a string to appear at the right hand end of the menu bar. It's an option on the login settings. Also, your system definitely indicates Mountain Lion (10.8.5). Nothing seems excessively obsolete on your reported hardware, so it seems likely to me that you are right: the issue is with Podium not liking your graphics card or perhaps simply needing more hardware resources for a model as complex as you are trying to render. I am not a Podium user, so I can't offer any insight about that but perhaps another sketchUcation member will chime in...
