    [Plugin] Layers Panel 1.2.1
    672 Posts 109 Posters 202.1k Views 109 Watching
      db11
      @jiminy-billy-bob said:
      FYI, TT is currently helping me porting the plugin on OSX. Cheers to him ! πŸ˜„
      Been patiently waiting for a functioning OSX version of this must-have plugin, so this is the best news I've heard in a long time!
      Any idea on the ETA?
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        @nanolin said:
        Hello
        You can sort the list by alphabetical order of layers? . It can be added as an option?
        thanks
        Someone (maybe you ?) already suggested this. So it's on my todo list πŸ˜‰
        Nope. In the meantime, you guys can help by filling the issue tracker on the github projet : https://github.com/jiminy-billy-bob/Layers-Panel/issues?state=open
          jiminy-billy-bob
          Hey guys, I've added a poll at the top of the topic.
          Choose what render engine you would like to be supported by Layers Panel.
          I don't garanty that I can make it work with every engine, but it some cases it can be done by the engine's dev (Like Tomasz is supposed to be doing with Thea πŸ˜„ ). So if an engine gets lots of vote and it has to be done by the dev, I can communicate them that there is high demand.
            jiminy-billy-bob
            It's here guys ! πŸ˜„
            New version 0.9 beta !
            Changelog :
            • OSX support
            • Fixed clicking on layer's name not selecting it
            Download in the plugin store !
            A huge thanks to TT for the OSX support ! πŸ‘ πŸ‘
            It's the first OSX version, so it still has bugs. We need you to find them πŸ˜‰
            • tt_suT Offline
              tt_su
              A couple known bugs:
              • "Add Group" doesn't work the first time you click it.
              • Unfolding the window doesn't work correct. Instead of unfolding it expands a little in the width.
              • Bob JamesB Offline
                Bob James
                After loading the latest version I still get this upon opening a model.
                • H Offline
                  huckrorick
                  Is there a way to tell within Sketchup which version I am using?
                  • tt_suT Offline
                    tt_su
                    Any model_ Or a specific model?
                      jiminy-billy-bob
                      "Still", you mean you had this issue before 0.9 ?
                      Does it happen everytime ? Only when opening a model, not when opening the dialog ?
                      Window > Preferences > Extensions > click on Layers Panel. You'll get the version at the bottom.
                        Bob James
                        Any model
                        Yes. And when I change the condition or existence of layers in SU Layers it does not "track" into Layers Panel.
                        Yes. On two different computers: home and work (Win7)
                        β€’It also pops up when using Ctrl-Z to restore a Ctrl-X.
                        β€’It also still disrupts the layers associated with a scene: if I change the layer combination in a scene and the go back to a different scene the layers in that previous scene have been lost. When I disable Layers Panel the problem goes away (repeatable experience over many models and both machines)
                        • tt_suT Offline
                          tt_su
                          What IE version do you have installed?
                            jiminy-billy-bob
                            Did you try to delete everything related to Layers Panel in your plugins folder, and perform a clean install ?
                            About the scene issue, did you check that the auto-update option is disabled ?
                              Bob James
                              Also the Ctrl-X/Ctrl-Z dialog box has a different Char:59 instead of 65
                              By the way: closing and opening Layer Panel gives the Char:59 version of the error.
                                Bob James
                                Yes, and the error pops up during the installation!
                                It was enabled. I disabled it, closed and reopened SU and the scenes are saved (hooray), but I get the Char:59 error each time I switch scenes. By the way, I have to click "Yes" and then the dialog box comes up again and I have to click "Yes" a second time.
                                  jiminy-billy-bob
                                  So, the error pops up even when the dialog is closed ?
                                    Bob James
                                    No. I have it set to open when SU starts. But it "errors" when I turn it off and then on again.
                                    From previous post: Disabling the auto-update option seems counter-intuitive. What does "auto-update" do?
                                      jiminy-billy-bob
                                      It auto-updates the layer state of the current scene.
                                      If you turn on or off a layer, it's saved in the scene.
                                        jiminy-billy-bob
                                        Can you try with all the other plugins disabled ?
                                        • wind-borneW Offline
                                          wind-borne
                                          Changelog :
                                          • OSX support
                                          Glad to join in.
                                          Enjoying the ability to group, merge and rearrange β˜€
                                          Problem:
                                          The options panel doesn't work for me.
                                          None of the changes take effect.
                                          Shown, reopening options(right) after setting(left).
                                          Tried reinstalling and tested on 2013 also, same no go.
                                          Annoyance:
                                          Upon closing, Save dialog appears even if no changes made on file with this extension enabled.
                                          For those of us using shortcuts or main toolbar, having floating toolbar automatically load. Deleted that line for now.
                                          Suggestion:
                                          You might want to enlarge icon for use in main toolbar, barely discernible as shown on top shot.
                                          OSX 10.9, Safari 7.0, SU 8
                                          Good luck and thanks again...
                                          "To read between the lines was easier than to follow the text."OSX 10.11.6
                                          %(#BF80BF)[SU 8 pro
                                            jiminy-billy-bob
                                            Thanks for your feedback ! πŸ˜‰
                                            @wind-borne said:
                                            Annoyance:
                                            I have to initialize some stuff, so there is no real workaround for the save dialog.
                                            As for the toolbar, can't you just hide it in the toolbars options ?
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 33
                                            • 34
                                            • 23 / 34
