    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 368.9k Views 110 Watching
    • bagateloB
      bagatelo
      Can you reply the features of this plugin for 3dsmax to sketchup?
      http://www.scriptspot.com/3ds-max/scripts/theonion
      • jiminy-billy-bobJ
        jiminy-billy-bob
        What features exactly ? LP already allows to group and merge layers.
        What do "Alternate Material", "Alternate Property", "Import of REZN8 LayerManager Information" exactly ?
        • ElibjrE
          Elibjr
          Wow, this plugin is really coming along! When you add the color functionality to the plugin. I will be able to use it exclusively. See as a developer and designer of buildings where renovation is the norm. Having a colored layer for existing work and a second color for work to be removed as well as a new work layer color is critical in developing the scope of a project long before you figure out materials. Thanks for the good work. The great aspect of your plugin would be to start off with the default color and only color the needed layers, but then anything put into that layer would have that color. This is a great checking system to make sure what you have created is in the correct layer. Thanks for your great work.
          • jiminy-billy-bobJ
            jiminy-billy-bob
            Unfortunatly, I won't be able to add layer colors until the API is updated. There are some workaround, but they're just so heavy, I don't think that would be usable...
            In the meantime, layer colors still work in the default layers window.
            • jiminy-billy-bobJ
              jiminy-billy-bob
              FYI, TT is currently helping me porting the plugin on OSX. Cheers to him ! 😄
              • marcorigamonti74M
                marcorigamonti74
                Let me know when the plugin will be ready for OSX sistem!!!
                THANKS!!!!!!
                • nanolinN
                  nanolin
                  Hello
                  You can sort the list by alphabetical order of layers? . It can be added as an option?
                  thanks
                    db11
                    Been patiently waiting for a functioning OSX version of this must-have plugin, so this is the best news I've heard in a long time!
                    Any idea on the ETA?
                    • jiminy-billy-bobJ
                      jiminy-billy-bob
                      @nanolin said:
                      Hello
                      thanks
                      Someone (maybe you ?) already suggested this. So it's on my todo list 😉
                      Nope. In the meantime, you guys can help by filling the issue tracker on the github projet : https://github.com/jiminy-billy-bob/Layers-Panel/issues?state=open
                      • jiminy-billy-bobJ
                        jiminy-billy-bob
                        Hey guys, I've added a poll at the top of the topic.
                        Choose what render engine you would like to be supported by Layers Panel.
                        I don't garanty that I can make it work with every engine, but it some cases it can be done by the engine's dev (Like Tomasz is supposed to be doing with Thea 😄 ). So if an engine gets lots of vote and it has to be done by the dev, I can communicate them that there is high demand.
                        • jiminy-billy-bobJ
                          jiminy-billy-bob
                          It's here guys ! 😄
                          New version 0.9 beta !
                          Changelog :
                          • OSX support
                          • Fixed clicking on layer's name not selecting it
                          Download in the plugin store !
                          A huge thanks to TT for the OSX support ! 👍 👍
                          It's the first OSX version, so it still has bugs. We need you to find them 😉
                          • tt_suT
                            tt_su
                            A couple known bugs:
                            • "Add Group" doesn't work the first time you click it.
                            • Unfolding the window doesn't work correct. Instead of unfolding it expands a little in the width.
                            • Bob JamesB
                              Bob James
                              After loading the latest version I still get this upon opening a model.
                              • H
                                huckrorick
                                Is there a way to tell within Sketchup which version I am using?
                                • tt_suT
                                  tt_su
                                  Any model_ Or a specific model?
                                  • jiminy-billy-bobJ
                                    jiminy-billy-bob
                                    "Still", you mean you had this issue before 0.9 ?
                                    Does it happen everytime ? Only when opening a model, not when opening the dialog ?
                                    Window > Preferences > Extensions > click on Layers Panel. You'll get the version at the bottom.
                                    • Bob JamesB
                                      Bob James
                                      Any model
                                      Yes. And when I change the condition or existence of layers in SU Layers it does not "track" into Layers Panel.
                                      Yes. On two different computers: home and work (Win7)
                                      •It also pops up when using Ctrl-Z to restore a Ctrl-X.
                                      •It also still disrupts the layers associated with a scene: if I change the layer combination in a scene and the go back to a different scene the layers in that previous scene have been lost. When I disable Layers Panel the problem goes away (repeatable experience over many models and both machines)
                                      • tt_suT
                                        tt_su
                                        What IE version do you have installed?
                                        • jiminy-billy-bobJ
                                          jiminy-billy-bob
                                          Did you try to delete everything related to Layers Panel in your plugins folder, and perform a clean install ?
                                          About the scene issue, did you check that the auto-update option is disabled ?
                                          • Bob JamesB
                                            Bob James
                                            Also the Ctrl-X/Ctrl-Z dialog box has a different Char:59 instead of 65
                                            By the way: closing and opening Layer Panel gives the Char:59 version of the error.
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 33
                                            • 34
                                            • 16 / 34
