    [Plugin] Hatchfaces (v1.8 beta) UPDATED 15-Dec-2012
    360 Posts 41 Posters 329.3k Views 41 Watching
    • jolranJ
      jolran
      Yet another report..
      During troubleshooting some stuff I at least got intersecting working for surfaces.
      Could be useful for hatching slopes or similar.
      Note: The size of hatches will be determined by face size, spacing will be calculated according to that.. SO what you see here is a surface based on Quads.
      And the surface will have to be grouped for intersection.
      One cannot glue a large component onto a surface unfortunately. So that option will probably have to be cancelled..
      • jolranJ
        jolran
        Here is how you use it! Installation: Unzip in your Sketchup plugins dir.
        In ver 1.8 edge selection is not needed. Then angle will be calculated from the "bottom bounds-border". However for more control one can still use edge selection.
        New for APRIL 29-2013 Sectioncut and HATCHES tutorial
        It may not be so self-explanatory in the help files how to use Sectioncuts and Hatchfaces together, so I release this mini-tutorial of 1 way of doing it.
        NOTE: TIG's Sectioncutface is the prefered solution to use for creating faces at section
        in step 1 of this tutorial.
        • jolranJ
          jolran
          Tutorial added.
          404 Not Found
          (sketchucation.com)
          Plugin development status: Working on it and some other things in parallel.
          edit: Noticed there are some typos, but am not going to change those since I've flattend the original in Photoshop. I think the message comes through in the current text.
            DOD3R
            Hi Jorlan,
            I taught you would like to see work of krill2008
            https://sites.google.com/site/lssoft2011/home/lss_matrix
            this plug in is very help full and i think the closest thing to parametric modeling in sketch up.
            You probably know about this plugin, but just in case you missed it.
            • jolranJ
              jolran
              Hi.
              Thank you very much for the input. Much appreciated..
              I already have it in my pluginfolder πŸ˜„
              I have had a peek at Krill's code for ideas, but it is a VERY big script and it can take quite a bit of work(for me anyway) to get a grasp of what is going on.
              Actually in my case I'm avoiding peeking in others script to much since I noticed it
              distracts me a little. Unless I'm searching for a specific problemfix.
              I feel I have learnt more from experimenting, with my own code.
              Besides Krills script is copyrighted so, cant borrow anything from there anyway, but I do like to investigate his OpenGL preview a little, for ideas.
              Regarding Hatchfaces.
              I have code thats almost finished for tiling groups or components with intersecting on a single face. But recent developping has been all working on the node-GUI-editor.
              But I sence this plugin will require quite a lot of work so I might take a break from it in the near future and update Hatchfaces as promised.
              Best regards.
                DOD3R
                glad to hear about your progress. I am looking forward to new hatchfaces.
                Also I am happy, that you know about krills work. But question is if he knows about yours. Maybe you can join forces or maybe he is working on some parametric modeling on his own.
                I would like to here what he has to tell about parametric grasshoper-like modeling in sketch up and i think You even more.
                kind regards
                D.
                • jolranJ
                  jolran
                  Hi.
                  I'm afraid I don't have any collaboration in plan for that plugin.
                  Helps, ideas and suggestions are always welcomed though, and I thank you for your
                  input so far in this matter.
                  Best regards /
                  Joel.
                  • jemagnussenJ
                    jemagnussen
                    I have probably missed it, but is there a possibility to make insulation hatches with this plugin?
                    Brgds
                    Jesper
                    @jolran said:
                    Hi.
                    Best regards /
                    Joel.
                    HP ZBook 15, Windows 10 64 bit
                    Intel Core i7-6820HQ @ 2.70GHz
                    32 GB Ram
                    NVIDIA Quadro M2000M
                    • jolranJ
                      jolran
                      Not yet.
                      But in my developpment version yes. Any pattern you'd like. Hopefully soon for you guys.
                      Working on another plugin that has higher priority, but that might now change so standby on this.
                      Performance will be much slower than LO on complicated patterns or small scaling=many patterns. That is one of the reasons this plugin has been a little on hold, in case I could figure out a way to solve that.
                      • T
                        teisele27
                        I haven't read all the posts, so maybe this was already answered. I am running SU8 on a Mac. I put the plugin in my plugins folder a required, but can't get it to run. Suggestions? Thx
                          Tom, did you just move the ZIP file to the Plugins folder or did you extract the contents of the ZIP file first and put them in the Plugins folder. Did you install the plugin using the Sketchucation Plugin Store? (That's the best method, anyway.) Do you have permissions set to Read AND Write for the Plugins folder? Did you restart SketchUp after installing the plugin?
                          • jolranJ
                            jolran
                            Hi.
                            As Dave pointed out you will have to unzip the files to Plugin directory.
                            Let me know how it goes.
                            Reply Quote -1
                              ArCAD-UK
                              Had a quick play. Wish I'd taken notice of this sooner!
                              Development suggestion.. Crosshatching allows the creation of some interesting parallel line patterns by applying the same angle with different spacing values, but there is no way to do a simple parallel offset using the same spacing. Could you add an offset parameter in the crosshatch window to allow the creation of one of the more common basic hatch patterns like this // // // ?
                              • jolranJ
                                jolran
                                Hi!
                                If you scroll back a few pages you can see that it is the roadmap of using costum patterns. Where one could use any type of pattern one wish.
                                However I like your idea, and it could be expanded into a feature with inbuilt patterns.
                                We could call them "vector-patterns".
                                Now they would not have so many adjustable parameters, cause the dialog would get swamped. But they would be created by code and not tiled groups, so they (may) be faster to intersect.
                                Unfortunally I'm working a lot on another plugin, so this plugin is not prioritized.
                                Especially since Lo had the Hatchpattern function added, I was under impression people where content with that..
                                But if there is more interest I might be able to squeeze in an update when time permitts. I have by no means given up on this plugin..
                                  ArCAD-UK
                                  Not really. Raster hatching comes with scaling / dpi issues.
                                  The offset was just a suggestion as I thought it might be easy to add unlike shape patterns which I can see will be a BIG challenge.
                                  • jolranJ
                                    jolran
                                    Right, that was my opinion too. Not Always good printing result.
                                    There may be a possibility to pull off a few simpler pattern combinations in code.
                                    Which would be faster to intersect.
                                    OK, I pull up this one a notch in priority then. No promises made. Gotta try and finish some projects and not just start new ones πŸ˜„
                                    • E
                                      elvirem
                                      Great thanks Jolran : that's my dream !! Unfortunately it doesn t work for Mac with skp8.. if anybody knows how to develop this plugin for mac, that would be really great πŸ˜„
                                        It does indeed work on Mac. πŸ˜’
                                        If it didn't for you, the most likely causes are incorrect installation or lack of permissions to the Plugins folder. You'll have to give some useful information about if you want help sorting it out. Further development of the plugin isn't the answer, though.
                                        • jolranJ
                                          jolran
                                          Hi Elvirem.
                                          Can you be more specific, "than it does not work", please.
                                          I woulden't even know where to start debugging..
                                          Since Dave R (Thank you) can provide a screenshot of a working solution the issue is not general.
                                          If anybody knows how to develop this plugin for mac, that would be really great
                                          I havent updated the plugin for quite a while, since working on other plugin. But I intend to update at later point, even have code for doing so. So I would prefer letting me be in charge of updating my plugin.
                                          As Dave said, please come back with some more information, and I try to help you πŸ˜„
                                          / Joel
                                          • SkalpS
                                            Skalp
                                            @lapx said:
                                            Me too! It would be nice if it could read and tranaslate autocad hatch file. We need some cross polination of the minds on this one. πŸ˜„
                                            I wonder if it works on curved surfaces...I must experiment.
                                            Lapx,
                                            Take a look to Skalp for Sketchup, we have a live section tool and handle Autocad hatch patterns. We create tileable textures based on Autocad pattern files and have the ability to export them back to dxf .
                                            The Skalp Team
                                            Skalp
                                            http://www.skalp4sketchup.com
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 17 / 18
