    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 543.8k Views 172 Watching
      The file_loaded? method is created by sketchup.rb
      There should be a line near the start of every script to ensure that sketchup.rb is loaded before calling it:
      require('sketchup.rb')
      This will load it if it has no already been loaded by a script that loaded earlier on.
      If you have a very limited number of plugins loading and one of them has not loaded sketchup.rb before getting to try and load 'LiveIvy.rb' then you'll get a failure.
      If you don't want to edit the LiveIvy file to add that line of code at the sart, then why not just install the 'SketchUcation Plugin Store' toolset [see the Resources menu] - that has a loader starting with ! putting it first alphabetically, so it loads at the very start AND therefore will have already 'required' sketchup.rb, preventing later miscast plugins throwing an error.
      You'll also have the added advantage of then having an awesome [free] toolset to auto-install and manager your plugins and extensions !
        desunvn
        Thank you for share
        • K
          Kjammer
          The SketchupIvy.0.6.3 is a .rar file and Sketchup cant recognize it because it not an rbz. how do we install it?
          • KrisidiousK
            Krisidious
            Just extract it to your plugins folder. It's a zip folder.
            By: Kristoff Rand
              You can get the RBZ version from http://sketchucation.com/resources/pluginstore?pln=SketchupIvy
                saturne45
                Hello everybody, this very nice plugin working good with skp8 on windows xp and don't work with skp8 on windows vista?? with files in rar or rbz. anybody had got the same problem?? and is there a solution. thank you.
                • KrisidiousK
                  Krisidious
                  It will work on any system you put it on. perhaps you're having conflicts with other old plugins.
                  By: Kristoff Rand
                    If you don't explain 'how it doesn't work' then no one will be able to help you to fix this problem.
                    It WILL install and work...
                    You are either mis-installing, mis-using or have other conflicting plugins [like maybe Vray beta] ?
                    Give us a clue ! 😒
                      saturne45
                      Thank you for reply, when I start the plugin I can't get the reds lines ( branch) on my face,when I do ctrl left clic I get a littles crosses and shift clic I do that ? see on my screencapture. The plug installation is correct.
                      right now; I'm looking for if there is a conflict with others plugins.Thank you.
                      • saberopusS
                        saberopus
                        just left click to continue the growing process, then use ctrl+click (as you know) to add leaves and shift+click to finish
                        • saberopusS
                          saberopus
                          @jbjdesigns said:
                          The "branch" part worked okay; but when I applied the leaves, they all drooped (no matter what settings I used... and I really tried to make this work).
                          I seem to be having this same issue... all the leaves point downward, generally, and so the overall appearance is 'droopy.' There's doesn't seem to be a parameter to adjust this, though? Any thoughts?
                          • KrisidiousK
                            Krisidious
                            Gravity might be your problem. Try setting it lower... Somewhere earlier in these posts there are default settings.
                            By: Kristoff Rand
                              saturne45
                              Hello, Thank you for your reply, Still not find a solution. But can you explain to me this error message in the ruby consolle? look on screencapture. Thank you.
                                mechipo
                                Thanks for this !!
                                • L
                                  lomanzo78
                                  Hi im also having probles in Mac. the pluggin dialog apears, but at the moment than I want to do an ivy it desnt do anything, can you help me
                                  thanks
                                  • OxerO
                                    Oxer
                                    I'm having problems now too in OSX 10.9.1 and SU2013, before the Ivy version 0.6 worked fine on Mac, now when i call the plugin it appears this in Ruby Console:
                                    PS: I have uninstalled all the plugins except Ivy and the problem persists.
                                      You have float values saved as 0,8 rather than 0.8 so the commas breaks the conversion of the read_defaults string back into the hash ! There are some commas it needs, and some that should be '.' !
                                      You use a commas as your decimal separator rather than the '.', but Ruby uses '.' always...
                                      It should be something like:
                                      {:gravity=>{:vector=>[0, 0, -1], :weight=>1,0}, :branch=>{:radius=>0,8, :nodesize=>3, :detail=>4, :probability=>0,97, :floatlength=>150, :spread=>1,0, :pattern=>0,8}, :wind=>{:weight=>0,1}, :random=>{:weight=>0,3}, :adhesion=>{:weight=>0,2, :max_adhesion_distance=>50}, :legacy=>{:weight=>0,8}, :leaf=>{:probability=>0,75, :size=>5,0, :pattern=>1}}
                                      but you have:
                                      {:gravity=>{:vector=>[0, 0, -1], :weight=>1,0}, :branch=>{:radius=>0.8, :nodesize=>3, :detail=>4, :probability=>0.97, :floatlength=>150, :spread=>1,0, :pattern=>0.8}, :wind=>{:weight=>0.1}, :random=>{:weight=>0.3}, :adhesion=>{:weight=>0.2, :max_adhesion_distance=>50}, :legacy=>{:weight=>0.8}, :leaf=>{:probability=>0.75, :size=>5,0, :pattern=>1}}
                                      If you edit the file 'LiveVector_core.rb' with a plain-text editor and find line #61 that says:
                                      return eval(str)
                                      and now insert these lines of code just in front of it, thus:
                                      split=str.split('=>') split.dup.each_with_index{|e, i| next unless e=~/^[0-9]/; next unless e.count(',')==2; split[i]=e.sub(/,/, '.') } str=split.join('=>')
                                      then
                                      return eval(str)
                                      This should change the ',' to '.' - but only in the numbers like 0,8 >>> 0.8 but vector arrays and simple integers are ignored.
                                      The hash should now eval OK... 😒
                                      • OxerO
                                        Oxer
                                        Hi TIG,
                                        I done that you say me but it continue with the same Ruby Console Error, after try all possibilities (uninstall all plugins, delete SU preferences, etc) and to see that the problem persisted I have opted for delete SU2013 folder, all preferences (SU preferences, all plugins preferences, hide files related) and reinstall SU and the plugins and voila! now all work fine.
                                        I had time to try more things, perhaps it were a corrupt preference file or a conflict with other plugin, I don't know, mystery! ❓
                                        • JBJDesignsJ
                                          JBJDesigns
                                          The gravity settings were set at various levels, i.e., low, mid and high values. The leaves still droop. Also, I haven't heard anything back about the leaves turning up in every new project I start as components. Although it is now easier to "delete" the leaved and purge from materials, it's still annoying. Great idea, but I'd love to see further refinements.
                                          ...you send them to school, you give them books, and they eat the pages...
                                            ayarriquitukis
                                            i fix a problem with the alpha img i can use in sketchup 2014... if you want tell me ... "for search a way to upload my new files"excuse me for the bad english....
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 36
                                            • 37
                                            • 25 / 37
