    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 511.0k Views 172 Watching
    • Z
      zelimbo
      thanx man!
      • KrisidiousK
        Krisidious
        Did that fix it?
        By: Kristoff Rand
        • F
          fwolf21
          Great work.
          I have worked with the original ivy generator back in 2008-2009.
          Don't have any thing to say right now since just start using it.
          Ill keep you posted if anything comes up.
          Keep you the great work
          • P
            PHRodrigues
            awesome! thx man.
            • T
              technoshaman
              Thank you for this wonderful plug in. I was about to start modeling ivy by hand!!!! But this saved me so much time. THANK YOU
              • lele_poggiL
                lele_poggi
                The plug-in doesn't work with the new version of Vray for Sketchup 1.6.
                Can be fixed this bug?
                Thank you
                gsa | Gabriele Sacchi architetto
                http://www.gs-a.it
                  Thank you
                  The bug is in the Vray beta - it breaks several legit tools by having some flaky observer calls... I know Vray have a solution and I'd expect an update to their beta soonest...
                  Meanwhile can I suggest that you disable Vray from loading while modeling - you don't need a renderer to model ??
                  • lele_poggiL
                    lele_poggi
                    Thanks TIG.
                    I've already disable Vray and it works fine.
                    I didn't know it was a Vray bug.
                    So I'm in waiting for their next beta release to check this.
                    http://www.gs-a.it
                      I'd recommend that you report this to the developers of V-Ray. It's known to have caused problems with other plugins as well.
                        AcesHigh
                        @pierreden said:
                        TO COME
                        • Leaves as Components
                        • More Parameters and grow patterns.
                        • Other Plugins. Fur, Cloth and Tree.
                        I wonder what happened to Pierreden 😞
                        • JBJDesignsJ
                          JBJDesigns
                          Sorry to say I did not find this plug-in very useful. But it could be my version of SketchUp (2013). The "branch" part worked okay; but when I applied the leaves, they all drooped (no matter what settings I used... and I really tried to make this work). Turns out the "Tak2hata: Make Fur v2.0.6" is much better at creating leaves. Nice try though. And by the way, I do have the original ivy maker which I use once in awhile.
                          One other problem... the leaves for some reason turned up in every new file I opened as components. Then I tried to remove "unused" components, the leaves would not purge. They had to be deleted individually. Annoying.
                          ...you send them to school, you give them books, and they eat the pages...
                            jake0721
                            hello sir, is it compatible for su 8? im using su 8 pro
                            • KrisidiousK
                              Krisidious
                              yes, it is...
                              By: Kristoff Rand
                              • B
                                bsley
                                No luck getting this installed. Dropped the contents of the zip into my "Plugins" folder and I'm getting this when I open Sketchup:
                                Error Loading File LiveIvy.rb
                                undefined method `file_loaded?' for main:Object
                                Mac 10.8.3 / SketchUp 2013
                                • KrisidiousK
                                  Krisidious
                                  One of the SketchUp gurus will have to answer that...
                                  By: Kristoff Rand
                                    revalucia
                                    same problem:
                                    SU2013
                                    plugin Vray 1.49.02
                                    and sketchupIvy 0.6.3beta
                                    Please help! thank you
                                      The file_loaded? method is created by sketchup.rb
                                      There should be a line near the start of every script to ensure that sketchup.rb is loaded before calling it:
                                      require('sketchup.rb')
                                      This will load it if it has no already been loaded by a script that loaded earlier on.
                                      If you have a very limited number of plugins loading and one of them has not loaded sketchup.rb before getting to try and load 'LiveIvy.rb' then you'll get a failure.
                                      If you don't want to edit the LiveIvy file to add that line of code at the sart, then why not just install the 'SketchUcation Plugin Store' toolset [see the Resources menu] - that has a loader starting with ! putting it first alphabetically, so it loads at the very start AND therefore will have already 'required' sketchup.rb, preventing later miscast plugins throwing an error.
                                      You'll also have the added advantage of then having an awesome [free] toolset to auto-install and manager your plugins and extensions !
                                        desunvn
                                        Thank you for share
                                        • K
                                          Kjammer
                                          The SketchupIvy.0.6.3 is a .rar file and Sketchup cant recognize it because it not an rbz. how do we install it?
                                          • KrisidiousK
                                            Krisidious
                                            Just extract it to your plugins folder. It's a zip folder.
                                            By: Kristoff Rand
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 36
                                            • 37
                                            • 25 / 37
