    Tips and Tricks for faster animations
    renderpluginsextensions
    9 Posts 3 Posters 773 Views 3 Watching
    • V Offline
      valerostudio
      I'm wondering if anyone can share any tips / tricks in order to get animations out faster. The last 40 second one I did took over 9 hours to export at 30fps. I guess I could cut down to 24 and maybe reduce the size of the export and hook up some other machines to DR but are there any other secrets to getting these things to cook faster?
      • V Offline
        valerostudio
        Guess I am getting my answer, huh?
        (crickets)
        • andybotA Offline
          andybot
          better figure out a way to get DR working...
          Yes, I've had to reduce framerate and resolution to get things to render in a few days instead of a month. Sorry, no shortcuts that I know of. At least saved maps are working (IR map was broken before in 1.49 if you recall)
          • dkendigD Offline
            dkendig
            what's wrong with DR?
            Devin Kendig
            Developer
            • V Offline
              valerostudio
              DR is great if you have machines to render to. I am looking to increase animation render times without having to go out and buy a farm.
              • dkendigD Offline
                dkendig
                @andybot said:
                I don't believe there's any way to increase rendertimes in vray...
                Hey, there's a nice quote πŸ˜‰
                Devin Kendig
                Developer
                • andybotA Offline
                  andybot
                  πŸ˜†
                  what can I say, I'm just a vray fanboy πŸ˜„
                  • andybotA Offline
                    andybot
                    I dunno Matt, just sounds like you're complaining now
                    I don't believe there's any way to decrease rendertimes in vray without reducing resolution, quality, or framerate. There just aren't any shortcuts - well, there's Lumion I guess. If you can't "afford" the vray render, what's wrong with the SU output? I end up doing that all the time when I get into time or budget constraints. 98% effective... πŸ˜›
                    Edit: fine Devin - I meant increase the speed of vray... πŸ˜’
                    • V Offline
                      valerostudio
                      I found this article which has some good tips.
                      http://www.workshop.mintviz.com/tutorials/vray-animation-optimisation/
