BuildEdge PLAN 3.0 Now Available!
Oh boy! We have tracked down a problem with Windows XP systems
@aarondietzen
I have XP system so this explain that!
So must I send you an email or the new version will available on the PluginStore ?@ Tig : thx for these detailed infos!
@aarondietzen
So must I send you an email or the new version will available on the PluginStore ?That would be it and we have a fix! I am sending the new RBZ in right now...
Since I don't know when that will end up in the store, I can send you the RBZ if you want to send me an email address. Alternatively, you can download an updated installer here:
http://store.buildedge.com/Home/PlanUpgrade
It is marked as the "Update Installer" but it will install the full version as well.
As always, please let me know what you think!
That latest updated version is now in the SketchUcation PluginStore...
Hi Aaron, have watched the 3.0 videos and looks like a big leap foward!!
For some reason though this is what I get when loaded? Seems the dialogue box is scrambled; I can't seem to be able to insert my serial number.
I will try the uppdater
Much better...
Just a very anxious suspense !
1 minute 40 seconds before something arrives after the first click on the icon !
All is freezing then all works fine!
Never seen that for any plugin : I have tested some thousands!
Do you test something to Internet ? (I have a speedy connection)
Tested on a not very old computer
( 3 years 5 cores)
This is happening only at the start of a Sketchup session!
After the first openning of the plugin it works normally at each call of the plugin!
Another thing: does it normal in the free demo to not have door, window, floor ?
(colors image are mine in 2D prog changed
Hi Aaron,
if I am part way through my design using build edge and I need to close sketchup. When I re start sketchup and continue with my design do I loose the functionality of buildedge? Does it commit to sketchup on closing in other words.
@bruce watt said:
Hi Aaron,
Hi Bruce,
Closing SketchUp should not affect your BuildEdge data. You should be able to save, close, reopen and continue working. We only Commit when you tell us to!
Hi Andrew!
Woah! That ain't right!
Looks like a problem initializing the java script. Is that happening every time you try to run, or just the first time? If it IS every time, I will need to get some more data from you. I think it is something that we can fix pretty easily, but it might take a little bit of investigation.
Much better...
( 3 years 5 cores)
[attachment=0:1llvyi36]<!-- ia0 -->testb.jpg<!-- ia0 -->[/attachment:1llvyi36]
First off, I gotta say I am really enjoying the colors.
Now, as for the delay, is that happening every time you launch, or just the first time? Unfortunately, we do authorize the software, and that can take a little time (though, to be honest, 1 minute 40 seems a little too long).
As for doors, windows and floors, yep! That, along with advanced roof input and automatic input are paid functionality (but only $29!).
haven't heard back on how to retrieve my serial number...
also I tried rounding a curved wall and it seems the system is can't do short wall lengths like under 8" maybe?
Hi Kris,
Sorry, did you contact our help desk for your Serial Number? It is very quick and easy to reset. If you email me (adietzen@keymark.com) I will get that done and right back to you. Alternatively, you can contact the Help Desk through our site (http://www.buildedge.com/help).
As for the walls, it will not draw walls that are shorter than they are wide. It can do 8" long walls, as long as the wall width is thinner than 8".
they just sent serial, as for length of wall. that's probably the issue walls are 6" and was trying to make 4" length. around a curve.
Aaron,
I don't see anyway to get the new version for free on your website (I am a current user)?? Does the free version on the plug-in store become the full version with the input of my old activation key?
Regards,
Kris -
Yah....okay.
Update button is for the program download, not updating the shopping cart.
Kris -
@krism said:
Yah....okay.
KrisHi Kris,
Glad you figured that out... yeah, we will be changing that term from "Update" to "Upgrade"Sorry for the confusion...
Hi Aaron, happens every time I open it. Not sure what's happening so I hope you have some suggestions!
Great work on development; its really coming along nicely!!
Yes every time I Launch SU!
So for avoid this I can stay On Su 24 h / 24 h (not very ecologic!
So an authorisation the firt time will be some better!
Ok all that explain the remarks!
Hi Andrew,
Can you send me the .log files in your C:\Users"user name"\AppData\Roaming\BuildEdge\Plugins\SketchUp\BuildEdgePLAN folder?
Just email those directly to me (adietzen@keymark.com) and we can see why Java is not initializing on your machine.
Wait! Are you suggesting that you actually DO shut down SketchUp??? I thought you kept it running all day, every day!
Obviously, that is not ok... for what it;s worth, you are the first person I have heard this from! I will check with our development guys and see how we should go about tracking this down.
Sorry for the inconvenience, guys, but thank you for the quick feedback! Hopefully I can get you running quickly!
Not sure whats going on here when I select add window I get a circle with a slash thru it, the wall has not been committed to SU so I'm able to add doors move them just the add window not working any suggestions
Problem solved height of window and window height where the same 6'8" I'm not sure how that happened.
Aaron, that was happening a lifetime ago.... no probs now.
With your input, this post could be even better ๐
