    BuildEdge PLAN 3.0 Now Available!
    55 Posts 15 Posters 13.2k Views 15 Watching
    • K
      KrisM
      Aaron,
      I don't see anyway to get the new version for free on your website (I am a current user)?? Does the free version on the plug-in store become the full version with the input of my old activation key?
      Regards,
      Kris
      • K
        KrisM
        Yah....okay.
        Update button is for the program download, not updating the shopping cart.
        Kris
        • aarondietzenA
          aarondietzen
          @krism said:
          Yah....okay.
          Kris
          Hi Kris,
          Glad you figured that out... yeah, we will be changing that term from "Update" to "Upgrade"
          Sorry for the confusion... ๐Ÿ˜ณ
          "Imagination is more important than knowledge..."
          - Albert Einstein
          • utilerU
            utiler
            Hi Aaron, happens every time I open it. Not sure what's happening so I hope you have some suggestions!
            Great work on development; its really coming along nicely!! ๐Ÿ‘
            Just Curious...
              Now, as for the delay, is that happening every time you launch, or just the first time? Unfortunately, we do authorize the software, and that can take a little time (though, to be honest, 1 minute 40 seems a little too long).
              As for doors, windows and floors, yep! That, along with advanced roof input and automatic input are paid functionality (but only $29!).
              Yes every time I Launch SU! ๐Ÿ˜ฎ
              So for avoid this I can stay On Su 24 h / 24 h (not very ecologic! ๐Ÿ’š
              So an authorisation the firt time will be some better! ๐Ÿ˜‰
              Ok all that explain the remarks! ๐Ÿ˜„
              • aarondietzenA
                aarondietzen
                Hi Andrew,
                Can you send me the .log files in your C:\Users"user name"\AppData\Roaming\BuildEdge\Plugins\SketchUp\BuildEdgePLAN folder?
                Just email those directly to me (adietzen@keymark.com) and we can see why Java is not initializing on your machine.
                Wait! Are you suggesting that you actually DO shut down SketchUp??? I thought you kept it running all day, every day!
                Obviously, that is not ok... for what it;s worth, you are the first person I have heard this from! I will check with our development guys and see how we should go about tracking this down.
                Sorry for the inconvenience, guys, but thank you for the quick feedback! Hopefully I can get you running quickly!
                - Albert Einstein
                  mwm5053
                  Not sure whats going on here when I select add window I get a circle with a slash thru it, the wall has not been committed to SU so I'm able to add doors move them just the add window not working any suggestions
                  Problem solved height of window and window height where the same 6'8" I'm not sure how that happened.
                  2011 iMac
                  SU 2015 Pro, 2017 Make
                  V2 Twilight
                  macOS Sierra 10.12.5
                  • utilerU
                    utiler
                    Aaron, that was happening a lifetime ago.... no probs now. ๐Ÿ‘
                    Just Curious...
                    • H
                      Helle
                      I just bought BuildEdge 3.0. I cannot insert any windows, no matter what I do? Tried to change template to inches etc. but nothing matters. Does anybody have a solution, please
                        mwm5053
                        It did that to me too. Make sure height of window is not the same as top of window. I think when start out default are the same height.
                        2011 iMac
                        V2 Twilight
                        • H
                          Helle
                          I got it .... it was me.... from the bottom up regarding window height
                            mwm5053
                            ๐Ÿ‘
                            2011 iMac
                            V2 Twilight
                            • deaneauD
                              deaneau
                              Hello Aaron,
                              at first i love the Plugin.. in 2013 work fine however at 2014 ...
                              Hello,
                              BuilEdgePlane have a big BUG in 2014. If I insert a windows some dividers will place in the windows and the other dividers will place near on the zero point. so i can not work with this plugin.
                              other problem. the BEP-Windows will be ever active than non active etc. sometimes the value will accepted and somtimes not.
                              please fix this i use 2014 make at home.
                              reagards
                              Dean
                              p.s. look at Sophie some of the dividers will stay there.
                              • U
                                unearthed
                                This looks like it could really save me some time, but this is a worry:
                                I live/work in a remote location with local satellite access (which is not 100% reliable) I never purchase software that needs to handshake on startup or requires a livelink. So...is BuildEdge still like this?
                                Growplan - People โˆฉ Plants โˆฉ Place
                                windows 7 64b, 4GB RAM, SU 8.0.16846
                                Gimp, QGIS, Vectorworks 12, Bricscad 11
                                • U
                                  unearthed
                                  Waiting, wainting...still no answer since last week AND I sent the same query as an email.
                                  • aarondietzenA
                                    aarondietzen
                                    Hi Unearthed,
                                    Sorry, I don't regularly read through this forum looking for posts about BuildEdge. Also, as luck (bad luck, that is) our "Contact Us" page is broken and we are not receiving emails! For future reference, submitting a ticket to Help Desk through our main site is the best way to get in touch with us.
                                    As to your question, as of now, we are using the same security as we were before. You will need to be connected to the internet to initially authorize. After that, it will attempt to check in every few weeks to verify that you have not moved the security.
                                    As long as you have a connection at install and are connected occasionally as you run, you should be good!
                                    Thanks,
                                    Aaron
                                    - Albert Einstein
                                    • pbacotP
                                      That is great-- if it actually works. Continuous connection is not given, even when your provider has promised it. Also I have some software that requires me to refresh the license by going to the website, every time I move my laptop to my office or home. Not too nice.
                                      • U
                                        unearthed
                                        Thanks Aaron, that sounds more useable
                                        • aarondietzenA
                                          aarondietzen
                                          Glad that helps, Nigel.
                                          I know that it is not the perfect solution, and that security, of any kind, can be a pain, but we have attempted to create a solution that is as easy as possible and a staff that is quick to respond to customer issues (when our site is not dumping our contact us emails, that is!).
                                          Hopefully security does not cause too many issues for you all,
                                          Thanks,
                                          Aaron
                                          - Albert Einstein
                                          • deaneauD
                                            deaneau
                                            What about an Bugfix, since i have pay this i have never work withis
                                            404 Not Found
                                            (sketchucation.com)
                                            per email have tell me, that we solve the problem in june or July...now we have August.
                                            the30 day money-backguaranty is end in april. is this service?
                                            have i pay bugs or a plugin? ๐Ÿ‘Ž sorry
                                            • 2 / 3
