    BuildEdge PLAN 3.0 Now Available!
    55 Posts 15 Posters 12.8k Views 15 Watching
    • C
      cadmunkey
      Suitable for plans in metric or are all the doors/windows etc in feet and inches?
      • aarondietzenA
        aarondietzen
        Hum hum ๐Ÿ˜„ (V8)
        Load free version here at PluginStore
        Seems BuildEdgeSketchup.BIM_v3.dll missing : where is it ?
        Erreur de chargement du fichier
        > C;/Program Files/Google/Google SketchUp 8/Plugins/BuildEdgePlan/BuildEdgeSketchup.BIM_v3.dll
        > 127; La procรฉdure spรฉcifiรฉe est introuvable.
        > - C;/Program Files/Google/Google SketchUp 8/Plugins/BuildEdgePlan/BuildEdgeSketchup.BIM_v3.dll
        >  C;/Program Files/Google/Google SketchUp 8/Plugins/BuildEdgePlan/init.rb
        > undefined method `SetSketchUpVersion' for BuildEdgeSketchup;Module
        > Erreur de chargement du fichier BuildEdgePlan.rb
        Oh boy! We have tracked down a problem with Windows XP systems. Seems there was an issue with the way the Visual Studio built dlls or some such technical issue. Good news is we have a fix and will be releasing a new version today. If anyone is having this issue, just PM or email me (adietzen@keymark.com) and I will get you a fix, ASAP.
        So sorry for any inconvenience!
        "Imagination is more important than knowledge..."
        - Albert Einstein
        • aarondietzenA
          aarondietzen
          Hi Munkey,
          We defer to SketchUp units, so you can specify the door and window parameters in your preferred unit of measure.
          - Albert Einstein
            @aarondietzen
            I have XP system so this explain that! ๐Ÿ˜‰
            So must I send you an email or the new version will available on the PluginStore ?
            @ Tig : thx for these detailed infos! โ˜€
            • aarondietzenA
              aarondietzen
              @aarondietzen
              That would be it and we have a fix! I am sending the new RBZ in right now...
              Since I don't know when that will end up in the store, I can send you the RBZ if you want to send me an email address. Alternatively, you can download an updated installer here:
              http://store.buildedge.com/Home/PlanUpgrade
              It is marked as the "Update Installer" but it will install the full version as well.
              As always, please let me know what you think!
              - Albert Einstein
                That latest updated version is now in the SketchUcation PluginStore...
                ๐Ÿค“
                • utilerU
                  utiler
                  Hi Aaron, have watched the 3.0 videos and looks like a big leap foward!!
                  For some reason though this is what I get when loaded? Seems the dialogue box is scrambled; I can't seem to be able to insert my serial number.
                  Just Curious...
                    I will try the uppdater ๐Ÿ˜„
                    Much better... ๐Ÿ‘
                    Just a very anxious suspense ! ๐Ÿ˜ฒ
                    1 minute 40 seconds before something arrives after the first click on the icon !
                    All is freezing then all works fine! ๐Ÿ˜„
                    Never seen that for any plugin : I have tested some thousands! ๐Ÿ˜„
                    Do you test something to Internet ? (I have a speedy connection)
                    Tested on a not very old computer ๐Ÿ˜„ ( 3 years 5 cores)
                    This is happening only at the start of a Sketchup session!
                    After the first openning of the plugin it works normally at each call of the plugin! ๐Ÿ˜„
                    Another thing: does it normal in the free demo to not have door, window, floor ?
                    (colors image are mine in 2D prog changed ๐Ÿ˜‰
                    • B
                      Bruce Watt
                      Hi Aaron,
                      if I am part way through my design using build edge and I need to close sketchup. When I re start sketchup and continue with my design do I loose the functionality of buildedge? Does it commit to sketchup on closing in other words.
                      SKUP PRO 2021 latest version / update
                      Windows 10 Pro
                      Dell Alienware Aurora R10 AMD
                      AMD Ryzenโ„ข 9 3900X
                      NVIDIAยฎ GeForce RTXโ„ข 2080 Ti 11GB GDDR6
                      • aarondietzenA
                        aarondietzen
                        @bruce watt said:
                        Hi Aaron,
                        Hi Bruce,
                        Closing SketchUp should not affect your BuildEdge data. You should be able to save, close, reopen and continue working. We only Commit when you tell us to!
                        - Albert Einstein
                        • aarondietzenA
                          aarondietzen
                          Hi Andrew!
                          Woah! That ain't right!
                          Looks like a problem initializing the java script. Is that happening every time you try to run, or just the first time? If it IS every time, I will need to get some more data from you. I think it is something that we can fix pretty easily, but it might take a little bit of investigation.
                          - Albert Einstein
                          • aarondietzenA
                            aarondietzen
                            Much better... ๐Ÿ‘
                            [attachment=0:1llvyi36]<!-- ia0 -->testb.jpg<!-- ia0 -->[/attachment:1llvyi36]
                            First off, I gotta say I am really enjoying the colors.
                            Now, as for the delay, is that happening every time you launch, or just the first time? Unfortunately, we do authorize the software, and that can take a little time (though, to be honest, 1 minute 40 seems a little too long).
                            As for doors, windows and floors, yep! That, along with advanced roof input and automatic input are paid functionality (but only $29!).
                            - Albert Einstein
                            • KrisidiousK
                              Krisidious
                              haven't heard back on how to retrieve my serial number...
                              also I tried rounding a curved wall and it seems the system is can't do short wall lengths like under 8" maybe?
                              By: Kristoff Rand
                              • aarondietzenA
                                aarondietzen
                                Hi Kris,
                                Sorry, did you contact our help desk for your Serial Number? It is very quick and easy to reset. If you email me (adietzen@keymark.com) I will get that done and right back to you. Alternatively, you can contact the Help Desk through our site (http://www.buildedge.com/help).
                                As for the walls, it will not draw walls that are shorter than they are wide. It can do 8" long walls, as long as the wall width is thinner than 8".
                                - Albert Einstein
                                • KrisidiousK
                                  Krisidious
                                  they just sent serial, as for length of wall. that's probably the issue walls are 6" and was trying to make 4" length. around a curve.
                                  By: Kristoff Rand
                                  • K
                                    KrisM
                                    Aaron,
                                    I don't see anyway to get the new version for free on your website (I am a current user)?? Does the free version on the plug-in store become the full version with the input of my old activation key?
                                    Regards,
                                    Kris
                                    • K
                                      KrisM
                                      Yah....okay.
                                      Update button is for the program download, not updating the shopping cart.
                                      Kris
                                      • aarondietzenA
                                        aarondietzen
                                        @krism said:
                                        Yah....okay.
                                        Kris
                                        Hi Kris,
                                        Glad you figured that out... yeah, we will be changing that term from "Update" to "Upgrade"
                                        Sorry for the confusion... ๐Ÿ˜ณ
                                        - Albert Einstein
                                        • utilerU
                                          utiler
                                          Hi Aaron, happens every time I open it. Not sure what's happening so I hope you have some suggestions!
                                          Great work on development; its really coming along nicely!! ๐Ÿ‘
                                          Just Curious...
                                            Yes every time I Launch SU! ๐Ÿ˜ฎ
                                            So for avoid this I can stay On Su 24 h / 24 h (not very ecologic! ๐Ÿ’š
                                            So an authorisation the firt time will be some better! ๐Ÿ˜‰
                                            Ok all that explain the remarks! ๐Ÿ˜„
                                            • 2 / 3
