    Sketchup and Blender
    extensions
    170 Posts 26 Posters 46.2k Views 26 Watching
    • michaliszissiouM Offline
      michaliszissiou
      Recent betas of 3dcoat! The implementation of a new auto-retopology algorithm. Still in beta but looks promising and already useable.
      Z remesher is a little better in organic shapes. 3dcoat is more promising on hard surface cases.
      Patience though, another auto retopo tool is coming soon. In blender this time. We'll try not to call it lke "b remesher" LOL
      Auto retopology is a dream that is coming true.
      Still, serious issues there. Auto retopo tools tend to create endless spiral loops around the mesh, in certain cases.
      This is rather impossible to manually edit it.
      Blender is great on manual retopology. It provides some excellent new tools. It suffers from ugly visualization issues. I got used to it but if you give a try you will understand what i'm talking about.
      1. contours tool and 2. grid bridge in blender re topology are wonderful and result to very fast and really clean results.
      @Pete
      Artisan is a nice tool for those who are afraid to get involved in other apps, especially blender.
      Because, artisan is basically a box modeling tool.
      Blender is superb on box modeling - subd by any aspect. You don't have to retopo anything as a good topology means loops, auto retopology is basically a box modeling. (from a certain point of view)
      @Pilou
      thanks,
      Gutalin is a great concept artist, an inspiration and a good Z friend.
      However "my" approach is reverse engineering somehow. My goal was to easily export all these as low poly objects to any external renderer or a game engine engine.
      Gutalin's approach is very difficult to be exported. (without lose of details and quality)
      BTW my artwork you posed above is box modeling - subd result and does not use displacements-UV workarounds.
      Here an example of how a low poly (<30-40k faces) looks like. Using Tangent normal maps in cycles. Such scenes take less than 30 sec to render. Ideal as background assets.
      https://dl.dropboxusercontent.com/u/24090090/normTestTube.jpg
      And, allow me, my favorite recent experiment.
      https://dl.dropboxusercontent.com/u/24090090/ab5.jpg
      • soloS Offline
        Michalis, is this a low poly subdivision modifier with a displacement texture?
          michaliszissiou
          Yeah,
          well, the first one is a very low poly box modeling ~10k faces. Any detail comes form normal (tangent space) maps.
          The second one is dubdivided a lot and displaced by displ maps. Basically a few cylinders with loops on them
          Both normal or displacement maps have been baked- constructed by baking a relief modeling, on a single quad face.
          You basically model a relief like panel, you place a second one quad object in front of it, you ask blender to bake displ or nor-maps to "active". (active is the last you select, if interested, I could post a workaround on this)
          But in the end, you have this pre baked map, you just use the UV editor to align it to the existed topology.
          Here comes the tricky part, the powerful UV editor of blender.
          From a certain perspective, this is reverse engineering, the goal is to have a very low poly base with all the maps on it. Easy to export in any renderer. Or another application.
          It is a game, a kind of a generator, a conceptual art. Still, it is real geometry. Alternatively, an inspiration for other constructions. It became an obsession LOL, a friend named it "loopinitis" decease.
          • soloS Offline
            @michaliszissiou said:
            Yeah,
            Is there a walk through some place or a video tutorial, I'd really like to learn this and another thing, say I have a shape created in meta modeling and convert it to regular mesh will this process work with it?
            • olisheaO Offline
              olishea
              Michalis is the Gaudi of Blender! πŸ˜„
              oli
                michaliszissiou
                Simple ideas, working on a grid
                Loops, extrudes (insets) and subdivisions.
                Alternatively, if these loops can follow a geometrical displacement panel-map, I mean, if the selected face loop can be unwrapped as an aliened quad row on a geometrical pattern…. such a displacement will follow the topology.
                This is the basic idea. Too much work? Blender UV editor can do it automatically with 1-2 clicks.
                  michaliszissiou
                  A video tut?
                  Oliver Villar did a tutorial based on this. It explains only the basics though. There is much more potential on this method.
                  http://www.youtube.com/watch?v=3wyzvsmfia0&feature=youtu.be
                    Lobster
                    I must admit i did not really go for tutorials when i first started learning blender.
                    Even if this modelling time lapse isn't what you want to model in Blender i think it says more about modelling, approaches to modelling and retopology (after the z brush bit) than quite a few of the tutorials i have subsequently watched.
                    If in doubt just start modelling a hand in mid air and end up with the right number of edges to join to the arm! Using the sculpt brushes to shape the low poly mesh e.t.c.
                    it was definitely, mind blowing.
                    Regards
                      Had some fun with Pete's model...
                      Properly meshed and rigged this will make for some fun loony tune time πŸ‘
                        Funny : a French Blender Guru is named CoyHot! 😎
                        Site in English πŸ˜‰
                        http://www.coyhot.com/Images/Enter_Logo.jpg
                          michaliszissiou
                          we should still keep in mind how rapidly Cycles renderer is developing, right?
                          I noticed this artwork today, byn blender artist Spelle.
                          http://blenderartists.org/forum/attachment.php?attachmentid=271759&d=1384961721
                          • arail1A Offline
                            arail1
                            That is an incredibly impressive image!
                              http://www.blendernation.com/2013/12/07/sneak-peek-blender-toolbar-tabs/
                              New UI coming
                              • olisheaO Offline
                                olishea
                                About bloody time! This is the only thing that holds me back from being competent with blender.
                                oli
                                • andybotA Offline
                                  andybot
                                  New UI coming
                                  Looks like a nice evolution. Not sure Oli that it'll necessarily make Blender easier to learn. From what I could tell it doesn't fundamentally change anything about the UI, just makes it a bit easier to navigate.
                                    It's a pity that was not make from the beginning! πŸ˜’
                                      The level of commits for the next Blender is growing...
                                      Render time remaining now added
                                      Themeable UV editor
                                      Cycles speed improvement
                                      OSL improvements.
                                        michaliszissiou
                                        Christmas coming.
                                        A nice blender tutorial from Andrew Price
                                        I found it interesting, a good presentation of Sapling Tree blender editor.
                                        Some particles system
                                        Color indexing and some PPros (compositor)
                                        https://www.youtube.com/watch?v=5Yd7ad08e54
                                          Happy new year! 😎
                                          This guy is very good in Blender and speeching! β˜€
                                          A real entertainer! πŸ‘
                                            michaliszissiou
                                            Bisect tool in blender
                                            http://www.blendernation.com/2013/11/28/quick-tip-creating-stones-with-the-bisect-tool-part-1/
                                            • 7 / 9
