    Syd Mead's VEX (model progression)
    75 Posts 12 Posters 13.7k Views 12 Watching
    • tademaT
      tadema
      Looking good Bryan πŸ‘
      No pressure at all when the Crème de la crème of the car modeling world writes
      "I am watchin' you !" πŸ˜†
      John
      • Rafferty94R
        Rafferty94
        Looks really good Bryan! Looking forward to the updates..
        • Bryan KB
          If no one has any major objections or comments, this is the overall shape I'm proceeding with.
          In other words, this is the frame I will finish detailing.
          (never post hung over πŸ˜‰ )
          • Bryan KB
            Thanks guys, then I will move ahead with this shape. πŸ‘
            • Bryan KB
              Update
              • iichiversiiI
                iichiversii
                coming along nicely πŸ‘
                Bring on the Rain...
                • ely862meE
                  ely862me
                  Forgive me ,I have not watched carefully the pictures and the model, but i believe the side back panel is not broken like you did. I think it is one plane.
                  Care to send the model by pm or here if ok and I will try to adjust a bit ?
                  Elisei (sketchupper)
                  Come and See EliseiDesign
                  • Bryan KB
                    The problem is two-fold: Syd's drawings are forced perspectives as I found out doing a photo-match and neither exactly matches the other and the actual clarity of details leaves a lot to be desired. The best I could get from the photo-match was general dimensions.
                    The second part is the sides are actually warped trapezoids, so the only way SU can complete the surface is to divide it into a polygon. I tried several different ways to manually create the polygons and this was the best compromise I could get as I had the same issue with the front side panels.
                    It will have to do.
                    • Bryan KB
                      Update.
                      On Elisei's suggestions, I tried to tweak the rear side panel a little more. I like the new results, but still have the problem of it being a warped trapezoid. However, I do like the improvement. I also had the rear face too small, and enlarging it helped.
                      Other details added.
                      • ely862meE
                        ely862me
                        Much better .
                        For me , the upper edge and the lower edge look parallel .
                        • Bryan KB
                          Thanks again for the heads up Elisei. I was able to find a solution that resolved the warped trapezoid problem and now it looks right. πŸ‘
                          Various detailing roughed in.
                          • ely862meE
                            ely862me
                            No problem ! Nicely done !
                            • Bryan KB
                              Updates.
                              Once again, I am rebuilding some previous things as the proportions become more evident.
                              • Bryan KB
                                Speaking of which... proportion adjustments.
                                • Bryan KB
                                  Thanks for the help Elisei. It will take me a few days to dissect your model and incorporate it.
                                  Thanks again. πŸ‘
                                  • ely862meE
                                    ely862me
                                    I think yours is better, with just a few tweaks it will be great ! Afterall it is just a hand drawing and things might be bent a little !
                                    • Bryan KB
                                      I started a new job this week, so that's why there have been no updates.
                                      Will have some to show this weekend.
                                        Great model, good luck with the job.
                                        • ely862meE
                                          ely862me
                                          Congratulations on the job ! Keep up !
                                          • Bryan KB
                                            Thanks Mike and Elisei.
                                            Wheel links added. Minor scaling adjustments of various parts. More greeble blocked in.
                                            • 3 / 4
