    Syd Mead's VEX (model progression)
    75 Posts 12 Posters 12.0k Views 12 Watching
    • Bryan KB Offline
      @mike amos said:
      Cool kit but, sod mars and other off world jaunts, this would be MUCH better for the weekly shopping trip to tesco/asda et al.
      πŸ‘ πŸ˜†
      • Bryan KB Offline
        It's done. On to the main vehicle.
        • Bryan KB Offline
          Right now it's just a dog. And what do dogs say?
          Rough, rough. πŸ˜†
          I can see this one is going to take about a month as well.
          • Bryan KB Offline
            Update
            • ely862meE Offline
              ely862me
              I am watchin' you ! πŸ€“
              Elisei (sketchupper)
              Come and See EliseiDesign
              • tademaT Offline
                tadema
                Looking good Bryan πŸ‘
                No pressure at all when the Crème de la crème of the car modeling world writes
                "I am watchin' you !" πŸ˜†
                John
                • Rafferty94R Offline
                  Rafferty94
                  Looks really good Bryan! Looking forward to the updates..
                  • Bryan KB Offline
                    If no one has any major objections or comments, this is the overall shape I'm proceeding with.
                    In other words, this is the frame I will finish detailing.
                    (never post hung over πŸ˜‰ )
                    • Bryan KB Offline
                      Thanks guys, then I will move ahead with this shape. πŸ‘
                      • Bryan KB Offline
                        Update
                        • iichiversiiI Offline
                          iichiversii
                          coming along nicely πŸ‘
                          Bring on the Rain...
                          • ely862meE Offline
                            ely862me
                            Forgive me ,I have not watched carefully the pictures and the model, but i believe the side back panel is not broken like you did. I think it is one plane.
                            Care to send the model by pm or here if ok and I will try to adjust a bit ?
                            • Bryan KB Offline
                              The problem is two-fold: Syd's drawings are forced perspectives as I found out doing a photo-match and neither exactly matches the other and the actual clarity of details leaves a lot to be desired. The best I could get from the photo-match was general dimensions.
                              The second part is the sides are actually warped trapezoids, so the only way SU can complete the surface is to divide it into a polygon. I tried several different ways to manually create the polygons and this was the best compromise I could get as I had the same issue with the front side panels.
                              It will have to do.
                              • Bryan KB Offline
                                Update.
                                On Elisei's suggestions, I tried to tweak the rear side panel a little more. I like the new results, but still have the problem of it being a warped trapezoid. However, I do like the improvement. I also had the rear face too small, and enlarging it helped.
                                Other details added.
                                • ely862meE Offline
                                  ely862me
                                  Much better .
                                  For me , the upper edge and the lower edge look parallel .
                                  • Bryan KB Offline
                                    Thanks again for the heads up Elisei. I was able to find a solution that resolved the warped trapezoid problem and now it looks right. πŸ‘
                                    Various detailing roughed in.
                                    • ely862meE Offline
                                      ely862me
                                      No problem ! Nicely done !
                                      • Bryan KB Offline
                                        Updates.
                                        Once again, I am rebuilding some previous things as the proportions become more evident.
                                        • Bryan KB Offline
                                          Speaking of which... proportion adjustments.
                                          • Bryan KB Offline
                                            Thanks for the help Elisei. It will take me a few days to dissect your model and incorporate it.
                                            Thanks again. πŸ‘
                                            • 2 / 4
