    Syd Mead's VEX (model progression)
    75 Posts 12 Posters 12.0k Views 12 Watching
    • Bryan KB Offline
      @iichiversii said:
      Great work on the wheel Bryan πŸ‘
      Thank you iichiversii. I still feel kind of stupid because the result it not what I was looking for, but I only have two pictures to use as references.
      I will be refining the wheels until next week.
      Until I get tired of it. πŸ˜‰
      Just two more things... just two more... πŸ˜†
      • Bryan KB Offline
        x-ray
          Cool kit but, sod mars and other off world jaunts, this would be MUCH better for the weekly shopping trip to tesco/asda et al.
          • Bryan KB Offline
            πŸ‘ πŸ˜†
            • Bryan KB Offline
              It's done. On to the main vehicle.
              • Bryan KB Offline
                Right now it's just a dog. And what do dogs say?
                Rough, rough. πŸ˜†
                I can see this one is going to take about a month as well.
                • Bryan KB Offline
                  Update
                  • ely862meE Offline
                    ely862me
                    I am watchin' you ! πŸ€“
                    Elisei (sketchupper)
                    Come and See EliseiDesign
                    • tademaT Offline
                      tadema
                      Looking good Bryan πŸ‘
                      No pressure at all when the Crème de la crème of the car modeling world writes
                      "I am watchin' you !" πŸ˜†
                      John
                      • Rafferty94R Offline
                        Rafferty94
                        Looks really good Bryan! Looking forward to the updates..
                        • Bryan KB Offline
                          If no one has any major objections or comments, this is the overall shape I'm proceeding with.
                          In other words, this is the frame I will finish detailing.
                          (never post hung over πŸ˜‰ )
                          • Bryan KB Offline
                            Thanks guys, then I will move ahead with this shape. πŸ‘
                            • Bryan KB Offline
                              Update
                              • iichiversiiI Offline
                                iichiversii
                                coming along nicely πŸ‘
                                Bring on the Rain...
                                • ely862meE Offline
                                  ely862me
                                  Forgive me ,I have not watched carefully the pictures and the model, but i believe the side back panel is not broken like you did. I think it is one plane.
                                  Care to send the model by pm or here if ok and I will try to adjust a bit ?
                                  • Bryan KB Offline
                                    The problem is two-fold: Syd's drawings are forced perspectives as I found out doing a photo-match and neither exactly matches the other and the actual clarity of details leaves a lot to be desired. The best I could get from the photo-match was general dimensions.
                                    The second part is the sides are actually warped trapezoids, so the only way SU can complete the surface is to divide it into a polygon. I tried several different ways to manually create the polygons and this was the best compromise I could get as I had the same issue with the front side panels.
                                    It will have to do.
                                    • Bryan KB Offline
                                      Update.
                                      On Elisei's suggestions, I tried to tweak the rear side panel a little more. I like the new results, but still have the problem of it being a warped trapezoid. However, I do like the improvement. I also had the rear face too small, and enlarging it helped.
                                      Other details added.
                                      • ely862meE Offline
                                        ely862me
                                        Much better .
                                        For me , the upper edge and the lower edge look parallel .
                                        • Bryan KB Offline
                                          Thanks again for the heads up Elisei. I was able to find a solution that resolved the warped trapezoid problem and now it looks right. πŸ‘
                                          Various detailing roughed in.
                                          • ely862meE Offline
                                            ely862me
                                            No problem ! Nicely done !
                                            • 2 / 4
