    BuildEdge PLAN 3.0 Now Available!
    55 Posts 15 Posters 11.5k Views 15 Watching
      Seems the free demo is not 3.0 ?
      • aarondietzenA Offline
        aarondietzen
        [attachment=0:1n4od5hs]<!-- ia0 -->build.jpg<!-- ia0 -->[/attachment:1n4od5hs]
        Looks like it is not updated, yet. In all fairness, though, I only sent the updated RBZ to Rich last night, so he probably has not had a chance to update.
        "Imagination is more important than knowledge..."
        - Albert Einstein
        • KrisidiousK Offline
          Krisidious
          Where do you download if you're already a user?
          By: Kristoff Rand
            The latest version is now in the SketchUcation PluginStore...
              Hum hum 😄 (V8)
              Load free version here at PluginStore
              Seems BuildEdgeSketchup.BIM_v3.dll missing : where is it ?
              Erreur de chargement du fichier
              C;/Program Files/Google/Google SketchUp 8/Plugins/BuildEdgePlan/BuildEdgeSketchup.BIM_v3.dll
              127; La procédure spécifiée est introuvable.
              - C;/Program Files/Google/Google SketchUp 8/Plugins/BuildEdgePlan/BuildEdgeSketchup.BIM_v3.dll
               C;/Program Files/Google/Google SketchUp 8/Plugins/BuildEdgePlan/init.rb
              undefined method `SetSketchUpVersion' for BuildEdgeSketchup;Module
              Erreur de chargement du fichier BuildEdgePlan.rb
                Did you try restarting ?
                The dll etc is inside the RBZ if you open it...
                It should be in the plugin's subfolder..........
                  Damned that must be another thing because all is there! 😲
                  And by chance there is no accent on the path!
                  So...mystery!
                    But something curious look the positions of Slashes!
                    On my image path there are "" on the message error they are "/" !
                    Does this normal ?
                      Must be registered somewhere before using the free version ?
                      Another thing that I have never understand! 😮
                      Why the files needed (here Extentions..rb and sketchup.rb) are not in the original files!
                      That was the case for me! They were missing!
                      So I add them!
                      But alas that change nothing! Error message is the same! 😕
                      Does this version only for the 2013?
                        To answer various queries...
                        The file-separator on MAC is always /.
                        On PCs MS-DOS uses \ but \ or / will work.
                        Ruby tends to report with /, but it can cope with both formats.
                        The sketchup.rb and extensions.rb [and a few others] are shipped with SketchUp and they load from the Tools folder.
                        They should never come inside a plugin's archive. and they should never be found in the Plugins folder, or any of its subfolders.
                        If you have them in there remove them forthwith... checking that the Tools folder still has them in it.
                        These files add special functions to Ruby.
                        All Plugins and Tools folder's .rb files auto-load as SketchUp starts - it uses the $LOAD_PATH - the loading is done in alphabetical order, so those in the Plugins folder load before those in the Tools folder.
                        So if a script loads from the Plugins folder and it needs a function that one of the Tools folder's .rb files provide, then it will fail to load, because that .rb file's code hasn't yet been loaded.
                        So one way would round it would be to add code like load "sketchup.rb" to the start of code in the script, so its code is loaded before it is needed... BUT if lots of scripts did that 'load' then it'd slow down the auto-loading process unnecessarily, and quite noticeably too: So the method used is **require** "sketchup.rb" - this only loads the file IF it is not loaded already - BUT if an earlier script has already loaded it then it does not...
                          cadmunkey
                          Suitable for plans in metric or are all the doors/windows etc in feet and inches?
                            aarondietzen
                            Hum hum 😄 (V8)
                            Oh boy! We have tracked down a problem with Windows XP systems. Seems there was an issue with the way the Visual Studio built dlls or some such technical issue. Good news is we have a fix and will be releasing a new version today. If anyone is having this issue, just PM or email me (adietzen@keymark.com) and I will get you a fix, ASAP.
                            So sorry for any inconvenience!
                            - Albert Einstein
                              aarondietzen
                              Hi Munkey,
                              We defer to SketchUp units, so you can specify the door and window parameters in your preferred unit of measure.
                              - Albert Einstein
                                @aarondietzen
                                I have XP system so this explain that! 😉
                                So must I send you an email or the new version will available on the PluginStore ?
                                @ Tig : thx for these detailed infos! ☀
                                  aarondietzen
                                  @aarondietzen
                                  That would be it and we have a fix! I am sending the new RBZ in right now...
                                  Since I don't know when that will end up in the store, I can send you the RBZ if you want to send me an email address. Alternatively, you can download an updated installer here:
                                  (store.buildedge.com)
                                  It is marked as the "Update Installer" but it will install the full version as well.
                                  As always, please let me know what you think!
                                  - Albert Einstein
                                    That latest updated version is now in the SketchUcation PluginStore...
                                    • utilerU Offline
                                      utiler
                                      Hi Aaron, have watched the 3.0 videos and looks like a big leap foward!!
                                      For some reason though this is what I get when loaded? Seems the dialogue box is scrambled; I can't seem to be able to insert my serial number.
                                      Just Curious...
                                        I will try the uppdater 😄
                                        Much better... 👍
                                        Just a very anxious suspense ! 😲
                                        1 minute 40 seconds before something arrives after the first click on the icon !
                                        All is freezing then all works fine! 😄
                                        Never seen that for any plugin : I have tested some thousands! 😄
                                        Do you test something to Internet ? (I have a speedy connection)
                                        Tested on a not very old computer 😄 ( 3 years 5 cores)
                                        This is happening only at the start of a Sketchup session!
                                        After the first openning of the plugin it works normally at each call of the plugin! 😄
                                        Another thing: does it normal in the free demo to not have door, window, floor ?
                                        (colors image are mine in 2D prog changed 😉
                                          Bruce Watt
                                          Hi Aaron,
                                          if I am part way through my design using build edge and I need to close sketchup. When I re start sketchup and continue with my design do I loose the functionality of buildedge? Does it commit to sketchup on closing in other words.
                                          SKUP PRO 2021 latest version / update
                                          Windows 10 Pro
                                          Dell Alienware Aurora R10 AMD
                                          AMD Ryzen™ 9 3900X
                                          NVIDIA® GeForce RTX™ 2080 Ti 11GB GDDR6
                                            aarondietzen
                                            @bruce watt said:
                                            Hi Aaron,
                                            Hi Bruce,
                                            Closing SketchUp should not affect your BuildEdge data. You should be able to save, close, reopen and continue working. We only Commit when you tell us to!
                                            - Albert Einstein
                                            • 1 / 3
