    Video Card Question
    48 Posts 8 Posters 2.3k Views 8 Watching
    • soloS Offline
      @joe wood said:
      I don't know Solo, I even had to google PSU πŸ˜„Can I look it up in my computer specs somewhere?
      There should be a sticker on it, I do not know of anywhere one can check in windows however.
      • Joe WoodJ Offline
        Joe Wood
        yeah I can see a sticker up under the case but I can't read it unless I take it out.
        Joe Wood
        woodsshop.com/
        • Joe WoodJ Offline
          Joe Wood
          no numer, I only want the card, sorry, I don't know anything about replacing video cards or what to buy. I'm feeling pretty ignorant now.
          Solo, I've been googling what psu a dell dimension 4600 has, some are 250 watt and some 400 .. I downloaded the 4600 owners and service manuals, is it in there? Sorry I don't see it listed.
          Joe Wood
          woodsshop.com/
          • N Offline
            numerobis
            The GTX650 not available as AGP card. The latest AGP cards are some Radeon HD4xxx and GeForce 7xxx. Or do you plan to buy a new board now?
              Charlie__V
              IF it is a Dell computer, (I think you mentioned it is).....find the "service tag #" on the exterior of the case.
              It would be on a small decal about the size of a return address on a USPS envelope.
              Then, simply go to the Dell site.....support....service tag#....enter sevice tag #....viola...all or most specs. should still be available specific to your build.
              Charlie
              • Joe WoodJ Offline
                Joe Wood
                OK, it has a 250 watt psu.
                Joe Wood
                woodsshop.com/
                • jiminy-billy-bobJ Offline
                  jiminy-billy-bob
                  "AGP" and "PCI Express" are the type of connectors. AGP is outdated since several years. A PCIe card would simply not fit into your computer.
                  http://i.imgur.com/4Y7354q.jpg
                    Glenn at home
                    Did you open the case and verify?
                    • Joe WoodJ Offline
                      Joe Wood
                      no I haven't Glen, I'd need to remove it to see the sticker on the bottom. Too many connected wires has me intimidated!
                      I did google some numbers on the side of the psu
                      cn 0f0340-47890-353-2067
                      and found this
                      http://www.memory4less.com/m4l_itemdetail.aspx?itemid=1442482616&partno=0F0340&rid=88&gclid=CJWs-YDGzroCFUlyQgod8FQAIw
                      Joe Wood
                      woodsshop.com/
                      • Joe WoodJ Offline
                        Joe Wood
                        I asked this video card question at the Dell forum, and someone suggested this
                        "Money would be better spent finding a GX620 with Pentium D.
                        The 4600 is DDR with AGP.
                        The GX620 uses DDR2 and has PCI-E video and with Pentium D would be many times faster in all aspects and would have many video options that could be re used later in a newer better faster machine."
                        301 Moved Permanently
                        (www.amazon.com)
                        what am I looking at on that page? Isn't that tower the whole computer? For $83? That's right around what I was thinking of paying for the video card alone.
                        Joe Wood
                        woodsshop.com/
                          Glenn at home
                          You know Joe, getting a newer, used PC is not a bad idea. Here is a local CL add in your area that has 2 of those for $90 each.
                          craigslist | Page Not Found
                          (sandiego.craigslist.org)
                          They are older but they do use PCIe video cards (the newer ones) and they are dual core, 64-bit cpus which will be far and away better than your P4 based system. I really would not spend any money on that old system. I had one just like it and while it was a good PC for the 6 years I had it just got to a point where it was not worth upgrading it.
                          Search around a bit on CL and fins one local, this way you can maybe see it run and check it's condition before you buy.
                          Good luck πŸ˜„
                          • Joe WoodJ Offline
                            Joe Wood
                            Boy I don't know, then I'd have to transfer everything on this computer over onto the newer one and I've never done anything like that before. Is it that difficult?
                            Joe Wood
                            woodsshop.com/
                              Glenn at home
                              Yeah you'd basically have to reinstall all applications and then transfer all files as well. That is the worst part of getting a new PC. It can be a pain but it's worth it when you get better hardware.
                              • sketch3d.deS Offline
                                sketch3d.de
                                because of this investing in a new, capable PC which will last some time is probably a better choice then investing in some ol' stuff... desktops are cheap these times, this one w/ the GTX from above and SU will fly.
                                Norbert
                                • soloS Offline
                                  Actually setting up a new machine is therapeutic, especially if you get one with a larger HDD or multiple HDD's, you get a clean fast uncluttered machine to start with, you can organize the install as you please, put stuff in the right places, only load what you need resulting in a slick fast 3D machine.
                                    Glenn at home
                                    Good point from both Solo and Norbert.
                                    • Joe WoodJ Offline
                                      Joe Wood
                                      Well folks, I don't really need a fast slick computer, this one is doing just fine (especially after flashing the Bios whatever that means), except for the video card and even that is slowing my SUp only a little bit. I hardly ever do large complex models. Besides I want to get a laptop here pretty soon.
                                      so, I'm a little confused about which card to get, could I get a link to a card I can just order?
                                      Joe Wood
                                      woodsshop.com/
                                        sketch3d.de
                                        @joe wood said:
                                        ...except for the video card and even that is slowing my SUp only a little bit...
                                        the CPU is the crucial issue for speed in SU. The video system needs to provide reliable OpenGL support first, which automatically means a dedicated and therefore capable video card to some extent.
                                        The best/fastest/latest GeForce for ol' systems w/ AGP slot is the 7800 series. You can buy a new (expensive) GF 7800 GS at Amazon... or do a fall back to the cheaper and less power consumpting GF 7600 GS.
                                        Good Luck again,
                                        Norbert
                                        • 2 / 3
