    Sketchup and Blender
    extensions
    170 Posts 26 Posters 30.5k Views 26 Watching
      dedmin
      About units in Blender - this is very confusing for new users:
      http://www.katsbits.com/tutorials/blender/metric-imperial-units.php
      Importing Google SketchUp files into Blender 3D - advanced:
      http://www.katsbits.com/tutorials/blender/import-google-sketchup-kmz-models-advanced.php
        dedmin
        @solo said:
        And another thing, what software do folks use when doing a tutorial that shows what mouse and keyboard button is pressed?
        • michaliszissiouM Offline
          michaliszissiou
          OK, joining the club.
          There are many reasons to turn a geometry to quads.
          SketchUp supports n-gons based geometry.
          Blender also supports n-gons.
          The way to import the SUp n-gons to blender and continue to be N-gons is the Collada format.
          Import in blender as collada then.
          Enter edit mode, select all (A), press W menu/[remove doubles], select all again, [ctrl+N], this will turn all normals of faces outwards , in case something messed up in SUp.
          Now you are ready to go for a nice UV unwrapping. No need to import textures from SUp (it is possible) because the SUp default unwrapping can be automatically generated in blender. It is the cubic projection.
          The blender UV editor is one of the more powerful around and I suggest you to learn it.
          Now, you re ready to setup a scene, lighting and go for a Cycles rendering.
          And, more additional modeling of course.
          • JQLJ Offline
            JQL
            I tried exporting a model from SU to render in Blender, with little success. Is there a way to export cameras from SU to Blender? That was mostly where I stuck because everything was already set in SU.
            Thanks,
            JQL
            www.casca.pt
            Visit us on facebook!
            • soloS Offline
              Thanks,
              JQL
              Looking at the addons in Blender there are many importers and exporters, I wonder what it will take or who it will take to write one for Sketchup, one that will support layers, groups, components, camera's and even animations.
              • soloS Offline
                My first attempt at following a tutorial.
                I changed the obstacle to the Thea logo and opted to render with the Thea plugin and not Cycles as Cycles was still rendering after 15 minutes (too slow) and Thea completed it in just over 3 minutes.
                  Winner.
                  Show the blender mesh.
                  Mine way to quickly learn commands is with the dynamic menu. Hit space bar while in the viewport and start typing.
                  • soloS Offline
                    @rich o brien said:
                    Winner.
                    What is supposed to happen when you hit space, I get a window that opens but not sure what to do then.
                    Here is the screen shot.
                      You should see this command palette...
                      ...here you can type a word to see what the command is...
                      example...if you needed to merge verts hit space - type merge...
                      ...and you'll see the command is Alt+M
                      Great way to learn what is the shortcuts and the commands.
                      I'd really like to see the Thea Logo in edit mode.
                      Select it, hit edit and then hit / on the numpad to go into local view.
                      Take a screengrab while in edit mode so we can see the mesh.
                      • andybotA Offline
                        andybot
                        Woohoo!! Thanks for starting this thread Pete, glad to see Rich and Michalis right on board! I will be watching and participating as I can. I ❀ Blender!
                        • andybotA Offline
                          andybot
                          My tool of choice in SU is TIG's "Triangulate Faces" plugin. Before exporting anything to Blender that I will be editing in Blender, I always make sure I can see the entirety of my topology, and then make extensive use of the sandbox "Flip Edge" tool. I use TIG's obj exporter for my conversion, then import with the "keep vert order" option. (This is important for vray proxies, plus it helps keep the outliner neater.) Then in Blender: Mesh -> vertices - > "remove doubles", and Alt-J for tris to Quads.
                          • soloS Offline
                            I inserted it into post above, not much done to it from export, I figured it would be under water so it will be fine. πŸ˜•
                            • soloS Offline
                              Ooo, thanks, gonna try this.
                                Do you want my .blend file? It's a bit rough but you might see things that raise some questions?
                                • soloS Offline
                                  Yeah, always good to compare things and learn tricks, thanks
                                  • boofredlayB Offline
                                    boofredlay
                                    Yes, glad you started this thread Pete.
                                    I started learning Blender a few months ago and like everything I try to tackle I have to do it in small doses because of time issues.
                                    Anyway, I have been following the Blender Tutor http://www.blendertutor.com/page/4/?fp_type=news with pretty good results.
                                    I finished the coffee pot and am starting the SNES machine tutorial next.
                                    I think I have a better image at home but I am not at home now so...
                                      Here you go....
                                      thea-logo-su.zip
                                      Load file
                                      Press 0 for Camera view
                                      Press Alt+A to play animation
                                        • soloS Offline
                                          @rich o brien said:
                                          Here you go....
                                          [attachment=0:7zja5vc2]<!-- ia0 -->thea-logo-su.zip<!-- ia0 -->[/attachment:7zja5vc2]
                                          Load file
                                          That is a clean logo. Hmm, basic mesh with a sub-D modifier only.
                                          So this is modeled in SU, exported to Blender and added a modifier only?
                                          I'd love to sit next to you as you model this in SU as I cannot seem to get my head around what tools you used and your workflow, then I need to still figure out the material assigning in Blender, I did a tutorial this weekend and it's already forgotten. πŸ˜•
                                            Yes modeled in SU to a point just to figure out vert placement and form. Then into Blender for tweaking and some edge loops, creases and sub-d
                                            • 6 / 9
