    Search engine
    28 Posts 10 Posters 2.4k Views 10 Watching
    • N Offline
      notareal
      Am I blind or what, but I cannot see search with http://sketchucation.com/forums/viewforum.php
        It's......
        http://sketchucation.com/forums/search.php
          The search function should be in the header now....
          It uses Google Search so some testing by members would be appreciated
          • massimoM Offline
            massimo Moderator
            Works fine here on Firefox 24.
            EDIT: Damn, Pilou edited his post... ๐Ÿ˜†
              At least! My favorite tool is making its comeback! ๐Ÿ˜Ž
              Works fine on Google Chrome โ˜€
                @Pilou
                Not is impossible.
                @Massimo
                Bellissimo
                  And more results than 10 per pages ? ๐Ÿ˜„
                  As it's only text, 50 or better 100 will be fine for an speed over view! ๐Ÿ‘
                  • cottyC Offline
                    cotty
                    +1 ๐Ÿ‘
                    my SketchUp gallery
                    • massimoM Offline
                      massimo Moderator
                      The search engine stopped working. โ“
                        Tweaking. Google don't play fair
                          Gรกbor
                          It is back now.
                          • BoxB Offline
                            Thank God, does that mean Rich has stopped Twerking!
                              http://www.aceshowbiz.com/images/news/morgan-freeman-delivers-twerking-definition-on-hln-s-show.jpg
                              • massimoM Offline
                                massimo Moderator
                                @gรกbor said:
                                It is back now.
                                ๐Ÿ‘
                                  Seems the search engine is very very partial! ๐Ÿ˜ฒ
                                  Try with voluptuous
                                  You obtain just few result and alas not the very recent! ๐Ÿ˜ฎ
                                  And try with "search engine" itself, it can't find this post itself! ๐Ÿ˜ฎ
                                    Gรกbor
                                    The search engine is Google's custom search. As far as I know we do not have direct effect on what is indexed and what is not indexed by it. The Google algorythm decides... (anyhow I'll have a look into it if there is any way to influence it)
                                    For search tasks what require more accuracy and not flexibility the "old" PhpBB search engine is still available at:
                                      very cool : works very fine! ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                                      But where is now an icon or a clickable link about this old search engine ?
                                      (except the post above! ๐Ÿ˜‰
                                        Gรกbor
                                        At the moment this link shows up only if you execute a standard search (e.g: "New Posts", "Your Posts", etc.) at the top of the result list as a "Return to advanced search" link.
                                        If there is a need to insert a direct link to it on the other forum pages I'm sure we can find a place for it. The reason why we changed to Google's custom search is because there were many complains about the flexibility of the original PhpBB search engine.
                                          yes an icon on the first page start for an direct advanced research will be very cool ! ๐Ÿ˜Ž
                                          • BoxB Offline
                                            You could just make it a favourite or bookmark depending on what browser you use, then you don't even need to be on SU to get to it.
