    Can Any Confirm Survey Tools Working in 2013?
    29 Posts 5 Posters 2.2k Views 5 Watching
      So what happens if you click on it in the menu the next time? Does it work from there?
      • KrisidiousK
        Krisidious
        No, same deal.
        By: Kristoff Rand
        • BoxB
          You don't happen to have edges turned off?
          • KrisidiousK
            Krisidious
            Nope... Under View>Edge Style> Edges is checked.
            By: Kristoff Rand
              Working fine for me too...
              Win7 v2013.
              If you have the Ruby Console open as you use it are there any error messages ??
              • KrisidiousK
                Krisidious
                @dist = 100'
                @cbMajor = North
                @cbDeg = 68
                @cbMin = 45
                @cbSec = 20.0
                @cbMinor = East
                @cbDMS = 68.7555555555556
                @tbDeg = 68.7555555555556
                @subDeg = 291.244444444444
                northAngle = 0.0
                @subDeg = 291.244444444444 - modified for SketchUp's North direction
                Error: #<ArgumentError: wrong number of arguments (2 for 1)>
                C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/surveytool.rb:243:in offset' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/surveytool.rb:243:in drawline'
                C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/surveytool.rb:213:in sub2subN' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/surveytool.rb:197:in tb2sub'
                C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/surveytool.rb:168:in cb2tbC' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/surveytool.rb:161:in cb2tbB'
                C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/surveytool.rb:127:in cb2tbA' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/surveytool.rb:105:in distDialog'
                C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/surveytool.rb:70:in activate' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/surveytool.rb:260:in select_tool'
                C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/surveytool.rb:260:in `surveytool'
                C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/surveytool.rb:269
                By: Kristoff Rand
                  I get this in the console when I run it.
                  @dist = 100'
                  @cbMajor = North
                  @cbDeg = 68
                  @cbMin = 45
                  @cbSec = 20.0
                  @cbMinor = East
                  northAngle = 0.0
                  Save parameters you used but no errors. Weird.
                  • KrisidiousK
                    Krisidious
                    That's just a random bearing... I've tried other true ones and other fake ones. same thing.
                    By: Kristoff Rand
                    • Chris FullmerC
                      C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/surveytool.rb:243:in `offset'
                      It sure looks like a plugin you've recently installed has overwritten the Point3d#offset method.
                      You're gonna have to figure out what plugins you've installed most recently and uninstall them. Or uninstall them little by little to figure out which it is I think.
                      • KrisidiousK
                        Krisidious
                        Son of a... I have no idea...
                        By: Kristoff Rand
                          Put your plugins and extensions into sets in the SCF Plugin Store tool. Leave the Survey Tool out of the sets. Disable the sets, shut down and restart SketchUp and see that Surveytool works. Then enable a set and try again. Keep going until Surveytool quits working.
                          • KrisidiousK
                            Krisidious
                            I already did that Dave... And when I restarted all my plugins were enabled again. I'll try again. Why do I get the feeling Tig is getting ready to tell me I don't have admin rights to SU?
                            By: Kristoff Rand
                              It sounds like you didn't make the sets like I suggested and have the plugins really disabled. If they were disabled, they wouldn't load when you start SketchUp the next time.
                              • KrisidiousK
                                Krisidious
                                Yeah, after I restart all the plugins are still enabled.
                                I did all plugins except survey. I need to make multiple sets?
                                By: Kristoff Rand
                                • KrisidiousK
                                  Krisidious
                                  Didn't realize I should do both extensions and plugins. Disabling extensions worked... Plugins staying enabled after restart. Survey tool still doesn't work.
                                  By: Kristoff Rand
                                  • BoxB
                                    You can always do it the old way, rename your plugin folder to something else, like PluginsFull, make a new empty one and put the survey rb in it and see if it works, if it does then you know you need to find the errant plugin.
                                    • KrisidiousK
                                      Krisidious
                                      Yup... That did it. SO I guess this plugin that is causing the issue is also affecting Plugin Installer. Well at least I can get my survey done now. Thanks guys.
                                      By: Kristoff Rand
                                        Sorry, I had to go fix an anesthesia machine so the gas passer could do their job. πŸ˜„
                                        I suggested breaking your collection of plugins into several sets so you could put only a few plugins back at a time. That way, when the Surveytool quit working you would know that the offending plugin was in the last set you enabled. As long as it is working, though... You can work on sorting out which bad plugin you've got at your leisure.
                                        • KrisidiousK
                                          Krisidious
                                          Yeah it would make it much easier if I could use the plugin installer to do the sets. I'll report back on who the culprit is.
                                          By: Kristoff Rand
                                            The Plugins Manager and its Sets will NOT work unless you have FULL read/write security permission to the Plugins folder.
                                            With appropriate Admin privileges...
                                            context-menu > Properties > Security > Edit...
                                            Give every user/group listed FULL permissions.
                                            Also set SketchUp.exe to 'always run as administrator' in Properties > Compatibility
                                            The failure to keep the Disabling of Plugins or using Sets is a clear indication you have inappropriate security settings for your Plugins folder...
