Can Any Confirm Survey Tools Working in 2013?
Can Any Confirm Survey Tools Working in 2013? Or does anyone know of a current conflict with another plugin?
I think the tool can still be found here.
Do you know of another survey tool?
Are you talking about this Surveytool? It seems to work just fine in 2013.
That's the one... What am I doing wrong? Suddenly it doesn't work in 8 or 13.
Not holding your tongue right, probably.
Maybe it's being affected by one of those plugins that screws up others like Sketchy Physics or V-ray?
FWIW, I just checked it on my Mac install of 2013 and it works fine there, too.
I tried using Sketchucation plugin installer to disable all other plugins and it still didn't work. I put in my first bearing and hit OK, then the dialog disappears and the line never shows up. However when I go to select the tool again it is already checkmarked next to the tool name in the drop down. As if I was mid tool use. Something is fishy in Denmark...
So what happens if you click on it in the menu the next time? Does it work from there?
No, same deal.
You don't happen to have edges turned off?
Nope... Under View>Edge Style> Edges is checked.
Working fine for me too...
Win7 v2013.If you have the Ruby Console open as you use it are there any error messages ??
@dist = 100'
@cbMajor = North
@cbDeg = 68
@cbMin = 45
@cbSec = 20.0
@cbMinor = East
@cbDMS = 68.7555555555556
@tbDeg = 68.7555555555556
@subDeg = 291.244444444444
northAngle = 0.0
@subDeg = 291.244444444444 - modified for SketchUp's North direction
Error: #<ArgumentError: wrong number of arguments (2 for 1)>
C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/surveytool.rb:243:inoffset' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/surveytool.rb:243:in
drawline'
C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/surveytool.rb:213:insub2subN' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/surveytool.rb:197:in
tb2sub'
C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/surveytool.rb:168:incb2tbC' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/surveytool.rb:161:in
cb2tbB'
C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/surveytool.rb:127:incb2tbA' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/surveytool.rb:105:in
distDialog'
C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/surveytool.rb:70:inactivate' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/surveytool.rb:260:in
select_tool'
C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/surveytool.rb:260:in `surveytool'
C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/surveytool.rb:269 -
I get this in the console when I run it.
@dist = 100'
@cbMajor = North
@cbDeg = 68
@cbMin = 45
@cbSec = 20.0
@cbMinor = East
northAngle = 0.0
@subDeg = 291.244444444444 - modified for SketchUp's North directionSave parameters you used but no errors. Weird.
That's just a random bearing... I've tried other true ones and other fake ones. same thing.
C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/surveytool.rb:243:in `offset'It sure looks like a plugin you've recently installed has overwritten the Point3d#offset method.
You're gonna have to figure out what plugins you've installed most recently and uninstall them. Or uninstall them little by little to figure out which it is I think.
Son of a... I have no idea...
Put your plugins and extensions into sets in the SCF Plugin Store tool. Leave the Survey Tool out of the sets. Disable the sets, shut down and restart SketchUp and see that Surveytool works. Then enable a set and try again. Keep going until Surveytool quits working.
I already did that Dave... And when I restarted all my plugins were enabled again. I'll try again. Why do I get the feeling Tig is getting ready to tell me I don't have admin rights to SU?
It sounds like you didn't make the sets like I suggested and have the plugins really disabled. If they were disabled, they wouldn't load when you start SketchUp the next time.
Yeah, after I restart all the plugins are still enabled.
I did all plugins except survey. I need to make multiple sets?
Didn't realize I should do both extensions and plugins. Disabling extensions worked... Plugins staying enabled after restart. Survey tool still doesn't work.
