    [Plugin] Zorro2 (beta)
    314 Posts 154 Posters 381.0k Views 154 Watching
      What are you modeling that you have that many components?
      Of course one thing that might be driving the numbers up is nested components. You could take a look at the Outliner under the Window menu and check that out. It may be that even components that don't need to be exploded could tolerate having some of their child components exploded. Or maybe you need to explode those child components in the larger components on the cut line.
      If you are going to be cutting the model with Zorro anyway, maybe you should delete components on the camera side of the cut line before running Zorro.
      • N Offline
        Nina100
        It’s a vaulted ceiling church renovated into a shop.
        I think the clothing and small details I added to the shop mainly from Google warehouse have upped the component amount.
        Also I created all the different areas in small pieces, made each bit as an individual component then joined the pieces to make more components. Bit component happy lol I never knew I would later have to delete them. Is this what you mean by “nesting”?
        That’s a really good idea to delete the stuff on the side that Zorro will be cutting, as the shop is symmetrical so that should half the amount of components
          It might help to think about components like this:
          A simple component consists of some edges and faces. When you make a component (or a group, for that matter), it's like you've wrapped those edges and faces in clear cellophane wrap. As you know, to make changes to the component you must first open the component for editing. You're opening the wrapper to gain access to the edges and faces inside. Now suppose you take several components and wrap them up in a larger wrapper. You now have a nested component.
            LSWABY
            Cannot figure this plugin out, it crashes everytime I try to make a cut.
            It works on simple geometry (a box) but with a reasonably detailed model it fails and I'm given the bug splat report.
            I'm using SU13 and I've tried ungrouping all elements within the model, still no luck.
            Any ideas guys?
            • cottyC Offline
              cotty
              Did you try to scale the model up before using the plugin?
              my SketchUp gallery
                babak
                Here is my solution for getting no bugsplat whatsoever and with all my models : triangulating all the faces.
                To do this the quickest way, I export the model as a 3DS model whith these options ticked to keep a good UV mapping :
                • Export Full hierarchy
                • Export two-sided faces
                • Export Texture Maps
                • Favor Preserving Texture Coordinates
                Then I import it back whith merge coplanar faces unticked (very important because it would suppress all triangulation done while exporting !!!)
                To get rid of all the unnecessary edges visually, I use ThomThom's CleanUp plugin with once more merge coplanar faces unticked but whith option smooth edge by angle raised to 20%.
                Then I use Zorro2 and cut and cut and cut and never get any bugsplat anymore........
                Hope this help!
                I would like to thank a million times all the ruby coders for their unvaluable work!
                  jackwatson
                  The 'free hand' zorro cut tool works well for me, but I get an instant bugsplat when I try to use the section plane to cut the model - even if it's a simple 6 sided box.
                  Even tried babak's workflow above but am experiencing the same problem. I'm on SUpro 2013.
                  Anyone experiencing the same thing?
                    tianamazzi
                    YOU ARE AN AMAZING HUMAN BEING.
                    • U Offline
                      unknow179
                      thanks so much! 😄
                        architectcee
                        may i ask why the plugin result on a bugsplat when i try to cut it by zorro?? is there anybody can help me to this? hope for your help 😄 thank you
                          Zorro isn't invincible.
                          You can try and remove parts of the model you don't need before running it.
                          Also don't try to cut very small complex geometry link plants because this can result in tiny geometry that fails, as well as taking ages to do...
                          Give Zorro a chance and it will work...
                          How complex is what you are hoping to cut ?
                          Have you firstly deleted hidden entities, purged the model and fixed-problems etc...
                            rekin0
                            wa~~~~~~~~THANK YOU!, will definitely give this awesome plugin a try!
                              thandi_92
                              I am trying to install the plugin for Zorro2 on my Mac book OSX for Sketchup 2013, but when I click on the download link it keeps showing in my 'Downloads' folder as a plain text file. Can anyone help me?
                              Thanks in advance!
                                Dimethil
                                Hi.
                                I guess it happened to others too, but this plugin makes crash my sketchup when used in large models ( >20Mo) sketchup freezes with the message " Making unique components and deleting groups and components behind section plane"
                                how can I help sketchup to slice the model ? If I explode all components, will it change anything ?
                                thanks
                                  Work on a copy.
                                  Try exploding everything back into raw geometry.
                                  Also use Model Info > Statistics > 'Purge Unused'
                                  and 'Fix Problems'
                                  It may help, but you might still have issues...
                                  There are limits !
                                    marcie
                                    hello, how can i download Zorro2. I have tried it, but nothing happens.
                                      Marcie, what do you mean you tried it and nothing happens. How did you try downloading it? What did you do after downloading it?
                                      • N Offline
                                        Nilez83
                                        Hi people,
                                        I get the message "Unzip error: could not unzip archive" when trying to install zorro2 from the pluginstore inside SU2014. In SU2013 it works fine. I tried just installing the .rb file in the plugin folder manually but the plugin doesn't show up in SU2014 after a restart. Anyone else getting this error?
                                        Regards,
                                        Niels
                                          What Plugins folder are you expecting it to be in ?
                                          It should be in the Users one ?
                                          If you download the RBZ file from the PluginStore, then use the native Preferences > Extensions > Install... button, what happens ?
                                          The Unzip error shows that the RBZ couldn't be unzipped using the API RBZ installer, which is in essence the one used by that button 😕
                                          • N Offline
                                            Nilez83
                                            Hi TIG,
                                            I've put the file in the \program files\Sketchup\Sketchup 2014\plugins folder. I downloaded the file as .rb not rbz, from the first post of this thread. Because I don't have it as a rbz file it doesn't show up when I try to install it using preferences>extensions>install.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 13 / 16
