    Rope relief on wood
    15 Posts 7 Posters 517 Views 7 Watching
    • H Offline
      hulahopka
      Hi. Is any plugin or shortcut to make rope and that rope cut out from other object ? Like substract tool ?
      I mean similar like on picture, but I want that be engraved IN the wood ? (reverse like on picture)
      thank you
      • yorik1984Y Offline
        yorik1984
        http://3dalbertsoft.wordpress.com/plugins/
        • H Offline
          hulahopka
          👍 @yorik1984 Txh
          • emerald15E Offline
            emerald15
            I think there's also a article on just this subject in a back issue of CatchUp
            • H Offline
              hulahopka
              @emarald15 Thank you, are you shure is on last CatchUp ? Becasue I cant find in last ?
              thx
              edit: Is that SuSolid ?
              • cottyC Offline
                cotty
                It's in Vol. 10 (05-2012) page 11
                my SketchUp gallery
                • S ShepherdS Offline
                  S Shepherd
                  I'm wondering if something like this could suffice. One simple shape array copied.
                  SS
                    I think for this sort of thing, Scott is on the right track. A simple shape arrayed along like that should certainly get the point across. There's no need for the excess geometry that would be created by drawing a helix.
                    • H Offline
                      hulahopka
                      Maybe is ths better, I make something similar, and Is close to this what I try, normal need fine-tunning, but how I engraved that patern on gray object (I must flip around for 180 deg) with usual tools not go, becasue one object is not solid.
                      Must chek if is any plugin for non-solid objects.
                        I didn't understand that but if you want the rope pattern recessed in the wood, select the yellow things and flip them along the blue direction. Then move them down into the gray and intersect them. Delete what you don't need.
                        Learn to use the native tools. Don't be searching for plugins to do what you haven't learned how to do. You'll never know what is possible.
                        • H Offline
                          hulahopka
                          Yes understand that, but now I think I was do something wrong, because now this substract tool work even if I join that elements in each other.
                          Thanx for this, I must figure out what I do wrong before.
                          • cottyC Offline
                            cotty
                            Which tool did you use for this?
                            my SketchUp gallery
                            • H Offline
                              hulahopka
                              I use that regular Substract tool
                              edit: LOL Im wrong all the time, is Subtract tool, sorry
                              • BoxB Online
                                That is one of the Solid Tools, your profile says you are using Free/Make. Be aware that if that is the case and you are still in the trial period, when it runs out you will lose those tools or have to buy pro. Unless your profile is wrong and you do in fact have the Pro version already.
                                • H Offline
                                  hulahopka
                                  Yes i got pro in this moment, I got Hard Disk crash 2 weeks ago and reinstall complete system from scratch http://sketchucation.com/forums/viewtopic.php?f=79&t=54625#p495280
