    1.3k Posts 300 Posters 3.2m Views 298 Watching
    • U
      uniflipp
      @antonio555 said:
      Hi. I use Curviloft 1.2 d. It works good, but I see the error every time, when I start work in my ScetchUp 8.
      Error Loading File bootstrap_Curviloft.rb
      uninitialized constant Curviloft::T6Error Loading File CurviloftAlgo.rb
      uninitialized constant Curviloft::T6Error Loading File CurviloftCurveMover.rb
      uninitialized constant Curviloft::T6Error Loading File CurviloftPalette.rb
      uninitialized constant Curviloft::T6Error Loading File CurviloftTool.rb
      How can I improve this?
      Thank You.
      Be sure to extract the folder CURVILOFT_Dir_12 into the plugins folder. I extracted the *.rb files straight into plugins at first and got the same errors.
      • W
        woodmaster2013
        I just install curviloft plug in and I cant see in my sketchup window. Any comments please? im a newbie here. Thank you admin ... πŸ˜’ πŸ˜’ πŸ˜’
          Mvmcneil
          I am testing a lofting workflow on simple geometry and Sketchup keeps crashing when trying to loft simple lines.
          The process is this:
          Draw a line
          copy 4 times some distance
          move 3 lines vertically up some to distance
          select each line in sequence left to right
          run curviloft
          The tool activates then hangs sketchup. If I loft arcs or other shapes it seems to work fine.
          I am using Sketchup 8 and Sketchup2013 on OSX 10.8.5. Both seem to be affected.
          Thanks,
          Mike
          • cottyC
            cotty
            Some more infos woudl help us to help you (how did you install it, ...)
            run curviloft
            Try it the other way round: run curviloft and afterwards, select the lines in the right order.
            my SketchUp gallery
              As cotty says, more information would be useful. I expect you've not installed it correctly and/or you didn't bother to install the required LibFredo6 files.
                Draw a line
                run curviloft
                Thanks,
                Mike
                How about posting an example SKP file of what you tried to describe?
                  Mvmcneil
                  Draw a line
                  run curviloft
                  Thanks,
                  Mike
                  The file is not complicated is it only 5 lines and nothing more and it is a fresh file just after Sketchup starts. This is created in Sketchup 8.
                  I did try as Cotty suggested above to run Curviloft then select the lines. It worked and didn't crash Sketchup, but other geometry seems to work without running Curviloft first.
                  Mike.
                  lines-test.skp
                    It may not be complicated but you don't describe which direction you copied the lines or how far. why would you even want to use Curviloft of those lines? What sort of result are you expecting?
                      Mvmcneil
                      I am using a workflow process that is not uncommonly used in Rhino to connect two planes or surfaces without using arcs. I am trying to use simple geometry as a test first before it would be used later on a more complex model. I like to test things like this out on simple models before I try incorporate it into my modeling process, and I noticed this was causing sketchup to freeze on OSX. I am not sure if the same behavior happens in Windows as I am not at work to try it in that environment.
                      Mike.
                      • jgbJ
                        jgb
                        Draw a line
                        run curviloft
                        Thanks,
                        Mike
                        I do not understand what you think CL will do with a set of unconnected lines. CL needs a closed perimeter of some sort to create the intervening mesh. With 5 parallel unconnected lines, CL can do nothing. I tried it and got the usual CL "I'm stumped" color codes. It did NOT hang my system.
                        jgb
                        • BoxB
                          Selected the correct way it creates this, but the wrong way freezes SU.
                            It works fine for me, too.
                            It doesn't need to be a closed loop.
                            lines-test~.skp
                              jasonotero247
                              hello,
                              I autoinstalled Libfredo 5.2 and curviloft using skecthucation pluginstore 2.0. But now I am having trouble locating them in sketchup in order to begin using them. Can anyone help. Thank you.
                              • Jason
                                Did you read the first post in this thread? It tells you where to look.
                                  jasonotero247
                                  I did look under the tools tab and there is nothing there.
                                  I am using Bootcamp, Windows 7, SU 2013 and using the sketchucation plugin store to autoinstall the plugins.
                                    daloop
                                    Hi everybody,
                                    I have the same problem as Missy_X a few posts above.
                                    Whenever I activate one of the Curviloft functions in SU2013 (Windows 7, 64Bit), the "Curviloft: Temporary" window pops up immediately. I don't get the usual Fredo-Bar on top of the editor and the plug-in does not work. I can select edges behind the popup, but there's no preview and no lofting.
                                    The Ruby console shows nothing at all. I do have all the latest versions (including libFredo 6.5.2) installed.
                                    This is going on for a few days now. The plugins used to work fine. My current workflow relies on setting up 3D-Bezier curves and skinning them with Curviloft.
                                    Any help would be greatly appreciated.
                                    • fredo6F
                                      @daloop,
                                      Could you post an exmaple of the error traces (there is the button in the temporary window to export the trace file).
                                      Thanks very much
                                        daloop
                                        Thanks for your support.
                                        Sorry, but I can't find any buttons on the window:
                                        • fredo6F
                                          Then, could you post the model you are working on.
                                            daloop
                                            OK, here we go:
                                            Bezier12.zip
                                            • 45
                                            • 46
                                            • 47
                                            • 48
                                            • 49
                                            • 65
                                            • 66
                                            • 47 / 66
