    [Plugin] Lamella Roofs
    63 Posts 25 Posters 54.8k Views 25 Watching
    • T
      timwarner
      Nice surprise to go away into the Ontario wilderness for a week's canoeing, and come back to find a problem has been raised and resolved without my doing anything. Thx, all!
      • flyer50F
        flyer50
        @tig said:
        If you implement these general changes this has the basis of a useful toolset...
        Sorry if I disturbe you . I try to make all your suggestions but I can't solve the problems. my file seems to be different and I can't update it.
        My poor knowledge is also a big problem.
        My program also don't give any results, may be it is an incomplete version.
        Can you please upload the correct file that you are using already updated?
        Tanks a lot
        Flyer
        • Chris FullmerC
          The file is attached to the post here:
          404 Not Found
          (sketchucation.com)
          The very first post in this thread. Download it and install it. Look on youtube or somewhere for plugin installation help. Good luck!
          • flyer50F
            flyer50
            404 Not Found
            (sketchucation.com)
            Thank for your replay
            I use win7 and SU8
            I have already installed many time the program and also the one from the link you suggest but I have always the same problem:
            I can't see any drawing on the screen
            I did these tests :
            on the screen I draw one only component (cube) and when I select lamella.rb from the plugins list.
            the component (cube) disappear from the screen,
            the data input masks are anabled and I use the default settings,
            from the rubi console I can see that the program il working but it does not finish the job.
            on the rubi console I have this report:
            http://www.filedropper.com/lamellabroken
            I removed all plugins ( they are a lot ) except lamella.rb :
            the program can complete its job,
            at the end I can see on the screen the component (cube) that was previous cancelled,
            in the rubi console I have the following report :
            http://www.filedropper.com/lamellacomplete
            but still I don't see the drawing of the program
            After I reinstall all the plugins one by one but when I reinstall sketchyphisics the lamella plugin stops again.
            Now sketchyphisics is removed
            thanks a lot for your help
            • flyer50F
              flyer50
              I have solved and now it is working
              the problem was on the dimentions
              Ciao Flyer
                Works fine! 😎
                You must put an alert message when 0Β° is entered for the Screw Angle as nothing is done! πŸ€“
                Funny things arrive when you take Screw Angle = 1Β° πŸ˜„
                • flyer50F
                  flyer50
                  Sorry to distrube again
                  for two days the plugin was working
                  but now it stops again and in ruby console I can see
                  Compound mitre saw cuts (Option A)
                  Horizontal angle 39.68
                  Vertical angle 93.62
                  Compound mitre saw cuts (Option B)
                  Horizontal angle 5.65
                  Vertical angle 39.82
                  Error: #<NoMethodError: undefined method make_unique' for nil:NilClass> D:/Program Files/sketchup/Plugins/lamella_roof.rb:289:in lamella_roof'
                  D:/Program Files/sketchup/Plugins/lamella_roof.rb:1038
                  Pls. how can I solve this problem?
                  Flyer
                    Have you recently installed or enabled a new app, like Sketchy Physics or a nascent BIM tool ?
                    It looks like the code is first copying a group and then using make_unique on it.
                    The API's group.copy returns the new group, so that can then be used with the method .make_unique, BUT some tools [like SP] mess with some native methods and return nil rather than the new group, so things fail...
                    Try uninstalling the recent/problem tools and retest...
                    • flyer50F
                      flyer50
                      Yes unfortunately.
                      I removed bim-tools.rb program and in ruby console I have the following text, but the program can complete the cycle... and I can see the model
                      WARNING: make_unique is a deprecated methodof Sketchup:Group
                      (x,y) coordinates of vertices on the face of the lamella
                      -568.80, 142.75
                      -554.67, 0.00
                      grazie
                      Flyer
                        Some of these half-baked BIM tools add observers and/or mess with some of the native API methods.
                        In the Lamella tool's code there is probably a cp=group.copy...cp.make_unique code-combo which is being messed up by this [unfairly!]. the group.copy should return a reference to the new group, if the method is messed up it can return 'nil', then the cp.make_unique fails, as will any further operations using 'cp' as the new group's reference, which now isn't the expected 'Group' object but a 'Nil' object ! ...
                        The Console output about 'mitering' is the tool's output to report what it's doing.
                        The 'warning' about 'deprecated-method' is a known error from the API - sometimes groups copied via the API MUST be 'made unique' - otherwise changing one changes the others[s] - just like component-instance editing does. So the warning is 'spurious'...
                        There now seems nothing of concern there.
                        • flyer50F
                          flyer50
                          Thanks for your welcome help
                          ciao e grazie
                          flyer
                            rv1974
                            It produces very nice geometry πŸ‘
                            I wish this tool could generate LR based on given surface.
                            • Q
                              qn
                              Excellent...
                                johnminister
                                Some help please?
                                Error after running ruby?
                                lamella_roof
                                Error: #<NameError: undefined local variable or method `lamella_roof' for main:Object>
                                (eval)
                                Sounds simple to solve but how?
                                  Check under Security for permission. Are full permissions granted for all users?
                                  Do you have SketchyPhysics installed? If you look back through the thread you'll see that others found sketchyPhysics caused problems with this plugin.
                                    johnminister
                                    The plugin Lamella_roof is not working at all under the new Sketchup pro 2013.
                                    Sketchup itselve stops completely.
                                    I had no problems with Sketchup 8!
                                    Has anyone else the same experiance when upgrading to version 2013?
                                      johnminister
                                      @johnminister said:
                                      Some help please?
                                      lamella_roof
                                      (eval)
                                      Thanks Dave, I install sketchpro 8 back and it is working.
                                      Has someone used it win Sketchpro 2013? It's not working?
                                        johnminister
                                        Still not working in a clean 2013, it is in sketchpro 8?
                                        Got a complete hangup with a error report back and had to start sketchup again.
                                          I just tested it on my Mac with SU2013 and it works fine. You didn't answer my question about having SketchyPhysics.
                                            johnminister
                                            Dave,
                                            As I wrote I had a clean install which is not holding any plugins except the roof one.
                                            It was working in windows sketchup 8 and not in 2013.
                                            After excuting the roof plugin sketchup was more sketchdown.
                                            I was asked to send a error file thats it.
                                            • 3 / 4
