    [Plugin] Lamella Roofs
    63 Posts 25 Posters 54.8k Views 25 Watching
      Post a screen shot of your Plugins folder showing the file installed. Make sure extensions are being shown.
      And you did actually close SketchUp and reopen it? You didn't just minimize it?
      • V
        victor hugo
        Dave.
        I had some extensions unloaded........ load them and restarted SU and is working now...
        Thanks.
          There's no way in the world we could have helped you without knowing that. πŸ˜’
          I'm glad it's working now.
          • T
            timwarner
            Hi Dave R,
            My understanding from this exchange is that the problem was related to Victor Hugo's plugin folder, but is there anything I should do to make this plugin more robust?
              Hi Tim,
              No, your plugin is just fine. There's nothing you could do in your script to prevent a user from unticking boxes in the Extensions list under Preferences. V.H.'s problem wasn't specific to your script. It just happened yours is the one he was trying to use when he discovered he had a problem.
              • P
                prousteilcalamaro
                Hi Tim,
                Your plugin seems very nice, however I've a problem in executing it.
                After the two windows for the parameters (I leave them as default), the plugin stops working, no drawing is produced and the Ruby Console shows an error as follows:
                Error: #<NoMethodError: undefined method make_unique' for nil:NilClass> C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/lamella_roof.rb:289:in lamella_roof'
                C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/lamella_roof.rb:1038
                I'm using SU 8 and the new version of your plugin.
                Is something wrong with my SU preferences? I've a lot of plugins loaded.
                Let me know how to solve the problem (I'm not a programmer).
                  There's nothing wrong with Tim's plugin. It works just fine on SU 8. Considering that there's not much to installing it, I suspect you have another plugin that is causing the problem. There are some plugins that are known to cause other plugins to fail. SketchyPhysics is one.Matchbox_r1.1 is another. There are more. Perhaps you could post a screenshot of your Plugins directory and we'll be able to tell you which one it is.
                    Sounds like SketchyPhysics to me - that is known to mess with the base class/methods - like 'group.copy' which should return a reference to the 'new-group' but after the ill-advised reworking it returns 'nil'... so then when some legit code tries to do something to the copy
                    [like '.make_unique'] it fails because now it's 'nil' and not 'new_group'.
                    It could be relatively easy to fix this but the authors of this and some other 'rogue' scripts have either lost interest, or simply don't care about others and their legit tools, which expect the API to work as it ought...
                    • P
                      prousteilcalamaro
                      Thank you very much!
                      I had SketchyPhysics in my Plugins folder. I removed that plugin (I don't need it for my actual project) and Lamella Roof works fine: it's a great plugin.
                      • T
                        timwarner
                        Nice surprise to go away into the Ontario wilderness for a week's canoeing, and come back to find a problem has been raised and resolved without my doing anything. Thx, all!
                        • flyer50F
                          flyer50
                          @tig said:
                          If you implement these general changes this has the basis of a useful toolset...
                          Sorry if I disturbe you . I try to make all your suggestions but I can't solve the problems. my file seems to be different and I can't update it.
                          My poor knowledge is also a big problem.
                          My program also don't give any results, may be it is an incomplete version.
                          Can you please upload the correct file that you are using already updated?
                          Tanks a lot
                          Flyer
                          • Chris FullmerC
                            The file is attached to the post here:
                            404 Not Found
                            (sketchucation.com)
                            The very first post in this thread. Download it and install it. Look on youtube or somewhere for plugin installation help. Good luck!
                            • flyer50F
                              flyer50
                              404 Not Found
                              (sketchucation.com)
                              Thank for your replay
                              I use win7 and SU8
                              I have already installed many time the program and also the one from the link you suggest but I have always the same problem:
                              I can't see any drawing on the screen
                              I did these tests :
                              on the screen I draw one only component (cube) and when I select lamella.rb from the plugins list.
                              the component (cube) disappear from the screen,
                              the data input masks are anabled and I use the default settings,
                              from the rubi console I can see that the program il working but it does not finish the job.
                              on the rubi console I have this report:
                              http://www.filedropper.com/lamellabroken
                              I removed all plugins ( they are a lot ) except lamella.rb :
                              the program can complete its job,
                              at the end I can see on the screen the component (cube) that was previous cancelled,
                              in the rubi console I have the following report :
                              http://www.filedropper.com/lamellacomplete
                              but still I don't see the drawing of the program
                              After I reinstall all the plugins one by one but when I reinstall sketchyphisics the lamella plugin stops again.
                              Now sketchyphisics is removed
                              thanks a lot for your help
                              • flyer50F
                                flyer50
                                I have solved and now it is working
                                the problem was on the dimentions
                                Ciao Flyer
                                  Works fine! 😎
                                  You must put an alert message when 0Β° is entered for the Screw Angle as nothing is done! πŸ€“
                                  Funny things arrive when you take Screw Angle = 1Β° πŸ˜„
                                  • flyer50F
                                    flyer50
                                    Sorry to distrube again
                                    for two days the plugin was working
                                    but now it stops again and in ruby console I can see
                                    Compound mitre saw cuts (Option A)
                                    Horizontal angle 39.68
                                    Vertical angle 93.62
                                    Compound mitre saw cuts (Option B)
                                    Horizontal angle 5.65
                                    Vertical angle 39.82
                                    Error: #<NoMethodError: undefined method make_unique' for nil:NilClass> D:/Program Files/sketchup/Plugins/lamella_roof.rb:289:in lamella_roof'
                                    D:/Program Files/sketchup/Plugins/lamella_roof.rb:1038
                                    Pls. how can I solve this problem?
                                    Flyer
                                      Have you recently installed or enabled a new app, like Sketchy Physics or a nascent BIM tool ?
                                      It looks like the code is first copying a group and then using make_unique on it.
                                      The API's group.copy returns the new group, so that can then be used with the method .make_unique, BUT some tools [like SP] mess with some native methods and return nil rather than the new group, so things fail...
                                      Try uninstalling the recent/problem tools and retest...
                                      • flyer50F
                                        flyer50
                                        Yes unfortunately.
                                        I removed bim-tools.rb program and in ruby console I have the following text, but the program can complete the cycle... and I can see the model
                                        WARNING: make_unique is a deprecated methodof Sketchup:Group
                                        (x,y) coordinates of vertices on the face of the lamella
                                        -568.80, 142.75
                                        -554.67, 0.00
                                        grazie
                                        Flyer
                                          Some of these half-baked BIM tools add observers and/or mess with some of the native API methods.
                                          In the Lamella tool's code there is probably a cp=group.copy...cp.make_unique code-combo which is being messed up by this [unfairly!]. the group.copy should return a reference to the new group, if the method is messed up it can return 'nil', then the cp.make_unique fails, as will any further operations using 'cp' as the new group's reference, which now isn't the expected 'Group' object but a 'Nil' object ! ...
                                          The Console output about 'mitering' is the tool's output to report what it's doing.
                                          The 'warning' about 'deprecated-method' is a known error from the API - sometimes groups copied via the API MUST be 'made unique' - otherwise changing one changes the others[s] - just like component-instance editing does. So the warning is 'spurious'...
                                          There now seems nothing of concern there.
                                          • flyer50F
                                            flyer50
                                            Thanks for your welcome help
                                            ciao e grazie
                                            flyer
                                            • 3 / 4
