    Shading and bump issues (VfS 1.6)
    renderpluginsextensions
    15 Posts 4 Posters 1.8k Views 4 Watching
    • T
      tdevost
      And yet another issue - I'm getting this weird blotchy lighting from my wall lamp. The cover is a two-sided material and the bulbs are just basic emitters. Any ideas?
        rspierenburg
        Emitters as in Emissive material? Its been strongly suggested against using emissive materials as primary lights for this exact reason.
        • T
          tdevost
          I'm still getting the blotchiness with the sphere lights...
          • V
            valerostudio
            1. I actually don't mind how the grout lines are rendering. I have more problems with the general lighting of the scene. Seems a bit dark and uninviting. I would also reduce the reflection on the tile, it is distracting and seems unrealistic. Look at this link below.
            Fastly error: unknown domain 151.101.192.93
            (www.houzz.com)
            1. What I meant about settings was the amount you have set. Is it set to 1? I have found using 1 is a bit problematic, so try something like .85
            2. 1.6 is a beta, and its a beta that had a lot of bugs. The most current 2.0 is where you want to be and it will not affect any settings you have.
            3. The splotches are most likely from your render settings. Interiors that are low light, like this one will need 2 things. A - more light B - higher light cache settings. Chaos has given us the lovely feature of presets. Try them out. Use Interior - High Quality.
            • T
              tdevost
              1. I'd be happy keeping it the way it is, but I'm trying to simulate actual brand materials since this is a real project. I've attached a picture of a sample tile for context (it's quite a bit less red irl). Also, the lighting is work in progress.
              2. Sorry, it's set to 1.
              3. Perfect, I'll get it running in a moment.
              4. Handy, I had no idea there were presets. I'll give them a go when I get 2.0 running.
              • T
                tdevost
                Here's a new render with 2.0. I had to scale up the image quite a bit since the demo version only permits a max output size of 600 x 400. And obviously some materials need tweaking...
                Anyways, setting the bump to 0.85 didn't seem to help. Also, I tried using the high quality interior preset, but it didn't seem to remedy the splotchiness.
                • T
                  tdevost
                  Agh, sorry for spamming, but a new idea's yielded some promising results. Getting a lot less splotchiness after cranking up the down lights in the shower. I gather it has something to do with the way V-Ray handles scenes without environmental lighting?
                  • V
                    valerostudio
                    If you looking for sharp corners on the tile, maybe I would just model it. It's not a ton of modeling and would yield the most realistic result. Would you mind packing and sharing the model?
                      jackwatson
                      Have you tried increasing the HSph subdivs (under the irradiance map rollout) to something like 80-150 to reduce the blotchiness?
                      • T
                        tdevost
                        Just tried increasing the HSph subdivs to 150 and it seems to be doing the trick. Thanks for the suggestion.
