    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 322.0k Views 110 Watching
    • cmeedC Offline
      cmeed
      @jiminy-billy-bob said:
      @cmeed said:
      -All groups gone ๐Ÿ˜ž
      The groups unique IDs are still present in your file, but they are not listed by Layers Panel serialized string. Don't know why...
      Were layers still sorted, or did they revert back to Sketchup's default sorting ?
      Did anyone else experienced this ?
      The layers were not in any order.
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        Maybe the order they were created ? (Which is SU's default)
        • ElibjrE Offline
          Elibjr
          Any thought to adding Render[in], IRender-nXt or Shaderlight to the list? This is such a great plugin! Thank you for all your work.
            jiminy-billy-bob
            Same case as Thea, I have to contact the developers.
            • Bob JamesB Offline
              Bob James
              Any progress with regard to solving the problem with the interference with the saving of scenes?
                jiminy-billy-bob
                Working on it ๐Ÿ˜‰
                  jiminy-billy-bob
                  Bug found : When a group is moved to be nested in another group, we can't rename it. We have to restart Layers Panel.
                  Working on a fix.
                  • unclebimU Offline
                    unclebim
                    Great plugin, I have integrated it immediately in my workflow. However I noticed following issues (bugs?):
                    1. In SU 8 it displayed the outdated IE version message and did not allow the scroll. Since ver. 0.5 it does not display this message but only shows render engines in the window and no layers or layer groups at all. In SU 2013 this problem does not exist.
                    2. Not sure whether since ver. 0.4 or 0.5 but in both SU 8 and SU 2013 Edit->Paste and Ctrl+V do not work when pasting a group/component from another SU file, Edit->Paste in place works though. Removing the plugin files from SU Plugins folder resolved the problem in both SU 8 and SU 2013. Also renaming layers in the native SU Layers window sometimes caused bugsplat with the plugin installed in SU 2013.
                    Hope that helps.
                    Thank you for your great plugin, it is so useful.
                      jiminy-billy-bob
                      What's your IE version ?
                      @unclebim said:
                      1. Not sure whether since ver. 0.4 or 0.5 but in both SU 8 and SU 2013 Edit->Paste and Ctrl+V do not work, Edit->Paste in place works though. Removing the plugin files from SU Plugins folder resolved the problem in both SU 8 and SU 2013. Also renaming layers in the native SU Layers window sometimes caused bugsplat with the plugin installed in SU 2013.
                      Weird. Does it work when Layers Panel is installed but closed ?
                        Bob James
                        This started happening for me after ver 0.5
                        • danchoD Offline
                          dancho
                          I was installed your plugin and it is nice how its work in new file, but with
                          my actual project I can't see layer list with your plugin.
                          Secont, will be fine that you can put a possibility to show/hide panel like old layer window, click on the top of window.
                          Here is screen capture:
                          THX
                          Daniel
                          old and new layer window
                            jiminy-billy-bob
                            All the time ? With all kind of objects ? Even when LP is closed ?
                            I really don't see what could cause that... And I can't reproduce it.
                              jiminy-billy-bob
                              You're not the first to experience this.
                              Could you send me the file by PM ? (Even with all the content deleted, keeping only the layers) The best would be a version of the file that was never saved since LP was installed.
                              That's not possible, unfortunatly ๐Ÿ˜ž
                              • tt_suT Offline
                                tt_su
                                Workaround suggestion, size the window and leave a small clickable header in the HTML itself.
                                  jiminy-billy-bob
                                  I guess I could do that, thanks ๐Ÿ˜„
                                  But still not dockable, though
                                    jiminy-billy-bob
                                    Try to change scene.
                                      Mike Whitton
                                      This is a marvelous idea - SketchUp has needed this sought of control of layers for a long time. BUT .....It makes my version of SketchUp (2013) very unstable to the point of being unusable. I have had to uninstall the plugin.
                                      Am I doing something wrong?
                                        kct3937
                                        Too bad it doesn't work in OSX. Looks like a good plugin. Now if it worked on a real operating systemโ€ฆ.just imagine.
                                        Dave Richards might quit looking in a mirror.
                                          jiminy-billy-bob
                                          Please don't come here to troll...
                                          The reason why it doesn't work on your "real" OS is because Safari handles javascript requests higgledy-piggledy. JS sends a bunch of informations to ruby, and safari says "oh well, let's just put all of this into the trash and keep only the last one".
                                          So much for a real OS.
                                          Even though I'm happy to take request, I primarily develop this plugin for myself. And I don't really like MacOS (The OS itself, Apple's politic, etc...), so I'm not really motivated to develop Layers Panel for it. Guess what? People coming here smugly, telling me that their OS is superior, and should be the one and only, don't really motivate me much more!
                                            jiminy-billy-bob
                                            What are you experiencing, exactly ?
                                            • 11
                                            • 12
                                            • 33
                                            • 34
                                            • 10 / 34
