    [Plugin] Solid Inspector
    303 Posts 99 Posters 368.5k Views 98 Watching
      The error messages indicate you've not installed TT_Lib2 correctly. How about showing us a screenshot of your Plugins folder.
      This plugin and TT_Lib2 work just fin with SU8 and SU2013 when installed correctly.
      • tt_suT
        tt_su
        Sounds like you might have ended up affected by Windows UAC protection system and some files ended up in Virtual Store.
        Navigate to the Plugins folder in Explorer and see if there then is a Compatibility Files button. If there is any files in Virtual Store you should clean them up.
        • K
          kurtklingbeil
          on closer inspection, I see that the error messages all seem to relate to
          C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/libraries/win32/TT_Geom_BezierError
          well, yes indeedy that file is not there
          a disk-wide scan for TT_Geom_Bezier finds TT_Geom_Bezier.bundle in the osx folder...
          Is there an easy/correct way to force a re-install of TT_lib2?
          Directory of c:\Program Files\Google\Google SketchUp 8\Plugins\TT_Lib2\librarie
          s\win32
          09/12/2013 05:47 PM <DIR> .
          09/12/2013 05:47 PM <DIR> ..
          01/16/2011 04:31 PM 446 tt_api-readme.txt
          01/15/2011 03:26 PM 28,672 tt_api.so
          2 File(s) 29,118 bytes
          2 Dir(s) 380,049,514,496 bytes free
          09/12/2013 05:43 PM <DIR> .
          09/12/2013 05:43 PM <DIR> ..
          06/28/2013 01:23 PM 3,474 !SketchUcation_loader.rb
          01/18/2013 11:30 AM <DIR> cutlist
          08/04/2010 01:37 AM 1,535 cutlist.rb
          01/09/2012 07:05 PM 1,251 engineeringtoolbox.rb
          09/11/2012 04:11 PM <DIR> Examples
          08/23/2012 04:02 AM 2,412 examples.rb
          06/05/2013 05:42 PM <DIR> HibouScientificSoftwareLibrary
          06/05/2013 05:42 PM <DIR> Khamsin
          05/31/2013 11:08 AM 1,755 khamsin.rb
          02/07/2012 03:34 PM <DIR> ldd
          01/25/2012 07:41 PM 11,274 ldd.rbs
          09/11/2012 04:11 PM <DIR> Ocean
          08/23/2012 04:02 AM 1,065 ocean_extension.rb
          09/12/2013 03:34 PM <DIR> SketchUcation
          04/01/2013 06:50 PM 17,857 TIG-solidsolver.rb
          01/19/2012 04:36 PM 2,983 tt_export.rb
          09/12/2013 05:47 PM <DIR> TT_Lib2
          04/19/2013 01:31 PM 1,876 TT_Lib2.rb
          09/12/2013 03:36 PM <DIR> tt_solid_inspector
          04/25/2013 02:00 PM 1,614 tt_solid_inspector.rb
          09/11/2012 04:11 PM <DIR> Utilities
          08/23/2012 04:02 AM 1,175 utilities.rb
          01/30/2012 12:16 PM 19,578 VolumeCalculator21.rb
          13 File(s) 67,849 bytes
          12 Dir(s) 380,050,038,784 bytes free
          01/18/2013 12:29 PM 2,231 arc.rb
          02/19/2013 08:00 PM 1,844 attributes.rb
          02/19/2013 07:59 PM 8,916 babelfish.rb
          04/01/2013 07:46 PM 493 bezier.rb
          01/18/2013 12:29 PM 660 binary.rb
          01/18/2013 03:28 PM 1,233 boolean_attributes.rb
          02/19/2013 07:59 PM 4,304 bounds.rb
          01/23/2011 11:31 PM 2,803 CHANGELOG.txt
          01/18/2013 12:29 PM 626 color.rb
          04/19/2013 12:40 PM 12,092 core.rb
          01/18/2013 12:29 PM 8,084 cursor.rb
          09/12/2013 05:47 PM <DIR> cursors
          01/18/2013 12:29 PM 1,667 debug.rb
          01/18/2013 12:29 PM 1,128 deferred_event.rb
          01/18/2013 12:29 PM 3,535 definition.rb
          01/18/2013 12:29 PM 6,796 dimension.rb
          04/03/2013 11:00 AM 2,784 draw_cache.rb
          03/25/2013 01:50 PM 16,240 edges.rb
          03/25/2013 01:50 PM 4,266 entities.rb
          06/05/2013 03:29 PM 88 extension_info.txt
          03/25/2013 01:51 PM 3,652 faces.rb
          03/25/2013 01:51 PM 6,177 geom3d.rb
          03/25/2013 01:30 PM 48,638 gizmo_manipulator.rb
          03/25/2013 01:52 PM 18,667 gl_image.rb
          03/25/2013 01:32 PM 20,205 gui.rb
          03/25/2013 01:33 PM 685 image.rb
          03/25/2013 01:56 PM 11,211 inputbox.rb
          04/01/2013 08:10 PM 1,936 instance.rb
          04/03/2013 10:32 AM 658 integrity_list.dat
          03/25/2013 01:35 PM 1,264 javascript.rb
          03/25/2013 01:53 PM 2,930 json.rb
          01/18/2013 12:29 PM 693 length.rb
          09/12/2013 05:47 PM <DIR> libraries
          01/18/2013 12:29 PM 3,552 locale.rb
          03/25/2013 01:36 PM 6,665 materials.rb
          01/18/2013 12:29 PM 1,552 metaclass.rb
          03/02/2013 05:17 PM 2,888 modal_wrapper.rb
          03/25/2013 01:38 PM 3,980 model.rb
          03/25/2013 01:38 PM 3,947 point3d.rb
          03/25/2013 01:39 PM 1,758 point3d_ex.rb
          02/19/2013 07:57 PM 9,595 profiler.rb
          03/25/2013 01:40 PM 4,350 progressbar.rb
          03/25/2013 01:40 PM 5,350 ray.rb
          08/29/2010 02:43 AM 235 README.txt
          03/25/2013 01:40 PM 629 selection.rb
          01/18/2013 12:29 PM 2,830 settings.rb
          03/25/2013 01:41 PM 2,195 simpletask.rb
          03/25/2013 01:42 PM 2,528 sketchup.rb
          01/18/2013 12:29 PM 923 system.rb
          03/25/2013 01:46 PM 819 toolbarwindow.rb
          03/25/2013 01:45 PM 741 toolwindow.rb
          01/18/2013 12:29 PM 704 uvq.rb
          02/19/2013 07:58 PM 7,201 uv_plane.rb
          01/18/2013 12:29 PM 3,782 version.rb
          10/11/2011 12:59 PM <DIR> webdialog
          01/18/2013 12:29 PM 3,644 webdialog_patch.rb
          04/01/2013 07:46 PM 11,220 win32.rb
          03/25/2013 01:48 PM 17,093 window.rb
          55 File(s) 294,687 bytes
          5 Dir(s) 380,050,038,784 bytes free
          • tt_suT
            tt_su
            First of all, check the Virtual Store which I mentioned in my previous post. If there is anything there it is likely to mess things up.
            Then, once you have ensured there is no Virtual Store files, then you close all instances of SketchUp and then remove the TT_Lib2 files.
            After that you have a clean slate and you can install the RBZ via Preferences > Extensions - or use the Extension Warehouse.
              john_kucia
              I can't wait to use this! Except - I got errors trying to install RBZ files, so I changed ".rbz" to ".zip" and copied the files in. After resolving all of the "Can't find blah.rb" issues, I'm getting one last error:
              "Error Loading File core.rb
              uninitialized constant TT::System"
              Since the Solid Inspector ran on one model, do I just cope with a constant popup error? Any thoughts on this?
                Did you also install the required TT_lib2 files?
                You shouldn't have needed to change the RBZ to ZIP. Why not just use Install Extension from Preferences>extensions?
                • tt_suT
                  tt_su
                  What error where you getting? (The actual error messages are usually the most useful when debugging.)
                    john_kucia
                    FYI, I'm running SU8 on a Mac running 10.7.5. However, the RBZ problem occurs with all flavors of extensions regardless of their date.
                    re: RBZ to ZIP
                    I've tried the Install-Via-Preferences route, but I get problems. I've installed the TT_lib2, but via copying the contents of an unzipp'd RBZ, so perhaps there is a file to be dealt with that was not resolved in the simple copy maneuver?
                    Here's the error message when running the Preferences Extension Installer:
                    "Unable to install this Extension
                    SketchUp was unable to install the Extension you have chosen for some unknown reason.
                    Consult your Extension's documentation for additional help."
                    ....I know, helpful, right? I ran a couple permission repairs on my Mac, with reboots, that didn't change anything.
                    re: Unzipping and copying file structure into SU
                    This is what pops up when starting SU each time:
                      Looks like you have a permissions problem. Go to the Plugins folder, right click on it and open Get Info. At the bottom edit the permissions so all are set to Read & Write.
                      • tt_suT
                        tt_su
                        Try to remove TT_Lib completely and then reinstal it. (Make sure to exit all SketchUp windows first.)
                          docloco
                          Screen Shot 2013-10-23 at 3.26.35 PM.pngI am trying to install this plugin on a Mac, however, the root file for the plugins doesn't exist. Where do I put it? Here's is a screen shot of the hard drive location. I have the latest version of Google Sketchup Make.
                            Look in the right place. It does exist.
                            For SU2013 the Plugins folder is located under the User. You'll need to make the hidden Library folder visible, though. Why not make it easier for yourself and use the Sketchucation Plugin Store to automatically install plugins?
                            • G
                              G64
                              I hope this won't offend anyone, I use Mac and I am trying to install your plugin. I installed the TT library. The install or rbz files is easily managed within SU8. However to install the actual rb plugin, I can't seem to make it work. I followed the instructions for Mac users found here:
                              http://help.sketchup.com/en/article/38583
                              it says:
                              "If you have a file with the .rb extension, you can install the plugin by placing the Ruby script file into the appropriate folder, and then restarting SketchUp."
                              "Mac OS X - the default location is: Version 8 and older: [YOUR USER NAME]/Library/Application Support/Google SketchUp #/SketchUp/plugins"
                              I even had to create a plugins directory, pasted your rb script there and restarted SU8, the plugin won't show in the menu.
                              Have I missed something?
                              Has anyone had any success installing this plugin in a Mac running SU8?
                              Thanks, G64
                                It looks to me as if you followed the instructions for SU2013 which are different than for SU8. You didn't need to create a Plugins folder because it already exists in the right place. For SU8 go to Macintosh HD/Library/Application Support... You'll find the Plugins folder there, instead. Put the .rb file there and restart SketchUp.
                                Better would be to install the Sketchucation Plugin Store and let it automatically install plugins for you.
                                By the way, make sure you have full Read and Write permissions established for the correct Plugins folder. And get rid of the folder you made.
                                • tt_suT
                                  tt_su
                                  Install it as an RBZ package from the Plugin Store: http://sketchucation.com/resources/pluginstore?pln=tt_solid_inspector
                                  (I haven't had time to update all my threads to point to the Plugin Store yet.)
                                    Sauronbloo
                                    I've looked everywhere for this plugin, but dl fails on sketchucation, and on RLD they say it was taken down at the author's request. Where can I find this please?
                                    • massimoM
                                      massimo Moderator
                                      Have you tried to click on the Cattura.JPGbutton?
                                      • cottyC
                                        cotty
                                        Or with the link directly before your question... provided by the author himself 😉
                                        my SketchUp gallery
                                          Or you could spend a few moments reading and you might see this immediately above your post.
                                            Sauronbloo
                                            I have this plugin, and it shows in my exxtensions list in preferences (it is checked active), but I cannot get any functions of this to work. TT_Lib2 is also installed and checked. What may be the cause of this? How do I get the tool to work? I've tried right-clicking, tab, enter, anything I've read ppl doing in this thread. Pls help. I'm on 2013 pro using win7 thx
                                            • 11
                                            • 12
                                            • 15
                                            • 16
                                            • 10 / 16
