    [Plugin] Layers Panel 1.2.1
    672 Posts 109 Posters 186.4k Views 109 Watching
    • jiminy-billy-bobJ Offline
      jiminy-billy-bob
      Hey guys, how about choosing what layers to render ? πŸ˜„
      Got it working with at least Vray, Kerkythea, and Maxwell suite.
      • ToboboT Offline
        Tobobo
        That is a very interesting concept.
        It means you could using to hide walls etc
        Toby
        Philippians 4:13
          jiminy-billy-bob
          It means the plugin will hide/unhide chosen layers when you hit the render button, without actually hidding/showing them. So you could have heavy vegetation layers sent to the renderer, but never activated in SU's viewport.
          • tt_suT Offline
            tt_su
            Oh? Now that sounds mighty interesting.
              jiminy-billy-bob
              Yeah, and that's pretty simple :
              • Start operation with UI disabled
              • Hide/unhide chosen layers (But UI is disabled, so their visibility is not actually changed)
              • Trigger render (like "VRayForSketchUp.launch_vray_render")
              • Revert back layers visibility
              • Commit operation
              πŸ˜„
              • Bob JamesB Offline
                Bob James
                Totally outstanding plugin πŸ‘ πŸ‘
                Would it be possible to add the ability to delete a layer into the current layer?
                Example:
                I have layer 5 chosen as the current default layer.
                I want to put all the stuff in layer 8 into layer 5
                I need the option to select 1. delete completely, 2. delete to layer 0, and 3. delete to current layer.
                The first two exist (the red garbage can and the green garbage can)
                Now I'd like a "blue" garbage can "delete to current layer" πŸ˜„
                Once again: Outstanding Plugin
                  Bob James
                  While using Ctrl-z to undelete portions of the model that I have just deleted, I get this dialog.
                    jiminy-billy-bob
                    Noted bob about deleting to active layer.
                    Not sure about the undo problem, though. Do you get this every time ?
                      jiminy-billy-bob
                      BOOM !
                      Choose what layer to render ! πŸ‘
                      [screenr:t24aadah]OHcH[/screenr:t24aadah]
                      Works with Vray, Maxwell, Kerkythea and Indigo. I'm working with Tomasz to get Thea to support this feature.
                      It still needs some finishing, but the release is not far πŸ˜‰
                      • ToboboT Offline
                        Tobobo
                        BOOM !
                        Well done!!! I cant wait to have a crack πŸ‘
                        Toby
                        Philippians 4:13
                          jiminy-billy-bob
                          New version 0.4 beta !
                          Changelog :
                          • Adds the ability to choose which layers to render (Works with Vray, Maxwell, Indigo, and Kerkythea)
                          • Fix bug when having too many layers
                          • The dialog now remembers its size and position when closed
                          • Fix focus jumping at the top of the dialog
                          Download in the plugin store !
                            kirill2008
                            I won't be original, just want to say: it is a great plugin! πŸ‘ Many thanks for it!
                              jiminy-billy-bob
                              @kirill2008 said:
                              I won't be original
                              You don't have to, it's always nice to hear that πŸ˜‰
                              • U Offline
                                Ulimann
                                Hallo Jiminy
                                Great plugin , installed the update and get the resulting screen on activation.
                                I am running Windows 7 64 SU 8 PRO.
                                  jiminy-billy-bob
                                  Can you delete everything concerning Layers Panel in your plugin folder, and reinstall it ?
                                  Plugins/jbb_layers_panel.rb
                                  • U Offline
                                    Ulimann
                                    Thanks for the quick reply,did as you suggested its up and running.
                                    • sadyoS Offline
                                      sadyo
                                      Great Plugin... (y)
                                      waiting for Render feature to work with Thea Render
                                        jiminy-billy-bob
                                        Actually, if it works with Thea on day, it'll behave differently. You will probably have an option directly inside Thea allowing you to choose if you want to render with Layers Panel feature or not. But you won't render from within Layers Panel as you do with Vray/Maxwell/etc. This is due to the way Thea is designed. I can't trigger the render from my plugin.
                                        I gave evrything to Tomasz to make it work, the ball is on his side now πŸ˜‰ So if you badly want this feature, you should get in touch with him !
                                        • doush-007D Offline
                                          doush-007
                                          Great plugin...it must absolutely replaced the layer window in the next version of sketchup..thanks a lot for this plugin 😍
                                          • JQLJ Offline
                                            JQL
                                            Jiminy great plugin and great news on Thea!
                                            Is it possible that my layer groups have been wiped out after a purge?
                                            Best regards,
                                            JQL
                                            www.casca.pt
                                            Visit us on facebook!
                                            • 33
                                            • 34
                                            • 7 / 34
