    [Plugin] Layers Panel 1.2.1
    672 Posts 109 Posters 182.9k Views 109 Watching
    • jiminy-billy-bobJ Offline
      jiminy-billy-bob
      No it's ok.
      The fact you have this issue in IE8 is really weird. I can't reproduce it.
      I'm sorry but I won't support outdated versions of this crappy browser. I know you can't have a higher version of IE on XP, but we're talking about a 12 years old OS...
        jiminy-billy-bob
        Hey guys, how about choosing what layers to render ? πŸ˜„
        Got it working with at least Vray, Kerkythea, and Maxwell suite.
        • ToboboT Offline
          Tobobo
          That is a very interesting concept.
          It means you could using to hide walls etc
          Toby
          Philippians 4:13
            jiminy-billy-bob
            It means the plugin will hide/unhide chosen layers when you hit the render button, without actually hidding/showing them. So you could have heavy vegetation layers sent to the renderer, but never activated in SU's viewport.
            • tt_suT Offline
              tt_su
              Oh? Now that sounds mighty interesting.
                jiminy-billy-bob
                Yeah, and that's pretty simple :
                • Start operation with UI disabled
                • Hide/unhide chosen layers (But UI is disabled, so their visibility is not actually changed)
                • Trigger render (like "VRayForSketchUp.launch_vray_render")
                • Revert back layers visibility
                • Commit operation
                πŸ˜„
                • Bob JamesB Offline
                  Bob James
                  Totally outstanding plugin πŸ‘ πŸ‘
                  Would it be possible to add the ability to delete a layer into the current layer?
                  Example:
                  I have layer 5 chosen as the current default layer.
                  I want to put all the stuff in layer 8 into layer 5
                  I need the option to select 1. delete completely, 2. delete to layer 0, and 3. delete to current layer.
                  The first two exist (the red garbage can and the green garbage can)
                  Now I'd like a "blue" garbage can "delete to current layer" πŸ˜„
                  Once again: Outstanding Plugin
                    Bob James
                    While using Ctrl-z to undelete portions of the model that I have just deleted, I get this dialog.
                      jiminy-billy-bob
                      Noted bob about deleting to active layer.
                      Not sure about the undo problem, though. Do you get this every time ?
                        jiminy-billy-bob
                        BOOM !
                        Choose what layer to render ! πŸ‘
                        [screenr:t24aadah]OHcH[/screenr:t24aadah]
                        Works with Vray, Maxwell, Kerkythea and Indigo. I'm working with Tomasz to get Thea to support this feature.
                        It still needs some finishing, but the release is not far πŸ˜‰
                        • ToboboT Offline
                          Tobobo
                          BOOM !
                          Well done!!! I cant wait to have a crack πŸ‘
                          Toby
                          Philippians 4:13
                            jiminy-billy-bob
                            New version 0.4 beta !
                            Changelog :
                            • Adds the ability to choose which layers to render (Works with Vray, Maxwell, Indigo, and Kerkythea)
                            • Fix bug when having too many layers
                            • The dialog now remembers its size and position when closed
                            • Fix focus jumping at the top of the dialog
                            Download in the plugin store !
                              kirill2008
                              I won't be original, just want to say: it is a great plugin! πŸ‘ Many thanks for it!
                                jiminy-billy-bob
                                @kirill2008 said:
                                I won't be original
                                You don't have to, it's always nice to hear that πŸ˜‰
                                • U Offline
                                  Ulimann
                                  Hallo Jiminy
                                  Great plugin , installed the update and get the resulting screen on activation.
                                  I am running Windows 7 64 SU 8 PRO.
                                    jiminy-billy-bob
                                    Can you delete everything concerning Layers Panel in your plugin folder, and reinstall it ?
                                    Plugins/jbb_layers_panel.rb
                                    • U Offline
                                      Ulimann
                                      Thanks for the quick reply,did as you suggested its up and running.
                                      • sadyoS Offline
                                        sadyo
                                        Great Plugin... (y)
                                        waiting for Render feature to work with Thea Render
                                          jiminy-billy-bob
                                          Actually, if it works with Thea on day, it'll behave differently. You will probably have an option directly inside Thea allowing you to choose if you want to render with Layers Panel feature or not. But you won't render from within Layers Panel as you do with Vray/Maxwell/etc. This is due to the way Thea is designed. I can't trigger the render from my plugin.
                                          I gave evrything to Tomasz to make it work, the ball is on his side now πŸ˜‰ So if you badly want this feature, you should get in touch with him !
                                          • doush-007D Offline
                                            doush-007
                                            Great plugin...it must absolutely replaced the layer window in the next version of sketchup..thanks a lot for this plugin 😍
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 31 / 34
