    Flower petal rotated with plugin?
    6 Posts 3 Posters 321 Views 3 Watching
      alexbarsen
      Hello, am new here and found no topics on my question so here goes πŸ˜›
      I was watching this video on how to make a flower and at 3:10, the user used something to rotate the flower petal that I can't seem to repeat or see what tool he used.
      Does anyone know if its a plugin or is it a PRO version tool? Thanks.
      • massimoM Offline
        massimo Moderator
        He uses the radial bend tool from the Fredoscale plugin.
        Please read carefully the Fredo's post and manual for installation and usage.
          alexbarsen
          thanks mate, but it seems that i can't install it as im using 7... oh well i guess i'll deal with a flat petal πŸ˜„ thanks again
          • massimoM Offline
            massimo Moderator
            Works fine in SU 7. What do you mean with "I can't install"?
            In 7 you can't use the SCF plugin store or the extension manager, but you can use the "old" method: just download Fredoscale & LibFredo and put them in the plugins folder following the correct footprint.
              To reiterate...
              Auto-install from RBZ archives only works with >=v8M2 - so the latest v8 or v2013 have that option button in Preferences > Extensions and the SketchUcation PluginStore works fully with these versions too...
              An RBZ archive is a renamed ZIP file.
              So for earlier versions you need to download the .RBZ archive and rename it .ZIP...
              Now extract that ZIP's contents to a temporary folder [the unZIP app usually makes that folder named after the archiv itself]... keeping all of the files and files-inside-subfolders in the same relative relationship.
              Move these files/subfolders from the temporary-folder into your Plugins folder [ensuring first that you have FULL security permissions to change files in it !].
              Finally restart SketchUp to load the toolset.
              Note with some toolsets [like Fredo's] you need to also install a 'Lib' before it will work.
              A few plugins do need some special functions that are only available in >=v8 or Pro versions... but many do work on v7 or Free/Make versions too...
              These usually say this in their download page's info...
                alexbarsen
                thanks guys. sorry about that, was late where i am. soon as i saw SU8/13, immediately thought it doesnt work with older versions >.< i apologize.
