    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 294.4k Views 172 Watching
    • F Offline
      fwolf21
      Great work.
      I have worked with the original ivy generator back in 2008-2009.
      Don't have any thing to say right now since just start using it.
      Ill keep you posted if anything comes up.
      Keep you the great work
        PHRodrigues
        awesome! thx man.
          technoshaman
          Thank you for this wonderful plug in. I was about to start modeling ivy by hand!!!! But this saved me so much time. THANK YOU
          • lele_poggiL Offline
            lele_poggi
            The plug-in doesn't work with the new version of Vray for Sketchup 1.6.
            Can be fixed this bug?
            Thank you
            gsa | Gabriele Sacchi architetto
            http://www.gs-a.it
              Thank you
              The bug is in the Vray beta - it breaks several legit tools by having some flaky observer calls... I know Vray have a solution and I'd expect an update to their beta soonest...
              Meanwhile can I suggest that you disable Vray from loading while modeling - you don't need a renderer to model ??
                lele_poggi
                Thanks TIG.
                I've already disable Vray and it works fine.
                I didn't know it was a Vray bug.
                So I'm in waiting for their next beta release to check this.
                http://www.gs-a.it
                  I'd recommend that you report this to the developers of V-Ray. It's known to have caused problems with other plugins as well.
                    AcesHigh
                    @pierreden said:
                    TO COME
                    • Leaves as Components
                    • More Parameters and grow patterns.
                    • Other Plugins. Fur, Cloth and Tree.
                    I wonder what happened to Pierreden 😞
                    • JBJDesignsJ Offline
                      JBJDesigns
                      Sorry to say I did not find this plug-in very useful. But it could be my version of SketchUp (2013). The "branch" part worked okay; but when I applied the leaves, they all drooped (no matter what settings I used... and I really tried to make this work). Turns out the "Tak2hata: Make Fur v2.0.6" is much better at creating leaves. Nice try though. And by the way, I do have the original ivy maker which I use once in awhile.
                      One other problem... the leaves for some reason turned up in every new file I opened as components. Then I tried to remove "unused" components, the leaves would not purge. They had to be deleted individually. Annoying.
                      ...you send them to school, you give them books, and they eat the pages...
                        jake0721
                        hello sir, is it compatible for su 8? im using su 8 pro
                        • KrisidiousK Offline
                          Krisidious
                          yes, it is...
                          By: Kristoff Rand
                            bsley
                            No luck getting this installed. Dropped the contents of the zip into my "Plugins" folder and I'm getting this when I open Sketchup:
                            Error Loading File LiveIvy.rb
                            undefined method `file_loaded?' for main:Object
                            Mac 10.8.3 / SketchUp 2013
                              Krisidious
                              One of the SketchUp gurus will have to answer that...
                              By: Kristoff Rand
                                revalucia
                                same problem:
                                SU2013
                                plugin Vray 1.49.02
                                and sketchupIvy 0.6.3beta
                                Please help! thank you
                                  The file_loaded? method is created by sketchup.rb
                                  There should be a line near the start of every script to ensure that sketchup.rb is loaded before calling it:
                                  require('sketchup.rb')
                                  This will load it if it has no already been loaded by a script that loaded earlier on.
                                  If you have a very limited number of plugins loading and one of them has not loaded sketchup.rb before getting to try and load 'LiveIvy.rb' then you'll get a failure.
                                  If you don't want to edit the LiveIvy file to add that line of code at the sart, then why not just install the 'SketchUcation Plugin Store' toolset [see the Resources menu] - that has a loader starting with ! putting it first alphabetically, so it loads at the very start AND therefore will have already 'required' sketchup.rb, preventing later miscast plugins throwing an error.
                                  You'll also have the added advantage of then having an awesome [free] toolset to auto-install and manager your plugins and extensions !
                                    desunvn
                                    Thank you for share
                                      Kjammer
                                      The SketchupIvy.0.6.3 is a .rar file and Sketchup cant recognize it because it not an rbz. how do we install it?
                                        Krisidious
                                        Just extract it to your plugins folder. It's a zip folder.
                                        By: Kristoff Rand
                                          You can get the RBZ version from http://sketchucation.com/resources/pluginstore?pln=SketchupIvy
                                            saturne45
                                            Hello everybody, this very nice plugin working good with skp8 on windows xp and don't work with skp8 on windows vista?? with files in rar or rbz. anybody had got the same problem?? and is there a solution. thank you.
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 36
                                            • 37
                                            • 16 / 37
