    2D Export options for Make/Free?
    6 Posts 3 Posters 370 Views 3 Watching
      Can someone tell me the 2D export options for SU 7/8 Free 0r Make?
      Want to know if someone using Make can export .eps
      • BoxB Offline
        .bmp .jpg .tif .png on windows
          Shite
            There are free image > eps converters...
            http://image.online-convert.com/convert-to-eps
            http://www.convertmyimage.com/
            http://www.files-conversion.com/image-converter.php
            there are loads...
              Is there a way to export linework to inkscape or equivalent?
                Free vector file STL & OBJ exporters work on Free/Make...
                BUT these are NOT importable into Inkscape πŸ˜’
                There might be a free SVG exporter which would then be importable into Inkscape ?
                http://sketchucation.com/forums/viewtopic.php?f=15&t=52949
                http://code.google.com/p/sketchup-svg-outline-plugin/
                etc ??
                Or you could perhaps print out from the SKP as a PDF...
                Then import that into Inkscape ?
