    [Plugin] Layers Panel 1.2.1
    672 Posts 109 Posters 183.0k Views 109 Watching
    • cmeedC Offline
      cmeed
      everything was working well (the group names was the only thing) I was working inside a group outliner was open and then i got the bugsplat. I dont normally get bugsplats so its funny.
      I didn't uninstall or do anything witht the plugin.
      did you mean to uninstall it and try opening the files? as I've tried opening themon my Mac (no "Layers {abel" plugin) and still not luck - It happened on my pc
      opening .skb and .skp result with Unexpected file format.
      • kenK Offline
        ken
        I have had the same problem as cmeed. The unexpected file format. Luckily for me I had a backup or I would have lost the file.
        Note, I have the plugin TIG: Archiver v2.0 which is a life saver.
        http://sketchucation.com/forums/viewtopic.php?p=149749#p149749
        Thanks for your plugin.
        Ken
        • jiminy-billy-bobJ Offline
          jiminy-billy-bob
          Holy sh...
          I'll try to reproduce the bug. That's a big problem if it corrupts files... πŸ˜• I'm so sorry, I hope you didn't lose your work.
          I'll add a warning in the first post.
            jiminy-billy-bob
            cmeed, can you check if you still have the dump/log files produced by the bugsplat ?
            • cmeedC Offline
              cmeed
              I have started again (this time with archiver as cover)
              c
              • ElibjrE Offline
                Elibjr
                Oh wow, this is truly a nice plugin. I wished that the standard layers toolbar worked this way. Now I want to install in on both my laptop and the desktop machine. This is one of the cleanest plugins I have used. Great work Jiminy. My top 10 now.
                Elibjr
                  Ben Ritter
                  I appreciate your generosity in sharing this plugin
                    jiminy-billy-bob
                    Thanks everybody for your kind words, comments and feedback ! I really appriciate it.
                    • kenK Offline
                      ken
                      I have 4 layers that are in my template. I wanted to get this under a group, so I could turn all the layers off at once. They are xlines, markcenter, workplane and cline. When I try saving a template file, I get unexpected file format and the program closes. On trying to open Sketchup again, I get the failed to open template file. Sketchup open but not with the template file that I saved.
                      However, when I open the standby template file, saved as a regular file, and then try to save this file as a template with the name I used above, I get the file exist and do you wish to over write the file. So something was saved.
                      Just trying to keep you abreast.
                      Ken
                        jiminy-billy-bob
                        Thanks Ken, I'll look into that.
                          jiminy-billy-bob
                          New version 0.3.1 beta !
                          Changelog :
                          • Fix group names disappearing
                          Download in the plugin store !
                            jiminy-billy-bob
                            Ken, were these 4 layers created before you installed the plugin ? What happen when you create a new file, create the same layers, and try to save it as template ?
                            If you find a way to reproduce the bug every time, that would be really great ! πŸ˜„ I could propably debug this
                            • kenK Offline
                              ken
                              Well OK, I noticed that there were other versions of this plugin in my plugin folder. So I deleted all files associated with this plugin and did a re-install. It now appears to be working. I can save a template file, and re-open and have the four layers still there and in the group I added.
                              Hope this helps.
                              Ken
                              • X Offline
                                xkalvisx
                                I hope you have ever done:
                                Group - visible
                                Group - invisible
                                Should operate in a single click
                                Thank you
                                  jiminy-billy-bob
                                  What do you mean ? You can already hide/show groups with a single click.
                                    jiminy-billy-bob
                                    Hope this helps.
                                    Ken
                                    Great ! I'm glad it works now.
                                    But did you have the corrupt template multiple times ? I mean, was it just one time or was it systematic ?
                                    EDIT : When you say you had multiple versions installed, was it a beta (layer_panel.rb) and an old alpha version (Layers Panel.rb) ? Otherwise, I don't understand how you can have multiple versions
                                      jiminy-billy-bob
                                      Okay, I find a way to reproduce the bug in version 0.3 :
                                      • Open blank file
                                      • Open LP's dialog
                                      • Create group
                                      • Save as template
                                      I get "Incorrect format file" each time.
                                      The good news is I don't get this with version 0.3.1 ! πŸ˜„
                                      So it was probably related to the group names bug. So please update everybody !
                                      Thanks a lot Ken for your feedback, it helped me a lot finding the way to reproduce it.
                                      I hope it was the same problem cmeed had, even though he didn't save as template.
                                        jiminy-billy-bob
                                        For people understanding ruby :
                                        I fully identified the cause of the problem : The plugin trying to save "nil" as an AttributeDictionary key.
                                        @layerDictID being nil (the bug about group names)
                                        @model.set_attribute("jbb_layerspanel_groups", @layerDictID, groupName)
                                        • kenK Offline
                                          ken
                                          Well I was looking the plugin directory an found more than one layerpanel directory and some other files I believe came from other installations. I don't remember all the names, I just removed everything having to do with layerpanel. And re-installed and presto it works.
                                          Thanks for looking into this plugin.
                                          Wishing you luck.
                                          Ken
                                          • X Offline
                                            xkalvisx
                                            No groups, but the group of layers.
                                            It is now possible to make invisible only one layer.
                                            If you see me group 5 layers, this group click on the "eye", I wish that all the five layers in the group would become visible or not.
                                            Thanks.
                                            P.S.
                                            Sorry for the very poor proficiency in English.
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 33
                                            • 34
                                            • 23 / 34
