    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 321.9k Views 110 Watching
    • kenK Offline
      ken
      I have had the same problem as cmeed. The unexpected file format. Luckily for me I had a backup or I would have lost the file.
      Note, I have the plugin TIG: Archiver v2.0 which is a life saver.
      404 Not Found
      (sketchucation.com)
      Thanks for your plugin.
      Ken
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        Holy sh...
        I'll try to reproduce the bug. That's a big problem if it corrupts files... πŸ˜• I'm so sorry, I hope you didn't lose your work.
        I'll add a warning in the first post.
          jiminy-billy-bob
          cmeed, can you check if you still have the dump/log files produced by the bugsplat ?
          • cmeedC Offline
            cmeed
            I have started again (this time with archiver as cover)
            c
            • ElibjrE Offline
              Elibjr
              Oh wow, this is truly a nice plugin. I wished that the standard layers toolbar worked this way. Now I want to install in on both my laptop and the desktop machine. This is one of the cleanest plugins I have used. Great work Jiminy. My top 10 now.
              Elibjr
                Ben Ritter
                I appreciate your generosity in sharing this plugin
                  jiminy-billy-bob
                  Thanks everybody for your kind words, comments and feedback ! I really appriciate it.
                  • kenK Offline
                    ken
                    I have 4 layers that are in my template. I wanted to get this under a group, so I could turn all the layers off at once. They are xlines, markcenter, workplane and cline. When I try saving a template file, I get unexpected file format and the program closes. On trying to open Sketchup again, I get the failed to open template file. Sketchup open but not with the template file that I saved.
                    However, when I open the standby template file, saved as a regular file, and then try to save this file as a template with the name I used above, I get the file exist and do you wish to over write the file. So something was saved.
                    Just trying to keep you abreast.
                    Ken
                      jiminy-billy-bob
                      Thanks Ken, I'll look into that.
                        jiminy-billy-bob
                        New version 0.3.1 beta !
                        Changelog :
                        • Fix group names disappearing
                        Download in the plugin store !
                          jiminy-billy-bob
                          Ken, were these 4 layers created before you installed the plugin ? What happen when you create a new file, create the same layers, and try to save it as template ?
                          If you find a way to reproduce the bug every time, that would be really great ! πŸ˜„ I could propably debug this
                          • kenK Offline
                            ken
                            Well OK, I noticed that there were other versions of this plugin in my plugin folder. So I deleted all files associated with this plugin and did a re-install. It now appears to be working. I can save a template file, and re-open and have the four layers still there and in the group I added.
                            Hope this helps.
                            Ken
                            • X Offline
                              xkalvisx
                              I hope you have ever done:
                              Group - visible
                              Group - invisible
                              Should operate in a single click
                              Thank you
                                jiminy-billy-bob
                                What do you mean ? You can already hide/show groups with a single click.
                                  jiminy-billy-bob
                                  Hope this helps.
                                  Ken
                                  Great ! I'm glad it works now.
                                  But did you have the corrupt template multiple times ? I mean, was it just one time or was it systematic ?
                                  EDIT : When you say you had multiple versions installed, was it a beta (layer_panel.rb) and an old alpha version (Layers Panel.rb) ? Otherwise, I don't understand how you can have multiple versions
                                    jiminy-billy-bob
                                    Okay, I find a way to reproduce the bug in version 0.3 :
                                    • Open blank file
                                    • Open LP's dialog
                                    • Create group
                                    • Save as template
                                    I get "Incorrect format file" each time.
                                    The good news is I don't get this with version 0.3.1 ! πŸ˜„
                                    So it was probably related to the group names bug. So please update everybody !
                                    Thanks a lot Ken for your feedback, it helped me a lot finding the way to reproduce it.
                                    I hope it was the same problem cmeed had, even though he didn't save as template.
                                      jiminy-billy-bob
                                      For people understanding ruby :
                                      I fully identified the cause of the problem : The plugin trying to save "nil" as an AttributeDictionary key.
                                      @layerDictID being nil (the bug about group names)
                                      @model.set_attribute("jbb_layerspanel_groups", @layerDictID, groupName)
                                      • kenK Offline
                                        ken
                                        Well I was looking the plugin directory an found more than one layerpanel directory and some other files I believe came from other installations. I don't remember all the names, I just removed everything having to do with layerpanel. And re-installed and presto it works.
                                        Thanks for looking into this plugin.
                                        Wishing you luck.
                                        Ken
                                        • X Offline
                                          xkalvisx
                                          No groups, but the group of layers.
                                          It is now possible to make invisible only one layer.
                                          If you see me group 5 layers, this group click on the "eye", I wish that all the five layers in the group would become visible or not.
                                          Thanks.
                                          P.S.
                                          Sorry for the very poor proficiency in English.
                                            jiminy-billy-bob
                                            If you put layers in a group, and hide that group, all the nested layers will be hidden.
                                            But maybe you're talking about selecting multiple layers and hide them all with one click? I'm not sur about that workflow
                                            • 33
                                            • 34
                                            • 4 / 34
