    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 321.9k Views 110 Watching
    • jiminy-billy-bobJ Offline
      jiminy-billy-bob
      Sorry guys about the group names, I'll look into it.
      @cmeed said:
      EDIT: I'm not sure what happened but the layers have now appeared - it could have coincided with me importing an image but not sure
      When you had the problem, did you restart sketchup after installing the plugin ?
      If you manage to reproduce the bug, I would be glad if you gave me the intructions.
      @xkalvisx said:
      We would like to keep the size of the panel as it was before it was shut down.
      Sorry, but that's a limitation of the API. Sketchup saves the dialog's size/position between sessions, but not during a session... Dumb, I know, but there's not much I can do.
      @bagatelo said:
      Maybe you can add this function?
      http://sketchucation.com/forums/viewtopic.php?f=323&t=54108&p=490389#p490389
      That's not really the purpose of the plugin, which is to manage layers, not the model's entities. Maybe one day I'll add this kind of features, but for now that's not my priority.
        jiminy-billy-bob
        @cmeed said:
        EDIT: every time i use "undo" the layer Group Name reverts back to the "Group1"- its original default name.
        Anybody confirm this???
        (all layer names within group stay the same)
        When you undo, the Layers Panel dialog reloads its content. So what you're seeing is related to the same bug everybody is having with group names.
        • cmeedC Offline
          cmeed
          Yes i restarted - they didn't appear right away! they appeared after i'd worked on the model for a bit. then i noticed. I'll keep my eyes open when next time the occasion crops up.
          Great to see this Plugin. especially the "add layer visible only in this scene" - touch!!
          c
            jiminy-billy-bob
            If you have an old copy of the file that you didn't open after you installed Layers Panel, it would be great if you could PM it to me πŸ˜„
            • cmeedC Offline
              cmeed
              I've just had a bugsplat - was it from this plugin? its new on my computer..... also new, the latest version of su was downloaded this morning
              the major thing is i can't open the file now. "unexpected file format"!!!! Any Help?
              arrgh
              c
                jiminy-billy-bob
                Did you try disabling/uninstalling the plugin ?
                • cmeedC Offline
                  cmeed
                  everything was working well (the group names was the only thing) I was working inside a group outliner was open and then i got the bugsplat. I dont normally get bugsplats so its funny.
                  I didn't uninstall or do anything witht the plugin.
                  did you mean to uninstall it and try opening the files? as I've tried opening themon my Mac (no "Layers {abel" plugin) and still not luck - It happened on my pc
                  opening .skb and .skp result with Unexpected file format.
                  • kenK Offline
                    ken
                    I have had the same problem as cmeed. The unexpected file format. Luckily for me I had a backup or I would have lost the file.
                    Note, I have the plugin TIG: Archiver v2.0 which is a life saver.
                    404 Not Found
                    (sketchucation.com)
                    Thanks for your plugin.
                    Ken
                      jiminy-billy-bob
                      Holy sh...
                      I'll try to reproduce the bug. That's a big problem if it corrupts files... πŸ˜• I'm so sorry, I hope you didn't lose your work.
                      I'll add a warning in the first post.
                        jiminy-billy-bob
                        cmeed, can you check if you still have the dump/log files produced by the bugsplat ?
                        • cmeedC Offline
                          cmeed
                          I have started again (this time with archiver as cover)
                          c
                          • ElibjrE Offline
                            Elibjr
                            Oh wow, this is truly a nice plugin. I wished that the standard layers toolbar worked this way. Now I want to install in on both my laptop and the desktop machine. This is one of the cleanest plugins I have used. Great work Jiminy. My top 10 now.
                            Elibjr
                              Ben Ritter
                              I appreciate your generosity in sharing this plugin
                                jiminy-billy-bob
                                Thanks everybody for your kind words, comments and feedback ! I really appriciate it.
                                • kenK Offline
                                  ken
                                  I have 4 layers that are in my template. I wanted to get this under a group, so I could turn all the layers off at once. They are xlines, markcenter, workplane and cline. When I try saving a template file, I get unexpected file format and the program closes. On trying to open Sketchup again, I get the failed to open template file. Sketchup open but not with the template file that I saved.
                                  However, when I open the standby template file, saved as a regular file, and then try to save this file as a template with the name I used above, I get the file exist and do you wish to over write the file. So something was saved.
                                  Just trying to keep you abreast.
                                  Ken
                                    jiminy-billy-bob
                                    Thanks Ken, I'll look into that.
                                      jiminy-billy-bob
                                      New version 0.3.1 beta !
                                      Changelog :
                                      • Fix group names disappearing
                                      Download in the plugin store !
                                        jiminy-billy-bob
                                        Ken, were these 4 layers created before you installed the plugin ? What happen when you create a new file, create the same layers, and try to save it as template ?
                                        If you find a way to reproduce the bug every time, that would be really great ! πŸ˜„ I could propably debug this
                                        • kenK Offline
                                          ken
                                          Well OK, I noticed that there were other versions of this plugin in my plugin folder. So I deleted all files associated with this plugin and did a re-install. It now appears to be working. I can save a template file, and re-open and have the four layers still there and in the group I added.
                                          Hope this helps.
                                          Ken
                                          • X Offline
                                            xkalvisx
                                            I hope you have ever done:
                                            Group - visible
                                            Group - invisible
                                            Should operate in a single click
                                            Thank you
                                            • 33
                                            • 34
                                            • 3 / 34
