    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 368.9k Views 110 Watching
    • kenK
      ken
      I have 4 layers that are in my template. I wanted to get this under a group, so I could turn all the layers off at once. They are xlines, markcenter, workplane and cline. When I try saving a template file, I get unexpected file format and the program closes. On trying to open Sketchup again, I get the failed to open template file. Sketchup open but not with the template file that I saved.
      However, when I open the standby template file, saved as a regular file, and then try to save this file as a template with the name I used above, I get the file exist and do you wish to over write the file. So something was saved.
      Just trying to keep you abreast.
      Ken
      • jiminy-billy-bobJ
        jiminy-billy-bob
        Thanks Ken, I'll look into that.
        • jiminy-billy-bobJ
          jiminy-billy-bob
          New version 0.3.1 beta !
          Changelog :
          • Fix group names disappearing
          Download in the plugin store !
          • jiminy-billy-bobJ
            jiminy-billy-bob
            Ken, were these 4 layers created before you installed the plugin ? What happen when you create a new file, create the same layers, and try to save it as template ?
            If you find a way to reproduce the bug every time, that would be really great ! πŸ˜„ I could propably debug this
            • kenK
              ken
              Well OK, I noticed that there were other versions of this plugin in my plugin folder. So I deleted all files associated with this plugin and did a re-install. It now appears to be working. I can save a template file, and re-open and have the four layers still there and in the group I added.
              Hope this helps.
              Ken
              • X
                xkalvisx
                I hope you have ever done:
                Group - visible
                Group - invisible
                Should operate in a single click
                Thank you
                • jiminy-billy-bobJ
                  jiminy-billy-bob
                  What do you mean ? You can already hide/show groups with a single click.
                  • jiminy-billy-bobJ
                    jiminy-billy-bob
                    Hope this helps.
                    Ken
                    Great ! I'm glad it works now.
                    But did you have the corrupt template multiple times ? I mean, was it just one time or was it systematic ?
                    EDIT : When you say you had multiple versions installed, was it a beta (layer_panel.rb) and an old alpha version (Layers Panel.rb) ? Otherwise, I don't understand how you can have multiple versions
                    • jiminy-billy-bobJ
                      jiminy-billy-bob
                      Okay, I find a way to reproduce the bug in version 0.3 :
                      • Open blank file
                      • Open LP's dialog
                      • Create group
                      • Save as template
                      I get "Incorrect format file" each time.
                      The good news is I don't get this with version 0.3.1 ! πŸ˜„
                      So it was probably related to the group names bug. So please update everybody !
                      Thanks a lot Ken for your feedback, it helped me a lot finding the way to reproduce it.
                      I hope it was the same problem cmeed had, even though he didn't save as template.
                      • jiminy-billy-bobJ
                        jiminy-billy-bob
                        For people understanding ruby :
                        I fully identified the cause of the problem : The plugin trying to save "nil" as an AttributeDictionary key.
                        @layerDictID being nil (the bug about group names)
                        @model.set_attribute("jbb_layerspanel_groups", @layerDictID, groupName)
                        • kenK
                          ken
                          Well I was looking the plugin directory an found more than one layerpanel directory and some other files I believe came from other installations. I don't remember all the names, I just removed everything having to do with layerpanel. And re-installed and presto it works.
                          Thanks for looking into this plugin.
                          Wishing you luck.
                          Ken
                          • X
                            xkalvisx
                            No groups, but the group of layers.
                            It is now possible to make invisible only one layer.
                            If you see me group 5 layers, this group click on the "eye", I wish that all the five layers in the group would become visible or not.
                            Thanks.
                            P.S.
                            Sorry for the very poor proficiency in English.
                            • jiminy-billy-bobJ
                              jiminy-billy-bob
                              If you put layers in a group, and hide that group, all the nested layers will be hidden.
                              But maybe you're talking about selecting multiple layers and hide them all with one click? I'm not sur about that workflow
                              • cmeedC
                                cmeed
                                I have another one for you....
                                With the layer Panel open I can't use my shortcut key 'P' assigned to Create new scene. Turn panel off and shortcut key works as it should.
                                Does that happen for anyone else?
                                In the model I'm using i have a lot of layers going on. I've just had a major bug splat too, thankfully no lost data or corrupted files. on opening the the file again after the bugsplat, the bugsplat happened again and again - straight away before SU seemed to even open - restarted Machine seems Ok- File opened as Usual
                                mmmmm
                                c
                                • jiminy-billy-bobJ
                                  jiminy-billy-bob
                                  Were you trying to delete/purge layers with outliner opened ?
                                  http://sketchucation.com/forums/viewtopic.php?f=180&t=54161
                                  • jiminy-billy-bobJ
                                    jiminy-billy-bob
                                    Not sure about the P shortcut, I'll look into that.
                                    • cmeedC
                                      cmeed
                                      before the major bugsplat I was trying to create new scenes outliner could have been open. When i pressed P no scene tabs appeared which drew my attention
                                      then i opened the 'Scenes window' and noticed the scenes were there - but as i said no scene Tabs at the top of the SU Window. Then the crash
                                      • B
                                        Bimbalas
                                        Hi, jiminy-billy-bob,
                                        very nice job. Thanks.
                                        I'm discovered a new bug.
                                        On renamaming layers or groups directly on Layers Panel with letters from non ASCII character set (e.g. Δ…ΕΎΔ―Δ—Ε‘) this letters was changed to unicode codes.
                                        Can you look for this?
                                        • B
                                          breezy
                                          JBB,
                                          Thank you for designing the Layers panel, it is great to be able to nest layers. 😍
                                          But when I tried to remove a layer and delete the contents Sketchup throws a Bug Splat. πŸ‘Ž
                                          This happened first with 0.2 but again with 0.3.1. I am using Sketchup 2013. The layer that I tried to delete had no components assigned to it. I had the Outliner window open and just before the bug splat was thrown I noticed a bundle of groups appear on the bottom of the Outline tree. The model statistics are 201 components definitions, 35 layers, 31 materials all created before installing Layers panel. Some of the layers were hidden at the time of the bug splat. I submitted the bug splat #43650, if it is any help I still have a copy of the splat files Undo.log, Sketchup.dmp and .xml.
                                          Regards,
                                          Arie.
                                          • jiminy-billy-bobJ
                                            jiminy-billy-bob
                                            Bimbalas > I'll look at non-ASCII characters.
                                            Breezy > That's a known bug and Dan helped me fix it : http://sketchucation.com/forums/viewtopic.php?f=180&t=54161
                                            It will be fixed in the next release (out in a few days)
                                            • 33
                                            • 34
                                            • 4 / 34
