    [Plugin] Layers Panel 1.2.1
    672 Posts 109 Posters 183.0k Views 109 Watching
    • X Offline
      xkalvisx
      Does not save group names
      opening the panel, the group names reappear (Group1, group2, etc.).
      More ...
      We would like to keep the size of the panel as it was before it was shut down.
      Great thanks.
      https://www.dropbox.com/s/mw0340kn4nvquja/1.jpg
      Dropbox - Error - Simplify your life
      (www.dropbox.com)
      Before it was listed all the names of the groups.
      Thanks.
      • bagateloB Offline
        bagatelo
        Maybe you can add this function?
        http://sketchucation.com/forums/viewtopic.php?f=323&t=54108&p=490389#p490389
        • cmeedC Offline
          cmeed
          This plugin is really good. And intuitive. maybe because its so familiar (pShop)
          I am losing my group names. no data lost but its happened a couple of times.
          I'm looking out for the next time and will report ..
          cheers
          c
          EDIT: every time i use "undo" the layer Group Name reverts back to the "Group1"- its original default name.
          Anybody confirm this???
          (all layer names within group stay the same)
          • jiminy-billy-bobJ Offline
            jiminy-billy-bob
            Sorry guys about the group names, I'll look into it.
            @cmeed said:
            EDIT: I'm not sure what happened but the layers have now appeared - it could have coincided with me importing an image but not sure
            When you had the problem, did you restart sketchup after installing the plugin ?
            If you manage to reproduce the bug, I would be glad if you gave me the intructions.
            Sorry, but that's a limitation of the API. Sketchup saves the dialog's size/position between sessions, but not during a session... Dumb, I know, but there's not much I can do.
            That's not really the purpose of the plugin, which is to manage layers, not the model's entities. Maybe one day I'll add this kind of features, but for now that's not my priority.
              jiminy-billy-bob
              When you undo, the Layers Panel dialog reloads its content. So what you're seeing is related to the same bug everybody is having with group names.
              • cmeedC Offline
                cmeed
                Yes i restarted - they didn't appear right away! they appeared after i'd worked on the model for a bit. then i noticed. I'll keep my eyes open when next time the occasion crops up.
                Great to see this Plugin. especially the "add layer visible only in this scene" - touch!!
                c
                  jiminy-billy-bob
                  If you have an old copy of the file that you didn't open after you installed Layers Panel, it would be great if you could PM it to me 😄
                  • cmeedC Offline
                    cmeed
                    I've just had a bugsplat - was it from this plugin? its new on my computer..... also new, the latest version of su was downloaded this morning
                    the major thing is i can't open the file now. "unexpected file format"!!!! Any Help?
                    arrgh
                    c
                      jiminy-billy-bob
                      Did you try disabling/uninstalling the plugin ?
                      • cmeedC Offline
                        cmeed
                        everything was working well (the group names was the only thing) I was working inside a group outliner was open and then i got the bugsplat. I dont normally get bugsplats so its funny.
                        I didn't uninstall or do anything witht the plugin.
                        did you mean to uninstall it and try opening the files? as I've tried opening themon my Mac (no "Layers {abel" plugin) and still not luck - It happened on my pc
                        opening .skb and .skp result with Unexpected file format.
                        • kenK Offline
                          ken
                          I have had the same problem as cmeed. The unexpected file format. Luckily for me I had a backup or I would have lost the file.
                          Note, I have the plugin TIG: Archiver v2.0 which is a life saver.
                          http://sketchucation.com/forums/viewtopic.php?p=149749#p149749
                          Thanks for your plugin.
                          Ken
                            jiminy-billy-bob
                            Holy sh...
                            I'll try to reproduce the bug. That's a big problem if it corrupts files... 😕 I'm so sorry, I hope you didn't lose your work.
                            I'll add a warning in the first post.
                              jiminy-billy-bob
                              cmeed, can you check if you still have the dump/log files produced by the bugsplat ?
                              • cmeedC Offline
                                cmeed
                                I have started again (this time with archiver as cover)
                                c
                                • ElibjrE Offline
                                  Elibjr
                                  Oh wow, this is truly a nice plugin. I wished that the standard layers toolbar worked this way. Now I want to install in on both my laptop and the desktop machine. This is one of the cleanest plugins I have used. Great work Jiminy. My top 10 now.
                                  Elibjr
                                    Ben Ritter
                                    I appreciate your generosity in sharing this plugin
                                      jiminy-billy-bob
                                      Thanks everybody for your kind words, comments and feedback ! I really appriciate it.
                                      • kenK Offline
                                        ken
                                        I have 4 layers that are in my template. I wanted to get this under a group, so I could turn all the layers off at once. They are xlines, markcenter, workplane and cline. When I try saving a template file, I get unexpected file format and the program closes. On trying to open Sketchup again, I get the failed to open template file. Sketchup open but not with the template file that I saved.
                                        However, when I open the standby template file, saved as a regular file, and then try to save this file as a template with the name I used above, I get the file exist and do you wish to over write the file. So something was saved.
                                        Just trying to keep you abreast.
                                        Ken
                                          jiminy-billy-bob
                                          Thanks Ken, I'll look into that.
                                            jiminy-billy-bob
                                            New version 0.3.1 beta !
                                            Changelog :
                                            • Fix group names disappearing
                                            Download in the plugin store !
                                            • 11
                                            • 12
                                            • 33
                                            • 34
                                            • 10 / 34
