    [REQ] Plugin to make accurate budgets...
    20 Posts 8 Posters 5.7k Views 8 Watching
      You can't [easily] change the axis of a group... BUT it's easily fixed for a component...
      Then the XYZ reported ARE the correct sizes...
      • bagateloB
        bagatelo
        @i.aleks.s said:
        @bagatelo said:
        At this time, I think this is the better to my needs:
        http://sketchucation.com/forums/viewtopic.php?p=147658#p147658
        If You will be interested in this, I can communicate with You on this case and will share the information that I have.
        Good luck.
        @I.Aleks.S
        Yes! Would greatly appreciate any information that would facilitate my work.
        You can add me in facebook:
        https://www.facebook.com/alex.henrique.projetos
        @ashscott
        So now the only thing that I need to use the plugin ComponentReporter from TIG would be something that turns groups into components, and other that align objects in one direction only, putting such components and groups with longer side near the origin, disregarding the blue axes.
        Please open file that I share.
        Thanks guys!
        cutlist.skp
          The right-click context-menu lets you change selected groups into components...
          It could readily be made into a 'one-liner' so every group in a selection were made into a component...
          • bagateloB
            bagatelo
            Thank you TIG!
            I already knew of this possibility, but I thought of something that turns any group in the root in the outliner into component.
            Please consider creating something that did what the picture below shows.
            Please note that the objects were aligned by layers, by opening cutlist.skp below.
            Thank you!
            cutlist.skp
              It sounds to me you could head off a lot of your problems or reduce your demands from a plugin by changing your modeling workflow somewhat. For example if you just made components from the beginning...
              • bagateloB
                bagatelo
                Ok! I undestand you. This is not the great problem to me.
                look this:
                http://sketchucation.com/forums/viewtopic.php?f=323&t=16154#p210502
                So the only problem now it from some component that are not align in green or red axes.
                The problem is that components are in a diagonal position. It would be possible to create a plugin that all align as shown above or at least orient all component in a single direction?
                  If you're making components instead of groups, it is no big deal to align the axes for parts that are positioned diagonally so you can get accurate dimensions from a cut list. If you would practice good, clean modeling techniques you wouldn't need a plugin to make a group or component from loose geometry.
                  I frequently make accurate and precise cut lists and materials lists from complex models and I have no trouble with existing tools. One reason I don't have any difficulty is because every part is a component and I don't leave any loose geometry.
                  http://farm8.staticflickr.com/7392/9693495449_a8bd7cb886.jpg
                  • ashscottA
                    ashscott
                    Yeah I have to agree, I don't think I've seen a tool in any piece of software that lets you model hap-hazzardly and then reports accurately later - if you want an accurate report of what is in your model then you will have to align all the axes appropriately....
                    I'm willing to be surprised though
                    Just some stuff I do with Sketchup.
                    • KrisidiousK
                      Krisidious
                      It's a little steep... $179.00 But it does a lot.
                      http://www.renderplus.com/wp2/wk/Products.htm#SpaceDesign
                      By: Kristoff Rand
                      • ashscottA
                        ashscott
                        But it does a lot.
                        You're saying that this space design plugin from renderplus can interpret geometry that has been drawn crooked with the group/components axis not aligned?
                        • KrisidiousK
                          Krisidious
                          No, I mean it can make accurate budgets... I was referring to the OP.
                          By: Kristoff Rand
