    Plugin Folder Permision Issue
    6 Posts 3 Posters 1.1k Views 3 Watching
    • renderizaR Offline
      renderiza
      Somehow I changed the plugin folder permission and I don't know how to fix it. Here is an image showing that the current setting for permission doesn't allow anything.
      http://s12.postimg.org/gu7trb7fx/Untitled_1.jpg
      This setting only showed on Plugins Folder but in trying to fix it now I have made all folder use this Creator Owner Permision which I can't delete. πŸ˜• This doesn't even allow Extension Warehouse to install plugins automatically.
      Can someone help me? Do I need to restore my computer factory settings or is there easier way.
      Thanks,
      Renderiza
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
      • Rich O BrienR Online
        Right click SketchUp icon and choose run as admin.
        return with result
          renderiza
          It works great when I do what you suggested. Now I need to find a way to always to this without the need of right click.
            renderiza
            Running this auto fix from Microsoft Support solved some of the problem.
            http://support.microsoft.com/mats/windows_file_and_folder_diag
            I can install plugins with Plugin Store and Extension Warehouse again but the same problem persist that I can't change settings for Selection Toys. :S
            Note: Tested Plugin Store and I can Disable plugins now as well which before I couldn't so that is good news.
            • TIGT Online
              You can make SketchUp.exe always run as admin.
              As an admin [give yourself that power in the Users Control Panel]...
              Select the SketchUp.exe icon
              Right-click
              Context-menu
              Properties
              Compatibility
              Tick the 'Always run this Application as Administrator...' box.
              The permissions for the Plugins folder and its contents should be FULL read/write for all users/groups in the list:
              Select the Plugins folder's icon
              Right-click
              Context-menu
              Properties
              Security
              Edit
              FULL for all listed
              Apply/OK
              You could also try the Advanced button > Owner > Edit to change the ownership to say 'Admin' [yourself] AND tick the check-box option at the bottom to permeate that change down to affect all of the folder's contents...
                renderiza
                Thank you TIG I used your first suggestion and it works great.
